How do you DC-1 owners deal without component switching? - AVS Forum | Home Theater Discussions And Reviews
Old 12-24-2000, 09:47 AM - Thread Starter
Mane3215's Avatar
What do you guys use? I am looking into the dc-1 but i would really have liked to have the component video switching found on some higher end receivers. What do you guys do if you have the dvd/sat/hdtv? Thanks for the input.
Chris
Mane3215 is offline
Old 12-24-2000, 11:10 AM
Philip Brandes's Avatar
Very few of the receivers and pre/pros touting "component switching" capability have implemented the necessary bandwidth to pass HDTV signal without degradation. The top-of-the-line Denon 5800 will handle HDTV, and there might be one or two others--but most of the component-switching receivers are only useful if you plan to switch between two DVD players.
Most high-resolution displays accept multiple inputs anyway, and there are outboard switchers with sufficient bandwidth as well, so the pre/pro isn't a make-or-break factor. You are always better off running video sources directly into the display if possible, as this gives you the purest possible signal path.
Cheers,
Philip Brandes
Philip Brandes is online now
Old 12-24-2000, 11:26 AM
Craig Robertson's Avatar
page 23 of the Nov/Dec edition of The Perfect Vision has an informative article on the bandwidth issue that Philip mentions. the accompanying chart shows only 3 of the 23 listed rcvrs have sufficient bandwidth to handle HD, some don't even have enough to pass a progressive scan signal without degradation.
Craig Robertson is offline
Old 12-24-2000, 02:31 PM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
Cal audio labs video switcher the companion to the SSP-2500 has a bandwidth of 100mhz, three times the amount needed, for component switching but only has 2 component inputs. Cost a lot more than the Dc-1 though.
Never become so involved with something that it blinds you.
Bulldogger is offline
Old 12-24-2000, 04:55 PM - Thread Starter
Mane3215's Avatar
So say I do get a dc-1. How do I go about switching compnent inputs of the different sources i use say if i have only 1 component input on my monitor? How is it controlled if its a seperate switcher box? Also a little off subject what amps do you guys use with the dc-1? I would like to get a 7 speaker system.
Chris
Mane3215 is offline
Old 12-25-2000, 09:13 PM
Steve Dodds's Avatar
I use a pair of Fosgate 4200 four channel amps. These are basically rebadged Citation amps giving 125 per channel bridgeable to 250.
I'd agree with Philip's comments above though.
Steve
Steve Dodds is offline
Old 12-25-2000, 10:16 PM
Michael Lee's Avatar
Are those BNC connectors that I see on that Extron?
My Equipment List My DVD Collection
Michael Lee is offline
Old 12-25-2000, 10:21 PM
Chris
Hi Chris,
The DC-1 sound is very clean and neutral, so there is no need to think about needing a particular amp to compensate for the DC-1's coloration. Presumably Lexicon feels Bryston are a good match, since Lexicon's own amps are re-badged Brystons. However, this doesn't rule out any other competently designed amp. Your speakers are more likely to determine whether you want to bias the amp towards warm, dark, bright, or forward--but keep in mind that differences in well-designed amps are relatively small compared to other components. Price should be a significant factor here.
Good luck,
Philip Brandes
Old 01-06-2001, 10:47 PM
ggolamco's Avatar
Philip or Craig,
Was wondering if you could let me know if the B&K Ref30 (or the AVR307 if the article was just about receivers) was one of the few that could handle an HDTV signal without degradation.
Before you criticize someone, you should walk a mile in their shoes. That way, when you criticize them, you're a mile away and you have their shoes.
ggolamco is offline
Old 01-15-2001, 04:16 PM
Hugh Jackes's Avatar
Gelee says:
...I've never seen S-Video->BNC adapters...
Extron makes 'em. They're about 8 inches long, with a male mini-DIN on one end and two females BNCs on the other end. Extron's part # 26-353-01.
There is also a male-male, part # 26-353-02.
Hugh Jackes is offline
