Bose cubes as surrounds with Denon Amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 05-22-2007, 03:03 PM - Thread Starter
89vette's Avatar
My old HT set up used white dual cubes as my surrounds with my fronts being Paradigm Cinema 90's with a Paradigm Center CC and PDR 10 sub. They worked OK and looked OK.
Now I am upgrading the HT room with a new panny 58" plasma, Denon AVR2807 Receiver, Paradigm Monitor 7 fronts and a CC290 center. I want to use my Cinema 90 fronts as my surrounds and (I have 7.1 now) and keep the Bose as my rear surounds.
I know Bose stinks but my question is I remember reading somewhere that Bose speakers are a different ohm rating and can damage amps. My old Kenwood amp had no problem but before I plug these things into the Denon, I thought I'd better ask.
89vette is offline
post #2 of 16 Old 05-22-2007, 08:49 PM
mannoiaj's Avatar
the denon should have no problem powering bose cube speakers.
mannoiaj is offline
post #3 of 16 Old 05-22-2007, 09:02 PM
Sirquack's Avatar
Denon's can drive audiophile 4 ohm speakers, there is no way a BOSE cube is going to even cause a Denon to break a sweat, especially for rears.
___________
"Don't worry about the future, it is already tomorrow in Australia..."
My Website
Sirquack is offline
post #4 of 16 Old 05-22-2007, 10:19 PM
ChrisWiggles's Avatar
You should be fine. However, the bose cubes are meant to be used with their acousticrap module that has the crossovers. You won't be able to do it properly without that, however, I figure the worst you could do is blow them which in any case is extremely unlikely to happen as rear backs as there is very unlikely to be enough low bass in those channels to really damage them.
I would suggest you try using the system in 5.1 and 7.1 and see which you prefer, they may be fine just to fill in to the rear, or you may prefer just to stick with the paradigms in a 5.1 array. But experiment to see.
ChrisWiggles is offline
post #5 of 16 Old 05-23-2007, 07:57 AM - Thread Starter
89vette's Avatar
Thank you for all the info. Actually I'm a bit confused as to what to do. With my old 5.1 system, the surrounds were mouted behind the listener on the ceiling pointed down. After reading my Denon AVR-2807 manual last night, I don't understand if I want to stay with 5.1 sound, would the rear speakers be surrounds L and R or surround backs L and R?
89vette is offline
post #6 of 16 Old 05-23-2007, 08:08 AM
EnzoPolotso's Avatar
If you're only going to use 5.1, use the normal surround outputs, not rear or surround back. Put them wherever you like though.
EnzoPolotso is offline
post #7 of 16 Old 05-23-2007, 08:28 AM - Thread Starter
89vette's Avatar
Thanks Enzo. I will use my rear speakers just as surounds and not use them for rear surrounds. That being the case, I have the option accordign to the manual to use the surround back speaker amps to wire my front Paradigm Monitor 7's in a bi-amp mode.
What is the reason to wire speakers in a bi-amp mode?
89vette is offline
post #8 of 16 Old 05-23-2007, 08:52 AM
True Fan's Avatar
To give more power to them (sometimes it goes along with the improved sound)
Listening to sound opinions, preferring sound of music ...
True Fan is offline
post #9 of 16 Old 05-23-2007, 08:59 AM - Thread Starter
89vette's Avatar
That is what I figured. I the Denon is rated at 110W per channel does that mean the speakers will have 220W going to them? I think they are rated to only 180W.
89vette is offline
post #10 of 16 Old 05-23-2007, 10:45 AM
You don't want to just put them wherever. You need to place them properly for the best results, according to dolby which is to the side.
post #11 of 16 Old 05-23-2007, 10:53 AM
huh
huh's Avatar
bose...
huh is offline
post #12 of 16 Old 05-23-2007, 10:56 AM
sdurani's Avatar
Quoted: 4476 Post(s)
Liked: 2896
Good point. However, if the satellites are going to be run through the bass module, then the exact same distance setting should be set in the receiver for both speakers (even if they are at different distances). Since the bass module sums the low frequencies, the last thing you want is two signals with different delays being combined (recipe for phase cancellations).
Sanjay
Sanjay
sdurani is online now
post #13 of 16 Old 05-23-2007, 11:36 PM
Luap's Avatar
If the Kenwood can handle it, the Denon can, but I suspect that the result may be worse than using 5.1 because the Bose can't really put out much volume or proper mid-bass or treble.
Luap is offline
post #14 of 16 Old 05-24-2007, 08:20 AM
lexa695's Avatar
I'd be more concerned with the sound quality of the cubes if you don't use the bass module. The cube is a single or in the case of double cubes, two drivers and that is it. All the electronics are in the bass module and I am sure there is something besides a x-over in it to give the cubes better sound.
OK, so why *again* do we need a bigger one?
lexa695 is offline
post #15 of 16 Old 05-25-2007, 03:49 AM - Thread Starter
89vette's Avatar
I ditched the Bose and put the Paradigms Cinema 90's back there. The mounted the ceiling with the brackets I used for the Bose just fine. So they are slightly behind and pointing down to the listener. I pick up the monitor 7's tonight.
89vette is offline
post #16 of 16 Old 05-25-2007, 04:03 AM
JRSUB's Avatar
I tried Bose cubes as surrounds. While they do make sound, it is not very good.
JRSUB is offline
Reply Speakers
