cables - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-06-2001, 12:50 PM - Thread Starter
MaxM's Avatar
Now that I have a half way decent cd player in my stereo setup, i'll need some decent cables to go with it.
I'm looking for entry level interconnects and a cut above entry level speaker cables.
Does anyone have any suggestions?
~max
p.s. Monster Cable is not an option!
MaxM is offline
post #2 of 2 Old 01-06-2001, 01:43 PM
hk29's Avatar
I like my MIT T4 cables. I heard a higher benefit with the cables than the interconnects. The sound is much cleaner (detailed) and wider.
The MIT does have a box that changes the inductance frequency of the cables. Some people are resevered about this technique ... so read up. I personally like them.
http://home.fuse.net/hjkim/
hk29 is offline
Closed Thread Speakers
