8 or 4 ohms? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-08-2001, 01:41 AM - Thread Starter
Michael Gwynn's Avatar
Newbie question:
I don't know what my rear speakers ohm rating (ohmage?)is, can I measure it using a digital ohmmeter?
I understand that the new rec I'm ordering is not very forgiving about a few little ohms, here and there.
Michael Gwynn is offline
post #2 of 4 Old 01-08-2001, 06:15 AM
Bob Dycus's Avatar
You cannot measure Impedance with a digital ohm meter. You will be measuring Resistance. Impedance of a speaker is the complex combination of Resistance and Inductive Reactance. The specs of the speaker should include the Nominal Impedance.
Any audio amplifier should be able to handle 4 ohm loads.
Bob Dycus is offline
post #3 of 4 Old 01-08-2001, 06:37 AM
wclark's Avatar
Bob's basic statement is true - speaker impedance is more complex than just DC resistance - but you can get a fair idea regarding the basic impedance of the woofer with an ohm meter. What you cannot easily predict from DC resistance measurements is how or how much the impedance changes at higher frequencies. Ideally the designer kept the impedance relatively constant but there are no rules saying they have to and a lot of history suggesting the designer may not - in order to solve a particular problem.
The second statement that all amplifers will drive 4 ohm loads is too sweeping. A lot of the amplifiers in "receivers" couldnt handle the added amp heating generated by their class of operations and the increased current demand of 4 ohm speakers - some simply shut down if driven at all hard, others dealt with it thru other means like inserting a low value resistor in the output for 4 ohm loads - via a switch. Tube amps usually use output transformers and these should be impedance matched to the speaker - usually done by switches or taps on the output transformer. Better solid state amps certainly should handle a 4 ohm speaker just fine, but my guess is a lot of surround speakers are not driven by amps as good as used for the front.
wclark is offline
post #4 of 4 Old 01-08-2001, 07:39 AM
Andrew Low's Avatar
My experience with speakers is they usually have the ohm rating printed on them next to the binding terminals. And in the worst case, its in the manual.
A related newbie question: Which is more efficient 4ohm or 8ohm? Why would I want one over the other?
Roo
Andrew Low is offline
Closed Thread Speakers
