***The Official Ascend Acoustics Sierra Thread*** - Page 112 - AVS | Home Theater Discussions And Reviews
 50Likes
post #3331 of 3335 Old Today, 04:52 PM
neekos's Avatar
Quoted: 34 Post(s)
Liked: 48
I've been enjoying the Sierra 2's for a few months. I can't recommend them enough. Also, the Ascend stands that fit the other bookshelf speakers make for a great fit and presentation of the speaker. I also ordered the Sierra 1 center to use for h/t use to save some money, but it did not match the 2's too well, so I ordered the 2 center channel. Unfortunately the 2 that arrived had blemishes and scratches and Ascend has been a class act on how they are dealing with it. The Sierra 2 center is a much better speakers than the 1 center.
PS. WARNING. If anyone is going to use a VTI center channel stand with these speakers, be very careful. I had rubber pads installed in four different spots on the VTI and even with that, last night I heard a loud thump which was the Sierra 2 sliding off the stand. Damaged the speaker in two spots on the rear and cracked my floor. What I had to do as a remedy was to drill a hole on the back of the top plate of the VTI and put a bracket to hold the speaker in place. I hope this is not going to be an issue with Ascend since the speaker was being returned anyway because it was blemished to begin with. Sometimes luck or lack there of gets the best of us.
I'll post a follow up next week, but so far, the sound is lovely.
neekos is online now
post #3332 of 3335 Old Today, 05:03 PM
neekos's Avatar
Quoted: 34 Post(s)
Liked: 48
post #3333 of 3335 Old Today, 06:40 PM
lovinthehd's Avatar
Quoted: 1170 Post(s)
Liked: 1558
Try using a putty like Blu-Tack on stands, holds well even at an angle....
cschang likes this.
lovinthehd is online now
post #3334 of 3335 Old Today, 07:53 PM
neekos's Avatar
Quoted: 34 Post(s)
Liked: 48
Thanks, but the bracket I installed is more of a permanent fix.
post #3335 of 3335 Old Today, 08:51 PM
audio4life's Avatar
Liked: 202
Neekos, I wonder if you could relate your experience, when you got your Sierra 2 speakers, did the rubber isolation pads(for the speaker bottom) and the company logos stickers come with each speaker?
audio4life is online now
Reply Speakers
Ascend Acoustics , Acoustics
