Multiple Optical outputs into one input, with Escient system - AVS Forum | Home Theater Discussions And Reviews
Old 01-01-2001, 05:15 PM - Thread Starter
BobDole's Avatar
I have an Escient Tunesbase 100 system that I use with two Sony 555ES cd changers. I currently am running two 25 foot analog interconnects into two separate inputs on my Pioneer Elite receiver (CD and LD). I have the switch between the two inputs based on what changer is playing. I know the MSB digital director with the scan upgrade will automatically switch inputs based on which changer is playing. I am considereing using the splitter combiner for $20 available at http://www.soundprofessionals.com/cables/index.html and running the digital signal to a DAC. While both players will be on, only one will be playing at a time. This is only a temporary solution until the summer (I'm in a small dorm room now; apartment next year), so I don't want to spend much money right now. If this adapter will pass the digital signal to a DAC (I'm thinking used Theta DS PRO right now), it would be great. Keep in mind that the audio isn't that great now b.c I'm using cheap monster ($50/25 feet) analog interconnects from the mediocre ES DACS. thanks so much!
BobDole is offline
Old 01-02-2001, 09:09 PM - Thread Starter
BobDole's Avatar
BobDole is offline
Old 01-03-2001, 08:46 AM
Kit_C's Avatar
One way of getting around having to switch the inputs for each source would be to run the outputs of each player into an analog mixer, with the output of the mixer connected to your reciever.
Kit
San Diego, CA
Kit_C is offline
Old 01-03-2001, 12:11 PM
Kit_C's Avatar
Here's a link to a page that describes how to build your own analog mixer. The active design is what you would want to use:
http://www.nirvis.com/mixers.htm
There are MIDI products that would fit the bill, as well. Try looking at:
http://www.midiman.com/product.htm
I think the MultiMixer 6 is a popular choice for this sort of thing. You'll need to make a set of 1/4" -->RCA patch cables to use it.
Kit
San Diego, CA
Kit_C is offline
Old 01-03-2001, 10:52 PM - Thread Starter
BobDole's Avatar
Thanks for the responses, guys! Does anyone know a place to get a cheap analog mixer to use in that application? Also, the Digital Director is still an option, I just don't want to pay the $394 price right now. If there is somewhere that sells it cheaper than that (with the scan upgrade), then that would be great! Thanks again!
BobDole is offline
