Help in understanding - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-18-2007, 10:43 AM - Thread Starter
delrmx01's Avatar
I currently have an HTIB (5.1) Onkyo, forgot the model number. I was planning on replacing the speakers however I had one question concerning ohm impendance-- would it be okay for me to replace my center speaker to a speaker that has an impendance of 4 ohms, while my current speaker has an impendance of 8 ohms?
I tried reading up on this but it's all Latin to me... I'm more of a videophile I guess. Thanks for any help or explanations you can provide.
I don't have a signature...
delrmx01 is offline
post #2 of 7 Old 04-18-2007, 02:53 PM
deneb's Avatar
An amp that comes in a HTIB probably isn't stable enough to drive a 4 ohm load. It could overheat and either shut down or damage itself driving such a load.
deneb is offline
post #3 of 7 Old 04-18-2007, 03:06 PM
Stymlie's Avatar
Need more info. You might be OK if you have the 100wpc Onkyo and the 4 ohm center in question is very efficient / has small drivers, and the power handling requirement of the center is minimal. My 6 ohm 3" boombox speaker requires 5 watts.
Stymlie is offline
post #4 of 7 Old 04-18-2007, 03:49 PM - Thread Starter
delrmx01's Avatar
Hmmm... well the receiver I know has 100 watts pc. I was looking into getting the Polk CSi25--they're having a sale right now 59.99, I was planning on pairing it up with two R300s and buy a sub later on. Thanks again for the replies !
delrmx01 is offline
post #5 of 7 Old 04-18-2007, 03:51 PM - Thread Starter
delrmx01's Avatar
I'm on a tight budget but I'd like to upgrade my speakers for now...something decent within 3-4 hundred bucks on a 5.1 speaker system.
delrmx01 is offline
post #6 of 7 Old 04-18-2007, 05:57 PM
Stymlie's Avatar
I'd go ahead with it. In my small TV room I'm using an older Sony ES receiver rated at 100 wpc to drive some Polk LSi 9 speakers rated at 4 ohms and I'm not having any problems. In the future you can upgrade your receiver to compliment the more power hungry speakers.
Stymlie is offline
post #7 of 7 Old 04-18-2007, 06:45 PM
jostenmeat's Avatar
It hasn't been mentioned yet, so, if you x-over your center, you will put a significantly less load on your receiver. Of course, that also depends at which freq you x-over . . .
jostenmeat is offline
Reply Speakers
