RocketFish Wireless surround speaker kit - AVS Forum | Home Theater Discussions And Reviews
post #1 of 122 Old 04-25-2007, 07:34 AM - Thread Starter
stehal's Avatar
I saw a commercial about this Wirless solution for Rear speakers. The commercial said that it would work with all surround formats. Anyone tried this. I think the Price is around $100.
http://www.bestbuy.com/site/olspage....&type=category
stehal is offline
post #2 of 122 Old 04-25-2007, 11:09 PM
SOCCERrebel5's Avatar
I work at Best Buy and I can tell you that it is universally compatible with all speakers. However, it is not designed for high current (large, high-end speakers). It is geared more towards "high end" home theater in a box systems. Supposedly, Best Buy teamed up with one of the leaders in wireless technology to make it so it should be acceptable quality. I wouldn't recommend it for a high end system, but if you have a moderate system and need wireless give it a shot.
SOCCERrebel5 is offline
post #3 of 122 Old 04-26-2007, 09:06 AM - Thread Starter
stehal's Avatar
Thanks for the reply Rebel.
stehal is offline
post #4 of 122 Old 04-26-2007, 09:38 AM
Stephen Hopkins's Avatar
Seems to be a pretty basic idea... wireless transmitted to a small (probably digital) amplifier for the back speakers. It likely won't provide a whole awful lot of power to the backs but they can probably make due below reference levels. I'd run wire before I considered this but there are times that's not an option and this may be the best alternative.
Stephen Hopkins is offline
post #5 of 122 Old 04-26-2007, 04:28 PM
mcpack's Avatar
I would also love to know how this unit performs. Wonder if it suffers from slight delay over wired speakers, as some wireless systems. I have a situation where running wire is not an option, and I hate having wires running across the room.
mcpack is offline
post #6 of 122 Old 04-27-2007, 10:14 AM
DaveHolland's Avatar
Another option is the Kenwood RFU-6100. Same concept, more expensive, but at least Kenwood publishes the specs. No specs on the Rocketfish setup makes me think it puts out a couple clean watts at best.
DaveHolland is offline
post #7 of 122 Old 04-27-2007, 06:26 PM
QZ1
QZ1's Avatar
These are geared for at most a very good HTIB. It provides pretty good power for surround speakers in a HTIB, according to what I read. I read of an owner who said the manual reads, '2 x 25W into 4 ohms, RMS'.
QZ1 is offline
post #8 of 122 Old 01-16-2008, 08:27 AM
tingshen's Avatar
kenwood rfu-6100 is 50W x 2
any idea where is the cheapest place to get this? So far I only found $150....
http://www.shoptronics.com/kerfwispamsy.html
but then this is > 3x of what rocketfish is selling....
I'm wondering the impact between RFU-6100 and the rocket fish. I am considering feeding it with the Logitech Z680 speakers which is rated at 62W RMS. Is the rocketfish good enough?
tingshen is offline
post #9 of 122 Old 01-18-2008, 12:57 PM
sebberry's Avatar
Quoted: 26 Post(s)
Liked: 30
I'm sorry, but I just can't bring myself to buy anything branded "rocketfish"
sebberry is offline
post #10 of 122 Old 01-27-2008, 12:44 PM
Oone's Avatar
I've used the system on a few installs, and it works well.....supposed to only use it in line of site situations, however I've had good performance with a set up in an adjacent room(open walls) and no problem whatsoever!! If the system buzz's as some have experienced, all you need to do is connect a 100 ohm 1 watt resistor across each channels terminals(L+,L-) and problems solved! Nice little system in situations were hard wire in not a possibility.....
Oone is offline
post #11 of 122 Old 01-27-2008, 07:59 PM
bassmonkeee's Avatar
Supposedly, this has been corrected and no longer needs to be done.
PSN/XBL: bassmonkeee
Wii number: Who cares?
bassmonkeee is offline
post #12 of 122 Old 01-27-2008, 08:05 PM
Davidt1's Avatar
Quoted: 92 Post(s)
Can you use this for front and center speakers? I think wireless sound will be big in the years to come. I, for one, can't wait to get rid of speaker wires.
Davidt1 is offline
post #13 of 122 Old 01-27-2008, 09:14 PM
tonygeno's Avatar
Quoted: 134 Post(s)
Liked: 37
I can't wait to get rid of electrical cords. Think that'll be big in years to come? I also can't stand paying my electric bill. Hopefully they'll figure out a way to power all this equipment without power.
Tony
In search of the Holy Grail.
tonygeno is online now
post #14 of 122 Old 02-17-2008, 01:18 AM
carcollector's Avatar
Jeeze Tony...Chill out...
carcollector is offline
post #15 of 122 Old 02-17-2008, 02:00 AM
So this won't work with the Onkyo 705 because the Onkyo puts out 100 watts per channel to the rear speakers?
Thank you.
post #16 of 122 Old 02-17-2008, 06:22 AM
Project_2501's Avatar
The receiver will have no part in powering these speakers - they have an internal amp that powers them. You'll still need to plug these into a wall socket (well, hopefully some form of surge protector).
Project_2501 is offline
post #17 of 122 Old 02-17-2008, 08:32 AM
Tulpa's Avatar
Liked: 61
How far are your fronts from the receiver that you'd need wireless? I can understand not liking wires for surrounds, but geez...
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #18 of 122 Old 02-17-2008, 09:56 AM
Codes20's Avatar
I try not to laugh when customers want an all wireless speaker system for all of $500.
The Rocketfish system does work well, but there is a small, probably, 25 millisecond delay on it.
Codes20 is offline
post #19 of 122 Old 02-17-2008, 11:25 AM
tonygeno's Avatar
Quoted: 134 Post(s)
Liked: 37
What do you think I've been doing for the last three weeks while you've formulated your post?
Now can you help me with that electricity conundrum?
Tony
post #20 of 122 Old 02-17-2008, 11:47 PM
LOL...Much better Tony...
post #21 of 122 Old 02-18-2008, 12:23 AM
superco.mike's Avatar
LG makes a similar kit to this. Ive used it with HTIB and also smaller satelites like the mirage nanosat system.
Works relatively well in my experience with it.
superco.mike is offline
post #22 of 122 Old 02-18-2008, 12:43 AM
SirDrexl's Avatar
I don't think the delay would be a problem, since the receiver should be able to compensate. The Audyssey or similar setup should locate the speakers as a little farther back than they actually are and set the "distance" accordingly.
SirDrexl is offline
post #23 of 122 Old 02-18-2008, 01:26 AM
iMbEst's Avatar
Thank you.
I am wondering if the high power signal would burn the transmitter.....any idea?
I know Kenwood's RFU-6100 will work, coz they accept the 100W output from the receiver too.
iMbEst is offline
post #24 of 122 Old 02-18-2008, 10:07 AM
Yes, this is what I was concerned about. I have read that some (a very few) individuals have reported that their Rocketfish did not work and they returned it and the new one did not work either. Given the fact that there are so many people who say it works I am wondering if the receiver does indeed have something to do with it?
post #25 of 122 Old 02-18-2008, 11:15 AM
SirDrexl's Avatar
Since it's designed to connect to a speaker-level output, I think that it would work with receivers rated at 100 watts per channel. They'd really be limiting their market otherwise.
Looking at this on the website, I don't see much of a point. I mean, I thought each speaker had its own built-in amplifier, and you would plug in each speaker to a wall outlet on the corresponding side of the room. However, this set has a single amplifier to which both speakers must be connected, so you're going to have wires running across the back of the room anyway. Is this really better than just running wires from the receiver? I guess it would depend on the situation.
SirDrexl is offline
post #26 of 122 Old 02-18-2008, 11:19 AM
As I understand it, there are no wires running to the rear of the room. From the Onkyo to the amp/product there is a set of wires, then the receiver located by the rear speakers plugs into a wall outlet as well as connects to your speakers.
Right?
post #27 of 122 Old 02-18-2008, 11:27 AM
SirDrexl's Avatar
Right?
Right, but those two surround speakers have to be connected to the "little" receiver (sort of like being connected to each other). So, you still have wires running across the back of the room, but not from the "big" receiver to the back of the room. I could see where this would be helpful, but I'm not sure why they didn't go all the way and give each speaker its own amplifier.
SirDrexl is offline
post #28 of 122 Old 02-18-2008, 11:43 AM
tatanka01's Avatar
power 50 watts + 50 watts (1kHz, 10% THD, 8 ohms)
Think I'll stick with speaker wire, thanks just the same.
tatanka01 is offline
post #29 of 122 Old 02-18-2008, 10:03 PM
iMbEst's Avatar
totanka01, may I know what's the problem with 10% THD? degrades of SQ?
iMbEst is offline
post #30 of 122 Old 02-18-2008, 10:10 PM
Spezzy's Avatar
THD is distortion.
10% is an awful amount..
"The choices we make define our lives, because choice, not chance, determines destiny"
They call me the 18 year old DJ Audiophile-upgradeitis infected-guy!
Spezzy is offline
Reply Speakers
