Swan Owner's Thread - Page 121 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #3601 of 3982 Old 03-08-2012, 10:07 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2015 Post(s)
Liked: 2184
Cleveland Plasma is offline
post #3602 of 3982 Old 03-08-2012, 10:48 PM
Khaos's Avatar
Originally Posted by Cleveland Plasma View Post
PM sent They are just flat out sick are they not ?
You were not kidding...xP
Kudos to swan.
Please tell me what happened in this night.
It's like the cat inside the box.
You don't know if the cat in the box is dead or alive.
The cat in the box was dead.
Khaos is offline
post #3603 of 3982 Old 03-09-2012, 05:56 PM
mykyll2727's Avatar
Chris_Thanks for the pics! Gorgeous speakers! Do you have any pics of the speaks from the rear?
mykyll2727 is offline
post #3604 of 3982 Old 03-09-2012, 07:18 PM
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1038
I am between the Swan 6.1 or 6.2 and also the Audio Monitor RX6 Silver! Any thoughts?
Reefdvr27 is offline
post #3605 of 3982 Old 03-10-2012, 11:07 AM
Reefdvr27's Avatar
Liked: 1038
Bump!
post #3606 of 3982 Old 03-10-2012, 12:17 PM
roadster-s's Avatar
Quoted: 22 Post(s)
Chris, is that a flared front firing port at the bottom? Those cabinets really look like Usher's Dancer series...
Next best thing to my F2.2's
Go topless.
roadster-s is offline
post #3607 of 3982 Old 03-10-2012, 01:49 PM
Jon Lane's Avatar
Quoted: 97 Post(s)
Liked: 375
First, compare class-for-class: Add up cone area and determine if you're looking at a 2, 3, or even 4 way.
Second, if I can help define the Divas, drop me an email or PM. I was involved with the development of both series.
Jon Lane is offline
post #3608 of 3982 Old 03-10-2012, 05:34 PM
Reefdvr27's Avatar
Liked: 1038
PM Sent!
post #3609 of 3982 Old 03-26-2012, 02:58 PM
MrEastSide's Avatar
Quoted: 25 Post(s)
Liked: 55
I'm looking at buying a set of the Diva 6.1. My question is regarding the cabinet. Is there a quality difference between the Rosewood and the Black Cherry as far as sound quality goes?
Of course, I got it modified with the TK-427, which cheeks it up another, maybe, 3 or 4 quads per channel.
MrEastSide is offline
post #3610 of 3982 Old 03-26-2012, 03:14 PM
EJ
EJ's Avatar
None. I've heard from the experts that there's none.
I have the 6.1s in rosewood, my Dad has the BC. We ran them side-by-side, and they both sounded great.
Former USSB uplink operator.
EJ is offline
post #3611 of 3982 Old 03-26-2012, 03:22 PM
MrEastSide's Avatar
Quoted: 25 Post(s)
Liked: 55
I wouldn't think there would be, but I wasn't sure if it was made out of the exact same material, or if different material would produce a different sound.
post #3612 of 3982 Old 03-26-2012, 10:30 PM
sfeldman721's Avatar
What brand amp or av receiver do you all use to drive your Swans?
sfeldman721 is online now
post #3613 of 3982 Old 03-26-2012, 11:28 PM
EJ
EJ's Avatar
Having my diva swans for 9+ years, (Way back when [a v 1 2 3 . c o m] was the dealer), I've driven them with a Denon 3802, 3805 and currently an Onkyo HT-RC360. All midrange receivers, and all seemed to have plenty of power.
EJ is offline
post #3614 of 3982 Old 03-27-2012, 08:42 AM
Khaos's Avatar
For my Swan T900F's I drive them with a XPA-2/UMC-1 combo.
Amazing sound, plenty of headroom.
Khaos is offline
post #3615 of 3982 Old 03-27-2012, 05:37 PM
MrEastSide's Avatar
Quoted: 25 Post(s)
Liked: 55
So, I'm pretty sure I will pull the trigger on the 6.1 towers and matching center channel. I would like to ask though, what exactly is up with the coating on the mid-range driver on the center channel speaker? I see from the description it says "soft-cloth" mid-range. I've never heard of such a thing. And it looks like it's coated in a thick tar. It's not very attractive looking. Not that looks are what matter when it's behind the grille. But, the mid-range just looks kind of junky and cheap to me. Just curious...
post #3616 of 3982 Old 03-27-2012, 05:40 PM
Khaos's Avatar
http://www.swanspeaker.com/product/htm/view.asp?id=37
(Picture from my T900F)
It's a soft dome, similar to how a tweeter is made.
http://www.parts-express.com/pe/show...number=297-415
Khaos is offline
post #3617 of 3982 Old 03-27-2012, 08:34 PM
gene c353's Avatar
Quoted: 139 Post(s)
Liked: 99
My Swan 5.1 tower (the 6.1's little brother) also uses this mid-range. It's a quality piece.
gene c353 is online now
post #3618 of 3982 Old 03-27-2012, 08:36 PM
MrEastSide's Avatar
Quoted: 25 Post(s)
Liked: 55
^ Thanks for the info. Just seemed kind of odd looking, having that look of an un-smoothed coating on there. Seems like people on parts express like it though!
Also, how come the center channel uses a 6ohm configuration? Most centers I have owned run 8ohm, just wondering if there is a particular reason.
post #3619 of 3982 Old 03-27-2012, 08:56 PM
Khaos's Avatar
http://www.swanspeaker.com/products/...sid=54&pid=179
The midrange driver demands a 5-6ohm load around the 1-5khz range. Even though its a combo plate, each driver is separate.
Nominal Impedance (Z)(Ω) 6
Khaos is offline
post #3620 of 3982 Old 03-28-2012, 03:32 AM
MrEastSide's Avatar
Quoted: 25 Post(s)
Liked: 55
^^^ I appreciate the info. I may just go ahead and pick some of these up. They do look to be quite fantastic speakers!
post #3621 of 3982 Old 03-28-2012, 08:13 AM
leger433's Avatar
I use a Marantz receiver to drive my RM600s. I thought long and hard about going with a separate amp but spent money on a receiver with a decent amp section and pre-amp outputs for the option to upgrade later. However, I have not come close to hitting the amplifiers limits and do not see the need to go separate anytime soon for my purposes. The RM600s are also not the most sensitive speakers (89dB) and rated at 4 ohms nominal. I think swans are generally rated a bit conservative. More specifically the nominal rating is often close or at the minimum impedance seen across the frequency range. I have seen other speakers rated at 4ohms that drop to 2 ohms or less at certain frequencies.
leger433 is offline
post #3622 of 3982 Old 03-30-2012, 11:08 PM
Bernie7's Avatar
I use custom built Class D (IRS2092) monoblocks for my F2.2s. ARC's current Class D line uses IRS2092 as well.
Bernie7 is offline
post #3623 of 3982 Old 03-30-2012, 11:11 PM
Bernie7's Avatar
Hi leger
Did your RM600 come with additional wood base fitted with tiptoes?
Bernie7 is offline
post #3624 of 3982 Old 04-01-2012, 05:42 AM
Tokfan's Avatar
Hi there,
My first post on AVS forum
I just bought a set of 6.3HT and a sub 10D, i was wondering whats the best placement for the 6.3R speakers? I'm planning on mounting them on the sidewall, 1-2 feet above the sofa and maybe a a foot infront of the sofa as well. The DynaVoice "surround" won't be there when I've mounted the 6.3r speakers of course.
Please see the link for further explanation.
Tokfan is offline
post #3625 of 3982 Old 04-01-2012, 05:54 PM
leger433's Avatar
Originally Posted by Bernie7 View Post
Hi leger
They came with two sets of feet that screw into the cabinet. One set that are flat and a set of spikes for carpet. I'm using the latter. Metal threaded if I recall correctly.
leger433 is offline
post #3626 of 3982 Old 04-08-2012, 01:16 AM
avsbob123's Avatar
How does Swan M200 MKiii compare to "Dali Lektor 2 bookshelves with a Marantz 6004 amp" ?
avsbob123 is offline
post #3627 of 3982 Old 04-10-2012, 10:08 PM
sac8d4's Avatar
6moons has a new review up on the M6 http://www.6moons.com/audioreviews/swans3/1.html
"Without music life would be a mistake." -Friedrich Nietzsche
sac8d4 is offline
post #3628 of 3982 Old 04-11-2012, 02:35 AM
mykyll2727's Avatar
Thanks for the link!!
post #3629 of 3982 Old 04-17-2012, 08:51 PM
Khaos's Avatar
I agree with them 100% about the positioning. I found for my room that the T900's sounded best about 8ft apart and the listening position about 6.5-7ft away, with a slight toe in.
My room is 12ft x 12ft, 8ft high.
Great review! Really enjoyed the read. xP
Khaos is offline
post #3630 of 3982 Old 04-28-2012, 11:07 AM
Speqtre's Avatar
For Jon Lane or Cleveland Plasma:
Helping a friend buy a set of used F2.2HT:
Is the warranty transferrable to a new owner, and if so, how long is it? Current owner bought from a now-defunct dealer here in Virginia about 3 years ago, and can't find his receipt. Would the serial number be of any use?
Speakers look great and sound fantastic, but she's a little leary dropping that much cash with no recourse if there's issues.
Speqtre is offline
Reply Speakers
Oppo Dv 981hd Universal Dvd Player With Hdmi 1080p Up Converting Divx Sacd , Samsung Lns4096d 40 Inch Lcd Hdtv
