***The Official Ascend Acoustics Sierra Thread*** - Page 80 - AVS Forum | Home Theater Discussions And Reviews
 561Likes
post #2371 of 4924 Old 10-01-2011, 05:56 AM
Bill Mac's Avatar
Quoted: 1589 Post(s)
Liked: 1856
Originally Posted by cuzzin View Post
Here are some pictures to demonstrate the speaker distances from the walls.
You could try toeing the Sierras out so they are not turned in so much. I would start with them without any toe in and work from there. When I had the Sierras they were 6' apart and I sit 7'-8' away dead center. I found that with just a minimal amount of toe in the Sierras sounded best in my room. Did you try moving your sub back toward the front wall or on the other side of the left speaker?
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
post #2372 of 4924 Old 10-01-2011, 05:56 PM
bcg27's Avatar
Originally Posted by kyle454 View Post
nice! thanks for the reply!
can I ask what model Rythmik sub you have?
I have the f12 in black oak finish. Since my room is smaller and I share a wall with neighbors (I live in a condo building) I did not feel anything larger than the 12 inch woofer would be appropriate. I also didn't want to fork over the extra money for the gloss finish although I do like the looks better.
The f12 is very tight and great with music, and it has enough output to get good thump during movies, but still not causing my neighbors to complain (too much ). I cross over my sierras to the sub at 80 Hz.
bcg27 is offline
post #2373 of 4924 Old 10-01-2011, 06:09 PM
Bill Mac's Avatar
Liked: 1856
I have the F12SE and agree with your thoughts that it is an excellent sounding sub for both music and HT. My room is not huge (14'D x 17'W) and the F12SE does just fine even for LFE heavy action movies. I got the F12SE at a great price used or I probably would have went with the F12 as well.
Bill
Bill Mac is offline
post #2374 of 4924 Old 10-02-2011, 11:43 AM
cuzzin's Avatar
Quoted: 63 Post(s)
Liked: 68
Bill
Thanks. Wouldn't hurt to try that. I've just always heard that they should be pointed right at the primary listening position for best results, which is why they are so turned in currently.
cuzzin is offline
post #2375 of 4924 Old 10-02-2011, 12:33 PM
cuzzin's Avatar
Quoted: 63 Post(s)
Liked: 68
Well, changing the speaker angles made no difference.
I'm back to thinking the issue could be an issue with the volume of the right speaker. I think the audio pans from the center to right speaker are so distracting because there is a noticeable volume increase. When I lower the volume level in the right channel, it sounds more seamless. Only thing is my calibrations don't agree with this. Very frustrating.
cuzzin is offline
post #2376 of 4924 Old 10-02-2011, 02:31 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 817
How are you securing the microphone when you measure?
"I've found that when you want to know the truth about someone that someone is probably the last person you should ask." - Gregory House
Chu Gai is offline
post #2377 of 4924 Old 10-02-2011, 04:05 PM
cuzzin's Avatar
Quoted: 63 Post(s)
Liked: 68
Well with the Audyssey mic, I don't use a tripod or anything like that. I just set it on top of a stack of stuff, laying as flat as possible, at about ear level. When I do a manual calibration using my Radio Shack SPL meter, I just hold the meter in my hand, with the microphone end pointing slightly up toward the ceiling.
cuzzin is offline
post #2378 of 4924 Old 10-02-2011, 05:39 PM
kyle454's Avatar
are the Sierra-1 NrT's available yet?
if not, are the Sierra-1's able to upgrade to the NrT when they become available?
thanks for the heads up!
kyle454 is offline
post #2379 of 4924 Old 10-02-2011, 07:10 PM
Bill Mac's Avatar
Liked: 1856
There is no set rule for toe in or toe out. Best to play around till you get the best sound to your ears in your room. You have not indicated if you have moved or have tried moving your sub. As I said before in your pictures the sub appears to be forward of the left speaker. If it is then that is in effect blocking the dispersion of that speaker and possibly effecting how your front LCR speakers interact.
Both methods you are using are not very good ones to be completely honest. For the best results with Audyssey and taking SPL measurements is to use a camera tripod or a mic stand. Holding the SPL meter in your hand is most likely going to yield very poor readings. The chance of you holding the SPL meter totally still and not blocking the test tones from a specific speaker are not very good.
Bill
Bill Mac is offline
post #2380 of 4924 Old 10-02-2011, 07:13 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
Bill, wasn't there also an issue with Audessey mics with some Onkyo units being defective?
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #2381 of 4924 Old 10-02-2011, 07:14 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
Yes...they are available. Also, standard Sierra-1's can be upgraded to Sierra-1 NrT's. Best to contact Ascend.
-curtis
cschang is offline
post #2382 of 4924 Old 10-02-2011, 07:22 PM
Bill Mac's Avatar
Liked: 1856
Originally Posted by cschang View Post
Wasn't there also an issue with some Audessey mics with some Onkyo units being defective?
Curtis,
Yes there were mic issues but I don't think that would be part of the issue cuzzin is having. I think that his method of doing the calibration and SPL readings could be more of the issue than anything else. He has said if he lowers the volume level of the right speaker the panning is more seamless. But he says then his SPL readings are not all at his reference point (75dB?).
So it seems that maybe his SPL readings are inaccurate and when he does it by ear it sounds much better. If he used a tripod or mic stand the readings might be much more accurate and a more seamless blend of the LCR. If he decides not to use a tripod or mic stand then maybe doing the levels by ear might be best.
Bill
Bill Mac is offline
post #2383 of 4924 Old 10-02-2011, 10:28 PM
cuzzin's Avatar
Quoted: 63 Post(s)
Liked: 68
Thanks for the ideas, Bill. I guess I should go out and buy a tripod because I don't really have one on hand. I have read a few "how-to's" on calibrating your system using an SPL meter, and I don't recall any instructions against holding the SPL meter in your hand. Some even instruct you to do so, at a certain angle. I know with the Audyssey mic I probably should use a tripod or stand of some sort.
As far as my subwoofer, I will definitely try pushing it further back to the wall. There isn't a whole lot of room behind the sub, but there is some.
cuzzin is offline
post #2384 of 4924 Old 10-03-2011, 09:54 AM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
What test tones are you using? What is the source of the tones..the receiver?
Are you experiencing this issue just with DVD/BluRay movies?
-curtis
cschang is offline
post #2385 of 4924 Old 10-03-2011, 11:56 AM
cuzzin's Avatar
Quoted: 63 Post(s)
Liked: 68
I use the test tones on the Digital Video Essentials Blu-ray when I calibrate with the SPL meter. I do have problems bitstreaming the native TrueHD on that disc for some reason, so I just pass it via PCM. When I use Audyssey, the receiver tones are used, obviously.
As far as when I experience the issue, I first really noticed it when watching the Breaking Bad episode "Bullet Points," in a scene where dialog switched between the center and right channel. I thought maybe it was an issue with the broadcast until I noticed it again during a scene on the Scarface Blu-ray, when a gun being fired panned from the center to right channel.
cuzzin is offline
post #2386 of 4924 Old 10-03-2011, 12:18 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
I believe the receiver should also be able to play its test tones without the use of Audyssey. I would use those and check with your SPL meter, and see if the results are the same as when using the DVE disc.
You have already swapped speakers, and the problem persisted, so it is definitely a room/calibration/setup issue.
-curtis
cschang is offline
post #2387 of 4924 Old 10-03-2011, 01:31 PM
cuzzin's Avatar
Quoted: 63 Post(s)
Liked: 68
I know how to use the receiver's own test tones to calibrate, I just always heard using a disc was more accurate because you are calibrating the source more directly. In any event, I will re-calibrate using the Onkyo's test tones later on to see if a difference is made, though I'm not optimistic there will be.
cuzzin is offline
post #2388 of 4924 Old 10-03-2011, 03:31 PM
Bill Mac's Avatar
Liked: 1856
I have found that if you start over analyzing what you are listening to and looking for flaws you'll find them. Have you checked the distance (delay) settings of your front speakers? It could be possible that the issues you are hearing are flaws in the material itself.
Bill
Bill Mac is offline
post #2389 of 4924 Old 10-03-2011, 07:04 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
Understood...just wondering why when calibrated it doesn't sound correct to you, and better when you do it by ear.
-curtis
cschang is offline
post #2390 of 4924 Old 10-03-2011, 09:16 PM
cuzzin's Avatar
Quoted: 63 Post(s)
Liked: 68
I'm wondering the exact same thing.
cuzzin is offline
post #2391 of 4924 Old 10-03-2011, 09:23 PM
cuzzin's Avatar
Quoted: 63 Post(s)
Liked: 68
Bill
I may just have to end up paying a pro home theater calibrator to come set my system up right. I wish someone here had the episode in question on their DVR so they could check it out.
Yes, the delay is about right. Audyssey set it up and I reviewed the numbers it came up with afterward.
cuzzin is offline
post #2392 of 4924 Old 10-03-2011, 10:05 PM
Ascend's Avatar
Quoted: 123 Post(s)
Liked: 298
Hi Cuzzin,
I have been reading about your situation. From your pictures, it appears like your left speaker is situated in a corner of the room while the right speaker is not.
It is important to understand that when setting levels, SPL meters and receivers will use an average SPL measurement to approximate the levels.
Due to your room, your left speaker is most likely going to have quite a bit of room gain compared to your right speaker. This additional gain can skew the spl measurements such that when all levels are set to zero, the left speaker is measuring with higher SPL then your right speaker such that the right speaker will be set several dB higher to compensate. You also have a rather large subwoofer placed very close to the left speaker and this too will increase gain such that the right speaker will need compensation (boost).
It is highly likely based on what you have posted that the level setting of the right speaker has been boosted such that the "average" sound pressure level is now the same as the right speaker. However, room gain is typically not in the critical upper midrange response and this frequency range might be boosted too high compared to the left speaker such that while the average spl between both speakers is the same, a frequency range that you are sensitive to is now too high on the right speaker compared to the left.
Try this simple experiment... Turn OFF all Audyssey features and manually set the level adjustments for the front speakers to "Zero". Now listen to the same recordings and report back to us.
David Fabrikant
audio professional and soft spoken representative of www.AscendAcoustics.com
Ascend is offline
post #2393 of 4924 Old 10-04-2011, 07:23 AM
Tallen234's Avatar
Although I highly doubt it is the speaker, have you tried switching the left with the right speaker?
Tallen234 is offline
post #2394 of 4924 Old 10-04-2011, 08:05 AM
Bill Mac's Avatar
Liked: 1856
I also highly doubt it is a speaker issue. As cuzzin posted once he sets the levels by ear the issue he reports is minimized. I really believe it is setting, room or the material used issue. Or it could be a combination of all three.
Bill
Bill Mac is offline
post #2395 of 4924 Old 10-04-2011, 08:10 AM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 817
I kind of wonder if the panning differences would be reversed if the sub was placed on the other side in a mirror image kind of configuration.
Chu Gai is offline
post #2396 of 4924 Old 10-04-2011, 09:53 AM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
As Dave is suggesting, a room gain issue with the lower frequencies could be throwing off the channel balance of the three front speakers. He could try level matching using a 1khz tone.
-curtis
cschang is offline
post #2397 of 4924 Old 10-04-2011, 10:19 AM
Bill Mac's Avatar
Liked: 1856
I think cuzzin should disconnect and remove the sub from its present location. I still feel that the sub is causing issues due to its size and location. Try running everything full range with Audyssey off and manually setting distance as well a speaker levels. Then see how it sounds.
Bill
Bill Mac is offline
post #2398 of 4924 Old 10-04-2011, 10:37 AM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 817
Yeah Bill, there's just something about how that sub is placed that looks out of place. Usually these things are easy to spot like when you're at the beach.
Chu Gai is offline
post #2399 of 4924 Old 10-04-2011, 01:33 PM
holt7153's Avatar
Quoted: 139 Post(s)
Liked: 221
Bill
Good idea, Bill. I would temporarily move the setup within the room or even to another room and see if the problem goes away. I've been following this issue since I saw the picture of his setup. I did a triple take as his rig looks frighteningly similar to my Sierra setup, except mine is 2.1.
And Chu's a chubby chaser--who knew?
Anything good in life is either illegal, immoral, or fattening.
holt7153 is offline
post #2400 of 4924 Old 10-04-2011, 02:10 PM
Bill Mac's Avatar
Liked: 1856
I love how the women in the "form" fitting black swim suit is giving the women in the blue one the evil eye. I always thought black had a way of making people look slim. I'm down to leaving all my shirts untucked as much as possible so I shouldn't talk.
Bill
Bill Mac is offline
Reply Speakers
Ascend Acoustics , Acoustics
