Definitive Technology ProCinema Series 600/800/1000 (or 60/80/100) Thread - Page 252 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
Old 12-24-2015, 10:59 AM
Daryl L's Avatar
Quoted: 276 Post(s)
Liked: 162
I just upgraded to a 5.1.2 Dolby Atmos system layout with the Denon receiver. My side surround speakers are dipole speakers that I've been using for years for surround. I understand dipole speakers are not a good choice for surrounds in an Atmos set up due to their negative impact on the up firing Atmos add-on modules performance. I've decided to replace them with some direct firing speakers. Due to my room layout and doors and wall shelves my choices are pretty limited to the speakers I can use to replace my current surrounds (it's a size location thing). I've been looking around and ran across the Promonitor 800s that seem to fit the bill due to their small size.
My question is do you think these speakers could perform okay handling a frequency down to 80hz? I notice that Definitive Technology has a recommended A/V receiver crossover setting of 100hz even though their frequency range is listed at 57 Hz - 30 kHz. I'm aware that measurement is measured in and an anechoic chamber setting as opposed to an average room at home. Any information you can provide is appreciated.
Daryl L is online now
Old 12-24-2015, 11:08 AM
Cla55clown's Avatar
Quoted: 86 Post(s)
Liked: 50
I have my PM800s crossed over at 100hz, the setting picked by the AVR when using YPAO. Sounds fine to me. They really aren't very big drivers so I think 100hz is appropriate.
Sent from my Nexus 5X using Tapatalk
Daryl L likes this.
Cla55clown is offline
Old 12-28-2015, 10:32 AM
cmeinck's Avatar
Quoted: 21 Post(s)
I have an older Mythos set, but they aren't wife friendly. I'm thinking of migrating from an in-ceiling system to ProCinema 1000 for the L/R. Would the Mythos 3 I currently own work as a center channel? Would there be any benefit from using the ProCinema 2000 in place of the Mythos 3?
cmeinck is offline
Old 12-28-2015, 10:56 AM
ALtlOff's Avatar
Quoted: 598 Post(s)
Liked: 254
Honestly, just buy the Fronts and give it a try, I have a Three and it is a surprisingly full sounding center, if it sounds off to you, then go to the PC2000. (Not 1000)
*Warning* None of my suggestions, ideas or even thoughts have any WAF, in any way!
My Build Thread:
http://www.avsforum.com/forum/15-gen...formation.html
ALtlOff is offline
Old 12-29-2015, 06:43 AM
ROCCJA's Avatar
Quoted: 60 Post(s)
Liked: 4
Hi i have the 800's in surround and crossover set to 80hz, and they sound terrific in that role, you will be actually surprised at the bass these small speakers can produce.
Actually my surround 800's were sounding better than my Front 1000's, until I set the fronts to Large, and the Aud. setting to L/R Bypass.
Samsung UN65JS8500 TV, Denon S710W Dolby Atmos 5.2.2, DTSX Receiver, Definitive Technology ProMonitor 1000's (Fronts), ProCenter 2000 (Center), ProMonitor 800's (Surround), MAudio 300w Subwoofer. Sony BDPS6500.
ROCCJA is offline
Old Yesterday, 05:52 PM
de8212's Avatar
Quoted: 165 Post(s)
I think I've asked before but does anyone have their PM1000's mounted high on the wall? I know it's not ideal but that's where my current speakers are and would be an easy transition to switch over to PM1000's in front. They're only about 1.5" taller and 1.5" deeper than my current speakers.
Any pics of this type of setup?
de8212 is online now
Old Yesterday, 08:47 PM
Quoted: 93 Post(s)
Look at my old post in this thread for pictures:
Last year, I moved the PM1000s to surround duty.
Def Tech SM350 - Front L/R with Def Tech Pro800 Front heights
Def Tech PC2000 - Center / Def Tech Pro1000 - Surrounds L/R
Hsu VTF3 MK5
pmat123 is online now
Old Today, 12:08 PM
de8212's Avatar
Quoted: 165 Post(s)
Thanks. that's what I was looking for. Mine would be slightly higher but I have different mounts. I'm hoping they will hold the weight of the 1000's.
Definitive Technology Procinema 600 5 1 Speaker System , Definitive Technology Procinema 1000 5 1 Speaker System , Definitive Technology
