Digital connection dead on Meridian 565 - AVS Forum | Home Theater Discussions And Reviews
Old 01-02-2001, 06:43 AM - Thread Starter
MagnusB's Avatar
The electrical digital input just died on my Meridian 565.
(The optical input works).
Has anybody else experienced this?
There are no error messages, it just doesn't detect any signal. I have tried with my stereo DA and it detects the bitstream just fine.
///Magnus
MagnusB is offline
Old 01-02-2001, 08:07 AM
Homebread's Avatar
Have you double checked your config for source and input? I've seen where a spike or surge can whack out the config of 565's.
Homebread is offline
Old 01-02-2001, 07:45 PM - Thread Starter
MagnusB's Avatar
Yes I doublechecked the source setup and it is correct.
Neither CD,CDR or DVD works with "digital input" but
L-DISC works with the optical.
Is there some way of reseting the 565 to make sure you start
from scratch?
///Magnus
MagnusB is offline
Old 01-03-2001, 06:54 AM
Homebread's Avatar
Yes, you can retype the unit.
Power off on the back, then turn on while pressing the off key on the front.
However, this will erase all settings in the 565, including speakers, sources, distances, everything.
You'll have to start from scratch with the setup.
