Optical vs Digital Coax - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-08-2001, 09:53 PM - Thread Starter
michael goldman's Avatar
Need some help Would I be better off with using the Optical or the Digital Coax for my most used source. .
Thanks in advance
michael
michael
michael goldman is offline
post #2 of 2 Old 01-08-2001, 11:14 PM
rkaufmann's Avatar
Hi,
Neither optical or coax is "better" than the other, it's strictly personal preference. The only advantage of optical is the cables tend to be less expensive, however the trade off is they are more fragile which is only a concern if you move your equipment & cabling frequently. Digital Coax costs a bit more but tends to be more robust. As far as the quality of sound it's virtually the same.
Roger Kaufmann
rkaufmann is offline
Closed Thread Speakers
