Definitive Technology ProCinema Series 600/800/1000 (or 60/80/100) Thread - Page 202 - AVS Forum | Home Theater Discussions And Reviews
 24Likes
post #6031 of 7641 Old 05-10-2012, 06:50 AM
Joe@Definitive's Avatar
Originally Posted by toddRiffic View Post
Thanks Joe, any and all input is appreciated. I'll be making my choices at the builders design center in a few hours. I'm usually a bigger advocate of moving the speakers and listening for yourself in the space they're going to be used in rather than strictly adhering rules of thumb. So this will be a bit of a leap of faith.
I will have conduit used as much as budget allows. I assume the larger diameter the better. I will have them add enough slack to the runs for the tower speakers so if I decide to run wire higher up the wall for the pm1000's, I can easily do so.
You are Toddriffic! Yes, rules of thumb are really just guidelines when it comes to this sort of thing. Trying it out is the best way...but sometimes, you have to make a leap of faith. Good luck and let us know how it goes. Best, Joe
Joe@Definitive is offline
post #6032 of 7641 Old 05-10-2012, 06:54 AM
Originally Posted by pleibowitz View Post
Hi Joe, For the most part I'm satisfied with the ProCinema 800 especially for movies. When it comes to music I feel that it sounds a bit hollow, and doesn't quite fill the room. I've gone on the Denon forum for my receiver (I have the AVR 1912) and made suggested adjustments for music which has helped. The other part to this is from reading the forums I've begun to question whether I properly sized the system for the size room it's in 26x14.5 with 7.5ft ceiling. I'm new to all of this and have begun to hit the forums to learn as much as I can. I thought I did my homework prior to making my purchase but now feel based on my readings that might not be the case in terms of the room size.
Hello Ple, yes, that's a large room, and of course we make much bigger (and costlier) products partly because it's harder to fill a larger space. A dorm room is easier to fill that a finished basement, for sure. The 1000's go a little lower in the mids for a better blend with the bottom end than the 800's can. Also, a second subwoofer can make a massive difference in the bottom end, and even the mid-bass, if it is dialed in correctly.
I hope this helps - best, Joe
post #6033 of 7641 Old 05-10-2012, 11:01 AM
toddRiffic's Avatar
Quoted: 22 Post(s)
Liked: 36
+1 on running two subs. They make made more of an impact for me then upgrading to towers or extra surrounds. Highly recommended.
toddRiffic is offline
post #6034 of 7641 Old 05-24-2012, 07:23 AM
denguz's Avatar
I would first confirm if you only notice the issue when watching movies with your bluray player vs cable/sat box. They key to troubleshooting is isolation.
I finally did more listening and determined that the sound fading in and out happens on either watching Blu ray or DVD and watching regular cable tx programs. I have the volume a lot higher on movies and thus I notice it more. I checked all cables HDMI and speaker cables and all seem to be firmly plugged in.
Has anyone have any advice for troubleshooting? I will post similar to the Denon AVR board as to me it may be the culprit
denguz is offline
post #6035 of 7641 Old 05-24-2012, 10:57 AM
toddRiffic's Avatar
Quoted: 22 Post(s)
Liked: 36
Is the fade like the volume goes up and down a bit, or does it completely cut out?
post #6036 of 7641 Old 05-25-2012, 04:42 AM
denguz's Avatar
It seems like volume is cutting out completely for a second and then come back on.
I posted on the Denon forum and someone mentioend could be a HDMI handshake issue. I currently have all devices plugged in to the AVR and using ARC feature. I have set the Dynamic volume to OFF to see if that does anything
denguz is offline
post #6037 of 7641 Old 05-25-2012, 06:15 AM
Hello Denguz, as Todd mentioned, the key to troubleshooting is isolation. But it sounds like you are having this issue of volume cutting out on almost any source. It may be an HDMI issue. Are you using high speed HDMI cables? They aren't really "faster" but can handle more data. You might also try Denon's tech support or see if their site has an FAQ section. Good luck and let us know how it goes - best, Joe
post #6038 of 7641 Old 05-25-2012, 08:48 AM
toddRiffic's Avatar
Quoted: 22 Post(s)
Liked: 36
I've had zero trouble with $3 HDMI cables from amazon with my Denon 1909, but my father has issues with his newer Onkyo avr. AVS member Batpig is the resident Denon guru, he may be able to help. If you haven't done so, check out his "Denon to English dictionary" I would use rca/optical/digital coax for your audio connection to further confirm you have a HDMI issue.
post #6039 of 7641 Old 05-26-2012, 09:51 AM
toddRiffic's Avatar
Quoted: 22 Post(s)
Liked: 36
Good HDMI cables are a must for long runs. In the instance of short runs and multiple sources having the same issue I would tend to not suspect the cables so much. But I've been wrong at least a couple times in my life.
HDMI can be tricky in my experience. I have three Sony bluray players and my new one that's a few months old is the only one that I ever experience a occasional audio and video drop out. The oldest one it replaced never had the issue with the same cables and connected equipment. Hopefully the newest firmware I saw available yesterday will resolve the issue.
Side note: Sad day, I packed up 10 DT's and 2 subs not to be heard from again for 2-3 months while I wait at the in-laws place for the new house to be finished. Of course if Joe and the other good people at Definitive would like to send a temporary care package of the new studio monitors to swap out for my father un-law's PSB's I would be very grateful!
post #6040 of 7641 Old 05-29-2012, 07:51 AM
Good one Todd! Patience, patience...
post #6041 of 7641 Old 06-01-2012, 08:49 AM
pleibowitz's Avatar
Just curious, does any one know if Definitive Technology is discontinuing the Procinema line? I went on to Newegg.com this morning and the Procinema 800 pkg was "deactivated" on their online catalogue with the message, "the item is currently out of stock, and may or may not be restocked".
pleibowitz is offline
post #6042 of 7641 Old 06-02-2012, 11:35 AM
W2GOD's Avatar
Ok this is a rookie question I have a 7.1 setup . I have 6 DEFTECH 1000's. Center is a pro2000. Sub is a prosub1000. Now I want to make sure my speaker setup is right . During a movie that is only played in 5.1 . I notice that sound does not come out from the surround back left and the surround back right . and does come from the surround left and surround right and of course the front left and right and center and sub are fine . now I know it's not using all 7 speakers because if it's only using 5.1 soundtrack but I want to make sure this is correct or in a 5.1 sound track should it use the surround back left and surround back right. And the left surround and right surround have no audio . I wanna make sure I put my speaker wires in the right inputs on the receiver . thanks
W2GOD is offline
post #6043 of 7641 Old 06-02-2012, 04:11 PM
rdclark's Avatar
Quoted: 348 Post(s)
Liked: 651
In 5.1, the channels are L, C, R, surround L and surround R. The "Back" or "Rear" (or "front height" or "front wide") are the channels added for 7.1.
Usually in your setup you would use Dolby ProLogic IIx. In a 7.1 movie this will put all channels to the correct speakers. In a 5.1 movie the receiver will create matrixed sound for the "back" channels so they are not completely silent. I think you'll find that this is most people's default configuration.
Wide Awake
on the Edge
of the World
rdclark is offline
post #6044 of 7641 Old 06-02-2012, 05:20 PM
W2GOD's Avatar
Thank you !!!! So I got it right lol, thanks for the info I thought I was doing something wrong!!!!
W2GOD is offline
post #6045 of 7641 Old 06-04-2012, 07:47 AM
Hello Ple, the ProCinema 800 series absolutely is current and continuing! We sell loads of them - which goes for the rest of the ProCinema series too. We do however sell them to dealers as either a fully packaged system, or as individual parts and pieces. Sometimes folks want bigger L&R, or a better sub (or twin subs), etc. So maybe they are discontinuing the package and will offer it as separates. Best, Joe
post #6046 of 7641 Old 06-06-2012, 10:38 AM
ben_r_'s Avatar
On that note I will say I upgraded my the ProMonitor 800's I was using for L and R in my office surround sound system to the ProMonitor 1000's and it was a considerable improvement in sound. So much so that Im considering upgrading my ProCenter 1000 to the 2000 as well in that room.
ben_r_ is offline
post #6047 of 7641 Old 06-12-2012, 04:06 PM
DenonRCDN7Owner's Avatar
On this note - I have been wondering if we would see an update to the ProMonitor 1000 & 800 speakers to match the form factor of the new ProCinema 400 series. Any insights?
DenonRCDN7Owner is offline
post #6048 of 7641 Old 06-13-2012, 05:15 AM
Raym1234's Avatar
I will be using a new AVR that has Audyssey XT32 with my ProCinema 80 system. What volume level and crossover point should I initially set the sub to before running the Audyssey setup? Also, should I use the sub's L/R inputs or the LFE input? Thanks in advance to the forum members for any guidance you can provide this relative newbie.
Raym1234 is offline
post #6049 of 7641 Old 06-13-2012, 07:32 AM
Hello Den, at present we are not planning any changes to the ProCinema 800 / 1000 series. They are really selling well and, I think, represent great value in the category. We are hot after a couple of new things in other areas though... so stay tuned! Best, Joe
post #6050 of 7641 Old 06-13-2012, 07:42 AM
Hello Raym,
I am glad you have the ProCinema 80 system. If you use the LFE input on that system you will not have to worry about crossover point, as the LFE bypasses the crossover inside the sub. Even if you use the L/R we urge you to take the crossover all the way up to 150 in order to get it out of the way of your receiver's crossover. The sub crossover settings are really there for a 2 channel set-up in which the receiver or amp has no crossover. I hope this helps! Best, Joe
post #6051 of 7641 Old 06-15-2012, 02:02 AM
Raym1234's Avatar
Thank you, Joe, for this information. Do you have any suggestions what gain (volume) I should set the sub to prior to starting the AVR setup?
Raym1234 is offline
post #6052 of 7641 Old 06-15-2012, 07:49 AM
Hello Raym, good question, and I see that I missed it before. Sorry about that. The key is to have the subwoofer up high enough to where the auto-on function works every time. I suggest you start at 12:00 on the clock face (or half-way up). Some folks try turning the sub virtually all the way up, and the receiver responds by setting the sub level to minus 12 or 15. So then the sub's level is low enough that auto turn on doesn't work consistently. Oops! I hope this helps - best regards, Joe
post #6053 of 7641 Old 07-01-2012, 06:41 AM
zibanez's Avatar
Quoted: 36 Post(s)
Hi guys, Just got my procinema 600 , all the way from USA to Indonesia. And thanks God, when I open the box, makes setup and YES its working!!
Right now . i'm still trying to set the crossover same problem with Raym123. BTW i'm using Marantz NR 1402 for receiver. Is there any recommendation crossover setting for pro cinema 600 set up?
Thank for advice
Bedroom theater
Dynaudio DM 2/6 - Dynaudio DM Center - Def tech pro monitor 600 - Rythmik Audio CI 15" HP600 - Marantz NR1402 - Bantam Gold Power Amp - Clark Synthesis tst 239 - Dune H1 - PS3
zibanez is offline
post #6054 of 7641 Old 07-01-2012, 11:13 AM
Raym1234's Avatar
I set up my new receiver using Joe's recommended settings for the sub (i.e, used the LFE input which bypasses the crossover and set the volume at the 12 o'clock position). The receiver set itself up without any problems and the sound is fantastic.
Raym1234 is offline
post #6055 of 7641 Old 07-02-2012, 06:28 AM
Thank for advice
Hello Zibanez, did the response I gave Raym make sense or help you? If you can be more specific with your question I am glad to help. Best regards, Joe
post #6056 of 7641 Old 07-02-2012, 10:23 PM
zibanez's Avatar
Quoted: 36 Post(s)
Yes, I've tried and the result still not good enough. So i fine tune it manually based on the receiver set. And right now this is my crossover setting :
Front 90Hz
Center 150Hz
Rear 90HZ
Next problem is Bass Management on my receiver. Right now for Bass Management setting ,i'm choosing LFE+main and LFE at 120HZ
Is it right ? or maybe you got any recommendation Joe?
FYI I'm using method 1 for Speaker connection with speaker configuration on receiver, Large front, small center, small rear, and subwoofer
Bedroom theater
zibanez is offline
post #6057 of 7641 Old 07-03-2012, 07:52 AM
Front 90Hz
Center 150Hz
Rear 90HZ
Hello ZiIbanez, the 90 Hz crossover points make sense to me, although our customer service gents suggest that 120 may be better. If you like the sound at 90, great.
The 150 Hz crossover point seems a bit high for the center. Have you also tried it at 120? If it sounds better to you at 150, fair enough.
LFE at 120 is also just about right. I hope this helps - best, Joe
post #6058 of 7641 Old 07-03-2012, 11:06 PM
zibanez's Avatar
Quoted: 36 Post(s)
Ok, i'll try your suggestion. BTW, should I set the crossover again if change my speaker connections?
Example : from method 1 to method 1 with optional hooks up or from method 1 to method 2
Bedroom theater
zibanez is offline
post #6059 of 7641 Old 07-05-2012, 09:45 AM
Hello Z, yes, I would try it again if you change speaker connections. Not sure why you'd do that, but it always makes sense to try more than 1 crossover point. Thanks again for owning DT - best, Joe
post #6060 of 7641 Old 07-05-2012, 08:34 PM
zibanez's Avatar
Quoted: 36 Post(s)
I'm just curious Joe : ). Thanks for the response Joe. And right now I already got the sweet spot for crossover. I hope in the future there will be International Distributor for Def Tech product in Indonesia. So i don't have to ordered from US again. I'm very satisfied for Pro Cinema 600.
Bedroom theater
zibanez is offline
Reply Speakers
Definitive Technology Procinema 600 5 1 Speaker System , Definitive Technology Procinema 1000 5 1 Speaker System , Definitive Technology
