best front speakers ~$1000 pair - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-14-2000, 05:39 PM - Thread Starter
rhett's Avatar
Any opinions? I was thinking about Monitor Silver 5i's, Def. Tech 2006tl. Any help is much appreaciated, these will be used for modern rock (pearl jam ect.) and will be coupled with a center and surrounds (in the spring) from the same manufacturer
thanks
rdg
rhett is offline
post #2 of 2 Old 11-14-2000, 05:44 PM
ntode's Avatar
check out the klipsch reference series. You can get a pair for much less than 1000 and maybe buy a sub.
Also B&W 603 s2's are around 1000 a pair. check those out
ntode is offline
Closed Thread Speakers
