Red/Black - positive or negative... help hooking a speaker up - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-18-2007, 09:13 AM - Thread Starter
steveklein's Avatar
so i just got my brand new speaker set from ascend acoustics and was wondering how to hook it up with respect to my reciever, an onkyo tx-sr674.
each of the ascend speakers has 2 places for the speaker wire to go, one is red and one is black.
do these colors represent a (+) or (-)?
on my receiver i have (+) and (-) clearly labeled and want to make sure i feed the right split of the speaker wire into the right hole. which is which?
steveklein is offline
post #2 of 5 Old 06-18-2007, 09:15 AM
wahoodude23's Avatar
It should label + or - in addition to the colors but if you have an onkyo... if the 674 is like the 604 then black is alway (-). Other colors like red, brown, purple are (+).
*wahoo
wahoodude23 is offline
post #3 of 5 Old 06-18-2007, 09:26 AM - Thread Starter
steveklein's Avatar
right... the + and - is clearly labeled on the onkyo, but not on the speakers.
is black always (-) on the back of speakers?
post #4 of 5 Old 06-18-2007, 10:20 AM
DonoMan's Avatar
black is always - (unless perhaps all connectors are black)
"Vintage" is good for wine, not for A/V equipment.
-Dan D.
DonoMan is offline
post #5 of 5 Old 06-18-2007, 10:33 AM
Ron Alcasid's Avatar
It doesn't matter just be consistent with your connections. If you connect the + to the red terminal and - to the black terminal on one speaker, do the same for all speakers.
Ron Alcasid is offline
Reply Speakers
