Cerwin Vega D-3's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-25-2007, 03:12 PM - Thread Starter
ZeddProphecy's Avatar
Hi all, I"m new here searching for knowledge - I just picked up (well, found at the curb) a pair of CV D-3's - I guess you could call 'em vintage speakers.
I've tried just about every route to find the specs on these but have turned up nothing - even wrote to CV but they never replied.
Anyone out there know specs such as power handling or frequency response?
Also I'm refoaming them as soon as the kit gets here - anyone have advice on that or maybe pointers ?
thanks much,
Zedd
ZeddProphecy is offline
post #2 of 7 Old 04-25-2007, 08:16 PM
stevdart's Avatar
That series of loudspeakers came out in about 1985. I bought the D-9 version with the 15" sub driver at about that time. Specs will mean nothing, and CW has forever been stingy with providing parameters. Power is what you can give it until it sounds terrible...then give it a little less power. Frequency response is what it is. Expect musical output into the 30-something Hz area. It has a 10" sub driver, right?
The mid drivers are the weakest link in that series. Nothing more than $1.29 paper cones with about a half mm of Xmax. I will advise replacing those with something new that will fit, and you don't have to go very high in pricing. Just replacement OEM drivers would be better than the originals. You will note that one of the two mids is encased in a small plastic baffle and the other is open to the cabinet. If I were you, I would enclose both of them in a baffle and mount it inside the cabinet (it's okay that the tweeter is also in this small enclosure). Decide on airspace for these when you choose the replacements. Also, pull out the crossover and look it over for electolytic capacitors. Replace any that you find with the same value in a new poly or mylar cap.
stevdart is offline
post #3 of 7 Old 04-26-2007, 12:44 PM - Thread Starter
Yep, 10" sub with the orange/reddish foam - thanks for the great info- thats alot more than I expected to learn. I've got me an early spring project now.
post #4 of 7 Old 12-27-2010, 06:32 PM
PureInrg's Avatar
Here is the spec for the digital series D-3.
30 Hz-20 KHz 5-125 Watts rms ? Sensitivity 94db Max output level db @ 1 meter, driven to full power 114db
Hope this helps.
PureInrg is offline
post #5 of 7 Old 12-30-2010, 03:32 PM
NicolasKL's Avatar
Unless they made a different D3, the D3s don't have multiple mids like the D7s and D9s do.
NicolasKL is offline
post #6 of 7 Old 12-30-2010, 04:06 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 817
Just don't go picking up vintage women on the street corners.
"I've found that when you want to know the truth about someone that someone is probably the last person you should ask." - Gregory House
Chu Gai is offline
post #7 of 7 Old 12-31-2010, 09:38 AM
mark russ's Avatar
Don't knock it till you've tried it Chu, or, are those words of a bad experience there?
mark russ is offline
Reply Speakers
