XLR and RCA connections - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-02-2001, 10:07 PM - Thread Starter
shelly40's Avatar
Quoted: 141 Post(s)
Liked: 51
The manual to my amp says that you can't hook up the balanced and unbalanced connections at the same time, but why can't you ? Will the amp get ruined ?
If you assure that only one input is getting a signal, wouldn't it work ?
What I want to do is hook up my processor with the XLR cables, and the SACD player through an analog bypass to the RCA plugs...
The way my system is configured, it would just be alot easier to hook it up with both inputs....
shelly40 is offline
post #2 of 5 Old 01-03-2001, 11:08 AM - Thread Starter
shelly40's Avatar
Quoted: 141 Post(s)
Liked: 51
Anyone know ?
shelly40 is offline
post #3 of 5 Old 01-03-2001, 11:17 AM
gages's Avatar
Having researched this issue, the only Amp capable of supporting 2 sets of connections is the Sunfire Cinema Grand.
On other amps with multiple inputs you have to select which input is active (typically done through a physical switch).
What type of amp do you have?
Steve
gages is offline
post #4 of 5 Old 01-04-2001, 08:46 AM - Thread Starter
shelly40's Avatar
Quoted: 141 Post(s)
Liked: 51
I have a Krell FPB200...... I e-mailed Krell... Haven't heard back yet..
There isn't a switch, but the balanced connections have a shorting pin in them when you are not using them...
shelly40 is offline
post #5 of 5 Old 01-05-2001, 05:23 AM
gages's Avatar
I checked with Krell on this, they do not support this function.
I have a custom made amp by Llano designs that has silver relays between 2 sets of balanced connections and allows for a 12v trigger for selection of each input.
Steve
gages is offline
Closed Thread Speakers
