Originally Posted by
DMark1 /forum/post/21090730
GREAT NEWS!!
Legacy just announced a new speaker, the
Legacy Audio Signature SE , which fits in the line-up between the Classic and the Focus. It is a
SEALED enclosure design, and is said to be perfect for music and home theater use. These should go great with sealed subwoofers in a home theater! I have a set of three Signature SEs on order from Legacy,
so I will post my thoughts on them after I set them up and spend some time with them.
The Signature SE is comprised of two 10" aluminum woofers, one 7" silver-graphite/rohacell mid-woofer, one 3" folded kapton ribbon midrange, and one 1" folded kapton ribbon tweeter. The mid-woofer, midrange, and tweeters are the same drivers used in the Focus and Whispers, and the 10" woofers are a similar design to the Focus' 12" woofers.
Frequency response is rated at 22 Hz-30,000 Hz +/- 2 dB.
Crossover Points are: 180 / 2,800 / 8,000
Impedance is rated at 4 ohms.
Sensitivity: 92 dB
Recommended amp power: 10 - 300 Watts
Dimensions are 48"H x 12"W x 13.75"D.
Weight is 110 lbs each.
The SE model has an upgraded, stiffer braced cabinet, performance matched drivers to .25 dB tolerences, upgraded Solen caps in the crossover, and Kimber Kable silver wiring to the tweeter. Finish options are Natural Cherry ($5,995/pr MSRP), Rosewood ($6,150/pr MSRP), or Gloss Black Pearl ($6,450/pr MSRP). Custom finishes are available at additional cost.
I can't wait to get mine!!!
