Places to get cheap speaker mounts? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-12-2007, 12:07 AM - Thread Starter
nobi125's Avatar
I'm looking around for cheap speaker wall mounts for two rear speakers that weight about 2-2.5lbs.
I've looked around town and places like Bestbuy and Radioshack want around $40 for two mounts.
The speakers ran me $20, so I'm not really keen on the idea of spending twice that much to mount them.
I was wondering if you guys knew any reliable places online to some lower priced mounts.
nobi125 is offline
post #2 of 6 Old 05-12-2007, 04:38 AM
buzzy_'s Avatar
Quoted: 66 Post(s)
Liked: 89
buzzy_ is offline
post #3 of 6 Old 05-12-2007, 05:33 AM
zacgo's Avatar
I vaguely remember seeing pretty cheap ones at Walmart.
zacgo is offline
post #4 of 6 Old 05-12-2007, 06:07 AM
tdogroeder's Avatar
Quoted: 41 Post(s)
Liked: 81
Under $10 at monoprice.com
http://www.monoprice.com/products/pr...ormat=2&style=
John 14:6 & John 3:16
Yamaha RXV765 & Emotiva LPA-1
Ascend Sierra-2s(LCR), RSS300, Polk R15, SVS PB12 plus
Panasonic S65, Sony S5100, PS4, PS3, XBOX 360
tdogroeder is offline
post #5 of 6 Old 05-12-2007, 06:08 AM - Thread Starter
nobi125's Avatar
Much better, thanks man.
I found some pretty cheap ones at monoprice but they don't have a very good selection like that place does.
nobi125 is offline
post #6 of 6 Old 05-13-2007, 10:54 AM
joshigh's Avatar
You could always make your own. I had a HTIB system a few years ago. I went to Home Depot and picked up L brackets and the proper screws. I mounted them to the ceiling.
For around 10 bucks I had 5 hidden, solid mounts.
If you're doing a wall mount, I'm sure you could put two L brackets together to make a square, or they may even have something else that would work for you.
joshigh is offline
Reply Speakers
