Flat speaker cables vs conventional ones? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-30-2000, 01:00 PM - Thread Starter
Goi
Goi's Avatar
I'm thinking of getting flat speaker cables for my surrounds due to their unobstrusiveness(or at least less-obstrusiveness), but I'm wondering if they are any worse than conventional speaker cables? I don't wish to lose sound quality on the cables.
A64 2.5GHz, Chaintech VNF3-250, 2x512MB Kingmax DDR500, XFX 6800GT AGP, SB Audigy2 ZS, Seagate 250GB, SATA, Liteon 12X DVD burner, 16X DVD-ROM.
Goi is offline
post #2 of 10 Old 12-30-2000, 03:16 PM
Dave928's Avatar
Location: Seattle - it's not Hell, but you can see it from h
how do you think you'd lose sound quality? flat is just as good as round...
dave
Widescreen DVD - Because a superior format requires superior formatting.
No, i can't go out, i'm watching Garbo...
Dave928 is offline
post #3 of 10 Old 12-30-2000, 06:40 PM
David Richardson's Avatar
As Dave puts on his Flame retardent suit.
Flat speaker wire will work just fine. Each speaker wire,type,AWG,Manuf. will give you a different sound. Depending on you equipment,(amps,interconnects,speakers,room layout) you may or maynot hear a difference. With surrounds they are less critical than the center and mains.
This is IMHO with my experience having installed many many systems at all levels.
Watch HDTV!!! Nothing else comes close!
David Richardson is offline
post #4 of 10 Old 12-30-2000, 09:26 PM
Steve Bruzonsky's Avatar
Quoted: 440 Post(s)
Liked: 101
Male speaker cable is flat, female speaker cable is round, and which sounds better depends on your sexual preference!
Seriously, flat vs oval vs round isn't the question. How does it sound in your system and room, that's the question!!!
Steve Bruzonsky
You mean you don't remember me? Back 1999 - 2003, I started and moderated the AVS Tweaks forum and also the AVS Special Guests forum.
My home theater at:
http://www.avsforum.com/avs-vb/showthread.php?t=1158431
Steve Bruzonsky is offline
post #5 of 10 Old 12-30-2000, 09:59 PM - Thread Starter
Goi
Goi's Avatar
So the general concencus is that there's no difference? Good. Are there any budget flat speaker cables around? The only flat cables I know of are the Nordost line of speaker cables.
For the mains/center I'm thinking of getting Audioquest Indigo+, Kimber 4TC, Ven Den Hul CS-122 or something of that price range(~$10/m). I think the Nordost Flatline Golds cost around the same price as well?
Goi is offline
post #6 of 10 Old 12-31-2000, 02:50 AM
Warren's Avatar
I use Tributaries SP3F 14awg flat speaker wire for my surrounds. They work very well.
Warren is offline
post #7 of 10 Old 12-31-2000, 05:12 AM
Dave928's Avatar
Monster makes 12 and 14 ga. cable...
Dave928 is offline
post #8 of 10 Old 12-31-2000, 06:19 PM
Quoted: 440 Post(s)
Liked: 101
My friend physicist Jack Bybee swears by the super expensive Nordost cables, and they are FLAT!!!!! However, my Bybee Meitner balanced interconnects are of a small round diameter!
Steve Bruzonsky
My home theater at:
post #9 of 10 Old 01-01-2001, 05:20 PM
Quoted: 440 Post(s)
Liked: 101
I think Jack luvs the Nordost SPM! Oh well!!!
Jack used a tiny bit of this cabling with his now discontinued external speaker filters.
Steve Bruzonsky
My home theater at:
post #10 of 10 Old 01-02-2001, 02:10 AM
phyre3's Avatar
Wireworld just came out with some cheap flat (UL Listed I believe) speaker wire.
Gifford Largey
AudioVision Systems
phyre3 is offline
Closed Thread Speakers
