HDCD Playback Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 12-27-2000, 10:35 PM - Thread Starter
S2K
S2K's Avatar
I have a DVD player that is capable of decoding HDCD. If my DVD player is connected to my pre-amp via digital coax only, am I still getting the benefits of HDCD or does the connection need to be analog?
Thanks for any enlightenment.
S2K is offline
post #2 of 17 Old 12-28-2000, 05:50 AM
Dave McRoy's Avatar
Assuming that your outboard decoder does not have HDCD capability then you need to use the DAC that's built into your CD player to take full advantage of HDCD. That means sending the CD player's analog outputs to your preamp, as you surmised.
HiDefDave
HiDefDave
STOP HDCP!
Dave McRoy is offline
post #3 of 17 Old 12-28-2000, 10:11 AM
hk29's Avatar
How good is HDCD playback? Is it worth choosing a DVD player with this capability?
hk29 is offline
post #4 of 17 Old 12-28-2000, 01:50 PM
rudolpht's Avatar
hk29,
After coming to the analog realization based on DenonDave advice (sorry Dave he beat you), I did see some benefit in HDCD, but remember there is limited which will be overcome by DVD-Audio & SACD. Many Tosh DVD players (mine is a 5109) have HDCD, but it would not be a short list feature I would search out.
The difference on a Denon 5800 (with 4xDACs in pure Direct) is marginal at best.
Tim
Tim
Selling Anthem PVA7.
STABILITY + Superior audio (SC09-TX) + Incredible picture (VPL-VW200) + good integration.
rudolpht is offline
post #5 of 17 Old 12-28-2000, 09:09 PM
shelly40's Avatar
Quoted: 157 Post(s)
Liked: 53
If your processor doesn't have an analog bypass, are you losing the benefits of HDCD, and SACD since it gets digitized again ?
shelly40 is offline
post #6 of 17 Old 12-28-2000, 09:23 PM - Thread Starter
S2K
S2K's Avatar
Thanks for clearing this up, Dave.
S2K is offline
post #7 of 17 Old 12-29-2000, 07:09 AM
rudolpht's Avatar
Correct.
Tim
Tim
rudolpht is offline
post #8 of 17 Old 12-29-2000, 08:20 AM
Ed Csoltko's Avatar
You need to bypass your preamp (that does not have analog bypass) with a passive preamp.
Ed Csoltko is offline
post #9 of 17 Old 12-30-2000, 03:42 PM
jfrano's Avatar
Will the Denon 5700 process the HDCD signal properly. What are the benefits of HDCD, is it a competing format against DVD-A or SACD??
jfrano is offline
post #10 of 17 Old 12-30-2000, 07:05 PM
shelly40's Avatar
Quoted: 157 Post(s)
Liked: 53
How is a passive preamp inserted into the system ? It still has to have connections to the main amp... but I can only use 1 input to that....... or can I hook up RCA plugs and XLR cables at the same time to the same amp ? Thanks
shelly40 is offline
post #11 of 17 Old 12-31-2000, 10:16 PM
shelly40's Avatar
Quoted: 157 Post(s)
Liked: 53
Anybody ?
shelly40 is offline
post #12 of 17 Old 01-01-2001, 08:36 AM
hk29's Avatar
HDCD is not a competing format for the SACD or DVD-A. HDCD was created years ago and is based on a 20bit encoding/decoding process still at 44khz stereo.
hk29 is offline
post #13 of 17 Old 01-01-2001, 08:42 AM
hk29's Avatar
oh yeah - Happy New Year!
I don't believe you specifically need a mode that says analog bypass. As long as your pe-amp or reciever does not digitize the music again ... for instance my yamaha 795 (don't laugh) does not have an analog bypass, but as long as I say main speakers is large and bass is subwoofer only then I am passing an analog signal directly through.
What is a passive pre-amp? I suspect that you it goes between your pre-amp and amp (i.e. pre-amp output rca into passive pre-amp then output of the passive to amp). Then your HDCD player would plug in the Passive. When you switch the passive to play from its input it ignores the original pre-amp ... my guess. Can anyone suggest a brand and model then we can take a look at the specifications? THANKS!
hk29 is offline
post #14 of 17 Old 01-01-2001, 10:35 AM
Ed Csoltko's Avatar
Good guess. I'm using the Creek OBH-12 Remote Control Passive Preamp to bypass my Lexicon MC-1 for SACDs. I got it from Audio Advisor. Recommended by audioreview.com and Stereophile Magazine.
post #15 of 17 Old 01-02-2001, 02:21 PM
shelly40's Avatar
Quoted: 157 Post(s)
Liked: 53
OK.. a couple of questions...
What is a passive preamp ? Is there an active preamp ?
I see where I can get a B&K PT3 ,,, its a preamp with a built in tuner... Would this accomplish what I need to have an analog bypass and not go through my processor that digitizes everything ?
Heres the address to the PT3 page so someone more knowledgeable can take a look
http://www.bkcomp.com/preamp.html
Thanks for answering
[This message has been edited by shelly40 (edited 01-02-2001).]
shelly40 is offline
post #16 of 17 Old 01-02-2001, 08:08 PM
Ed Csoltko's Avatar
The Creek OBH-12 is a remote control passive preamplifer that does not introduce any gain or distortion to the incomming signal(s). The volume control is a variable attenuator (potentiometer) that can be manually controlled or by an infra-red remote control.
post #17 of 17 Old 01-02-2001, 08:44 PM
shelly40's Avatar
Quoted: 157 Post(s)
Liked: 53
Would the above mentioned PT3 serve the same purpose?
shelly40 is offline
Closed Thread Speakers
