Definitive Technology ProCinema Series 600/800/1000 (or 60/80/100) Thread - Page 247 - AVS Forum
 8Likes
post #7381 of 7402 Old 12-13-2014, 02:28 PM
sqa4life's Avatar
Liked: 36
Wondering if the studio monitor 350's are any better than the PM1000's?
So tempting to get a pair of 350's from Newegg for $180 to complete my 7.1
I have the following now:
2 PM1000'S front
PC2000 center
SR-8040BP's surround
Supercube 2000
Yamaha RX-A2000
If I get the 350's, then I'll move the PM1000'S to surround L/R and use the 350's as front L/R.
Is that a good setup?
sqa4life is offline
post #7382 of 7402 Old 12-13-2014, 04:48 PM
ALtlOff's Avatar
Quoted: 93 Post(s)
Liked: 27
2 PM1000'S front
PC2000 center
Supercube 2000
Yamaha RX-A2000
Yes, the SM350's larger bass radiator will give you a fuller sound, but if it were me I'd move the 1000's in the rear and leave the 8040's as surrounds, the wider dispersion should work better as surrounds and use the narrower 1000's in the rear.
sqa4life likes this.
*Warning* None of my suggestions, ideas or even thoughts have any WAF, in any way!
My Build Thread:
http://www.avsforum.com/forum/15-gen...formation.html
ALtlOff is offline
post #7383 of 7402 Old 12-13-2014, 07:55 PM
swallan's Avatar
the sm350s make good front speakers for the price,we had the sm350s for our fronts with the clr2002 center for about 10yrs.
swallan is offline
post #7384 of 7402 Old 12-13-2014, 10:33 PM
sqa4life's Avatar
Liked: 36
They also have a pair 450's for $250, not sure if which pair to choose
sqa4life is offline
post #7385 of 7402 Old 12-14-2014, 06:22 AM
ALtlOff's Avatar
Quoted: 93 Post(s)
Liked: 27
Easy, 450's over the 350's, the 450's will be as much or more of an improvement as the 350's over the 1000's, and are absolutely worth the extra cost.
The 450's are probably as close to going to a tower front as you can come if that tells you anything as to how good they are, and yes they will still match up with your PC2000.
One thing about both the 350's and 450's, don't forget the radiators are on the sides instead of on top like the 1000's, so they need to be in a more open space and not in a hole in a cabinet, or too confined on the sides, this will make a "Big" difference in their fullness, richness and imaging.
My Build Thread:
ALtlOff is offline
post #7386 of 7402 Old 12-14-2014, 08:50 AM
thejez's Avatar
thats interesting. I am looking at possibly picking up some DefTechs for my house and found this thread. You guys are saying that the PM1000's which are $440 a pair are worse than the 350's which are $180 a pair? Is the price difference because the 350's are discontinued?
thejez is offline
post #7387 of 7402 Old 12-14-2014, 09:20 AM
swallan's Avatar
when we bought our sm350s around 10yrs ago they retailed for 500 dollars for the pair,i think they are real good speakers for the price.
swallan is offline
post #7388 of 7402 Old 12-14-2014, 10:49 AM
ALtlOff's Avatar
Quoted: 93 Post(s)
Liked: 27
Basically yes, honestly I wouldn't really put it as worse, just not as good in the lower frequencies and in fullness, the 1000's were designed to be used with a Sub more than the Studio Monitors were.
And yes, they did retail for more when they were a new product.
My Build Thread:
ALtlOff is offline
post #7389 of 7402 Old 12-14-2014, 11:06 AM
LowellG's Avatar
Quoted: 167 Post(s)
Liked: 114
I owned the 350s at one time and they are better as described above than the 1000s, but if space is an issue, the 1000s will work. Also, Bajawaverunner as 1000s for $220 a pair on Ebay.
Lowell
The MARVELous Home Theater: http://www.avsforum.com/forum/19-ded...e-theater.html
LowellG is offline
post #7390 of 7402 Old 12-14-2014, 11:11 AM
sqa4life's Avatar
Liked: 36
Thank you
I pulled the trigger on the 450's
Will need to find a pair of stands
sqa4life is offline
post #7391 of 7402 Old 12-14-2014, 11:14 AM
sqa4life's Avatar
Liked: 36
Agreed. My PM1000'S sounds great on movies and music and because the supercube 2000 put out over 600 watts
Sometime we sing karaoke (when drunk) too, so, the 450's will help, I guess.
sqa4life is offline
post #7392 of 7402 Old 12-14-2014, 11:17 AM
sqa4life's Avatar
Liked: 36
And you better act fast before the price goes back to normal or they run out of stocks, if you decide to go for either the 350's or 450's
sqa4life is offline
post #7393 of 7402 Old 12-14-2014, 03:59 PM
steveting99's Avatar
Quoted: 404 Post(s)
Liked: 136
Thank you
If you can get another SM450 for the center speaker, that would make a good sound stage with identical left, center and right.
Maranatz NR1504, Oppo BPD-93, MTV 7000D, LG LW6500, aTV, WDTV Live, Harmony 650 remote, KEF E301, MiniDSP(2x4), Rythmik F12G
steveting99 is online now
post #7394 of 7402 Old 12-15-2014, 03:02 PM
Liked: 0
I have a PM1000 (front L/R) and PM800 (rears) setup with procenter 2000. Considering buying SM450s for the front - will be moving PM1000s to the rear and PM800s to front-height. Can't go with 4 rear speakers due to (lack of) existing wiring.
I have seen some SM450 reviews saying that these speakers are tough to drive in spite of them being 90db. Can someone please share the experience. I have Denon AVR-e400 A/V receiver. Thanks.
pmat123 is offline
post #7395 of 7402 Old 12-15-2014, 03:36 PM
AlexanderDelarg's Avatar
Quoted: 38 Post(s)
Liked: 64
I have read on here others using the SM450's in a similar set up and liking the results. I almost went with the same set up but needed to wall mount everything due to children. I say go for it.
Epson Pro Cinema 6030 | OPPO BDP - 103 | Pioneer Elite VSX 70 | Definitive Technology PM 1000 (L/R) | PC 2000 (C) | SR8040BP's (7.1) | Rythmik LV12R | Carada Criterion Brilliant White 118" | URC MX 780 & MRF 350 | ATS Acoustic Panels | Sanus AV Rack | DirecTv | Roku 2 | Monoprice 12AWG |
AlexanderDelarg is offline
post #7396 of 7402 Old 12-16-2014, 07:39 AM
Quoted: 404 Post(s)
Liked: 136
pmat123,
A lot will depend on your room, the speaker layout and how far away you plan to sit from the speakers. If you're going to listen at very loud levels, then consider sitting closer to the speakers in a nearfield listening position. It would take maybe 1W to 6W to reach very loud levels. The further you sit away from the speakers, the more power is needed. Speaker power rises exponentially. If you're thinking of a 5.1.2 Atmos setup, the recommendation is to go with a pair of top middle or Atmos enabled up-firing speakers where the front left and right speakers are at. You will need a new receiver to decode the Atmos soundtracks or up-mix existing formats to Atmos configuration.
post #7397 of 7402 Old 12-16-2014, 11:57 AM
Liked: 0
Thanks Steve and Alexander. I am not planning to go for atmos as it will be significant investment. Just felt the itch to use the remaining two speaker outputs of my 7.1 receiver. My receiver has an option to do front heights (Dolby plz) instead of adding a pair of rear speakers. MLP for me is ~11 feet from the front speakers and my room is 14x16x8. HT usage is 90% movies and 10% music.
I am very happy with Promonitor 1000s (front) that I have since last couple of months. I have cranked them to ref level while watching some action movies - and they don't disappoint. Perhaps I should keep the upgrade bug under control for at least next 2-3 yrs and then think about getting a pair of SM65s . I currently have one PL200 sub that throws good bass for movies - will look towards adding one more sometime next yr.
pmat123 is offline
post #7398 of 7402 Old Yesterday, 02:21 PM
de8212's Avatar
Quoted: 83 Post(s)
I've been considering replacing my JBL satellite speakers for years. Unfortunately other things take precedence and I haven't been able to do so.
Anyway, the front runner was the pro monitor 800 speakers because they are similar sized to what I have. The more research I did I then started to consider stepping up to the pro monitor 1000's (just for the front L & R). Now, I'm seeing talk about StudioMonitor 350's. They seem kinda close in size to the PM1000s, aren't they?
Then one issue is I have some of the wall mounts similar to these
I think they might work with the pm1000's but I can't imagine them holding up the sm 350's. And there's no similar hole in the back of the 350's unless the picture I found online was wrong.
So, are the 350's that much better than the pm 1000's? And where are people finding them for 180/pr?
Unfortunately my setup just isn't good for bookshelves. And alot of you probably would never even encourage any speakers to be mounted where I have them.
Any suggestions?
de8212 is online now
post #7399 of 7402 Old Yesterday, 03:37 PM
ALtlOff's Avatar
Quoted: 93 Post(s)
Liked: 27
Any suggestions?
The larger bass radiator in the 350's give them a fuller and richer sound than the 1000's, and IMO sound considerably better.
The back the speaker looks like this:
So it can be mounted on the wall, if you get a pair without the keyhole plates, you can get some from DefTech, Chet just sent me some at no cost.
There's a used pair on E-Bay right now for $160 and regularly no more than $225, you just have to keep an eye out.
My Build Thread:
ALtlOff is offline
post #7400 of 7402 Old Yesterday, 04:29 PM
de8212's Avatar
Quoted: 83 Post(s)
After looking at the dimensions again I noticed the 350's are ~3" deeper. In my setup, I'm not sure how ~9.5" will look sticking out from the wall. Also, the keyhole plate would be great but then again, in my setup, it would not be pointing anywhere near the MLP.
i didn't know the deals on these were used/ebay. It's not a huge deal but I was thinking they were new.
The other option might be to run some new wires and put the 350's to the sides of the fireplace and use my existing JBL's as front height speakers (I think that's what they're called). I don't particularly want to do this but it is an option.
Just not sure what to do...
post #7401 of 7402 Old Yesterday, 06:29 PM
Quoted: 404 Post(s)
Liked: 136
The other option might be to run some new wires and put the 350's to the sides of the fireplace and use my existing JBL's as front height speakers (I think that's what they're called)...
This would work.
Hook up the front mains consisting of font left and front right to the side of the TV. Ideally you'd like to have the center speaker as the same as the front left and right, placed below the TV - no more than 2' vertical distance. If all are the Def Tech SM350 this would be a good match. Check the angles to the Main Listening Position (MLP) are between 22 deg to 30 deg (equilateral triangle arrangement is better). You can use the following wall mounts: http://www.amazon.com/dp/B000X9O8SI/...=I9JGQ03P8J8LO for the SM350.
Te existing JBL's can be utilized as heights - be sure to toe them into and angle them into the MLP. Check you receiver has the ability to front heights such as Yamaha's receivers which define them as 'presense' speakers. Other receivers will define them as Dolby PLIIz, DTS NEO:X, Audyssey DSX, etc. Use the receiver's room correction to equalize the sound field.
Your surrounds can also be kept as is with the existing JBL's. The only thing you would have lying around is a spare center speaker from JBL.
post #7402 of 7402 Old Today, 06:33 AM
de8212's Avatar
Quoted: 83 Post(s)
Originally Posted by steveting99 View Post
This would work.
Well, not now it won't.
Talked to the wife again last night and kinda showed her my ideas and she wasn't thrilled about having such large speaker protruding out of the wall or even on stands.
SO, I guess the best I can do is upgrade to the PM800 or PM1000's and a PC2000. I'm sure it will be a drastic improvement and maybe I can find some 1000's for a good price over the next month or two.
Reply Speakers
Definitive Technology Procinema 600 5 1 Speaker System , Definitive Technology Procinema 1000 5 1 Speaker System , Definitive Technology
