Multiple Subs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-02-2001, 10:14 PM - Thread Starter
Sore Eyes's Avatar
Have processor allowing for 7.1 system. Currently using seven speakers and one sub-woofer. How do I best put another sub in the room? Do I split the signal going out to the one sub, and if so how?
Sore Eyes is offline
post #2 of 4 Old 01-03-2001, 09:36 AM
jgenduso's Avatar
The way I'm going to do it is to run the Sub out to an amp then split the signal with a nice Y RCA cable. For now I am using the Y and it is working fine, but not enough power.
Do a search on this forum. This is where I found out my information on doing it. I also ordered the cable from bettercables.com and they built a really nice one.
Hope that helps.
Joseph
jgenduso is offline
post #3 of 4 Old 01-03-2001, 05:05 PM
Tim McCune's Avatar
There are few ways to do it, depending on the sub you have. Joseph has a good idea if your sub doesn't have a line level out. Since my Velodyne HGS-18 does, they are connectable. One other piece of advise, if memory serves, most forum responders felt stacking the subs in a corner provided the best performance. By all means, check the archives.
Tim McCune is offline
post #4 of 4 Old 01-03-2001, 05:45 PM - Thread Starter
Sore Eyes's Avatar
Thanks Joseph and Jim, you have confirmed my thoughts.
Closed Thread Speakers
