Cheap Speaker Cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-27-2007, 04:40 PM - Thread Starter
yamahareciever's Avatar
I'm looking for some cheap speaker wire to use for some speakers. I heard that you could use lamp cord and get fairly good results. I went down to Home Depot and couldn't believe the price! It was 29 cents afoot for 16 gauge lamp cord and 27 cents a foot for 16 gauge speaker cable. Over $1 for 4 feet! Ridiculous. Any other cheap alternatives. I need about 200 feet of cable because I'm setting up a zone 2 from my A/V receiver and I need about 80 feet of wire per speaker but I figure I'll get extra in case of any obstacles.
yamahareciever is offline
post #2 of 6 Old 05-27-2007, 05:39 PM
ericgl's Avatar
Quoted: 25 Post(s)
Liked: 24
The price of copper is rising. Check monoprice.
ericgl is offline
post #3 of 6 Old 05-27-2007, 05:57 PM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Probably shouldn't use 16 gauge for an 80 foot span either...
psgcdn is offline
post #4 of 6 Old 05-27-2007, 07:48 PM
Sirquack's Avatar
If you think a buck for 4ft is expensive try buying monster.
___________
"Don't worry about the future, it is already tomorrow in Australia..."
My Website
Sirquack is offline
post #5 of 6 Old 05-27-2007, 08:58 PM
DonoMan's Avatar
http://www.americanthunderaudio.com/...spx?id=1394899
I use this. No-name but works fine. I'm not positive if it's really 12 gauge - my guess is yes - but I am positive it is at least close.
"Vintage" is good for wine, not for A/V equipment.
-Dan D.
DonoMan is offline
post #6 of 6 Old 05-27-2007, 09:37 PM
oztech's Avatar
Liked: 101
80ft run i would use 12awg
oztech is offline
Reply Speakers
