Definitive Technology ProCinema Series 600/800/1000 (or 60/80/100) Thread - Page 255 - AVS Forum | Home Theater Discussions And Reviews
 24Likes
post #7621 of 7633 Old 02-17-2017, 09:17 PM
ALtlOff's Avatar
Quoted: 1085 Post(s)
Liked: 535
Originally Posted by tboysen00 View Post
Thanks. Btw nice build thread just went through your thread. Sorry another question. I have been trying to figure out the Yamaha presence options. Most of the people I have seen on the web use the presence speakers up front. Would I be ok in the surround back/presence output for the backs? I guess I don't get how I can can use this option as either the presense (front) or back surrounds? Thanks
Check your manual, you should be able to use then l them as Rear Surrounds for 7.1 by using the proper setup configuration, and if you like, rear surrounds can be mounted up high as well.
And, thanks. Now you know where my screen name comes from.
tboysen00 likes this.
*Warning* None of my suggestions, ideas or even thoughts have any WAF, in any way!
My Build Thread:
http://www.avsforum.com/forum/15-gen...formation.html
ALtlOff is offline
post #7622 of 7633 Old 02-17-2017, 09:50 PM
Quoted: 14 Post(s)
Liked: 0
Ha yeah. Love the setup. Someday You recommend the SVS pb 1000. I am thinking this sub wouldn't work well with my prosub 600 as the prosub is sealed and the pb is ported. Wonder if I'd be better off with the SVS SB?
tboysen00 is offline
post #7623 of 7633 Old 02-17-2017, 11:47 PM
ALtlOff's Avatar
Liked: 535
Actually I was recommending either, they are the same price.
Ported or Sealed really won't matter as far as the matching, the real issue is actually going to be size, the PB is actually quite large, so if you do decide on the PB, do yourself a favor and make a box the same size as the Sub to make sure it will physically fit in your room.
My Build Thread:
ALtlOff is offline
post #7624 of 7633 Old 02-28-2017, 12:15 PM
Liked: 0
Originally Posted by Gazoo382 View Post
Taking apart a Promonitor 600 (and I assume 800/1000) can be a puzzle. I spent 2 hours searching everything I could find so I figured I should at least post this for someone in the same situation.
PM600
1. Remove grille. (Start at bottom, slowly moving upward)
2. Remove top two screws. You'll notice that they are screws NOT bolts. (You don't have to remove these but I did.)
3. Do not (as I did) remove any of the 4 screws holding the woofer in place as then you'll have a nut bouncing around inside.
4. Do not remove the screw on the top thinking it's holding something on. (It isn't)
5. Not obvious: there are screws UNDERNEATH each of the rubber grommets that hold on the speaker grille. Pry them off and remove all 6 of the screws. Those 6 are what is holding it on.
6. Gently pull the frame out by pushing just a little on the top bezel. Just wiggle it a enough and it will start to give. (Note, as you'll find out when open, that top baffle is just lightly glued on)
7. Before it come all of the way out, you'll need to reach in and disconnect the two wire going to the binding posts. Again, a little wiggle back and forth and pull straight up. (Don't worry, they are tough, you won't hurt them)
I'll leave the rest to you. My issue was that the woofer is not
working. I looked at every solder joint, every millimeter of the PC board and could not find a issue. Therefore I assume a resistor or capacitor is blown, The 5w resistor you can't really tell if it bad. The capacitors maybe looked like they were leaking, but I could not verify even looking with a loop. Oh well! I will put it all back together and see if it works. That is how I fix all of my stuff. MAGIC!
THANKS!! Saved me a lot of time. Had very weak output on one satellite. Opened it up in 5 minutes with your help, otherwise, I'd have bee cursing up a storm not knowing about the screws behind those rubber grommets! Checked connections.... fine. Called support just to price a replacement crossover. They're sending one out.... FREE OF CHARGE! What? I read all of the good things about Definitive Technology's customer support and would like to add my experience. Why can't all companies be like this? They are sure making a great name for their company!
aj_chicago is offline
post #7625 of 7633 Old 04-03-2017, 03:28 PM
totalfly's Avatar
Due to WAF, I'm limited to 4 x ProMonitor 800 mounted on the walls. However, I have more leeway with size for the center speaker. Ignoring price, should I go with ProCenter 1000 or ProCenter 2000?
totalfly is online now
post #7626 of 7633 Old 04-03-2017, 03:36 PM
Quoted: 459 Post(s)
Liked: 124
Procenter 2000.
Only reason I see to go with the 1000 is if you have space limitations.
Doe Doe is online now
post #7627 of 7633 Old 04-03-2017, 04:14 PM
totalfly's Avatar
Originally Posted by Doe Doe View Post
Procenter 2000.
I thought maybe ProCenter 1000 would match (or blend in) with the ProMonitor 800 better because the drivers are the same size. Or does that not really matter?
post #7628 of 7633 Old 04-03-2017, 04:30 PM
Quoted: 459 Post(s)
Liked: 124
Don't think it really matters.
Def Tech's website states the 2000 matches with the 800, so I think it'd be fine. I wouldn't worry about matching exact driver size.
Works in Concert
A mainstay in the acclaimed Pro Series, ProMonitor 800 speakers pair with a ProCenter 2000 and matching ProSub for a complete ProCinema sound system.
post #7629 of 7633 Old Yesterday, 11:50 AM
AlexanderDelarg's Avatar
Quoted: 157 Post(s)
Liked: 178
PC2000 as it is much, much better than the PC1000.
Epson Pro Cinema 6030 | OPPO BDP - 103 | Pioneer Elite VSX 70 | Definitive Technology PM 1000 (L/R) | PC 2000 (C) | SR8040BP's (7.1) | Rythmik LV12R | Carada Criterion Brilliant White 118" | URC MX 780 & MRF 350 | ATS Acoustic Panels | Sanus AV Rack | DirecTv | Roku 2 | Monoprice 12AWG |
AlexanderDelarg is online now
post #7630 of 7633 Old Yesterday, 12:21 PM
Quoted: 459 Post(s)
Liked: 124
If you own the 2000 (or if anyone does actually), how does it handle voices in comparison to the 1000?
I own the 1000 and although dialogue is clear, I find male voices not as deep as they should be, and overall it seems like treble is cranked.
2000 fix those issues? Or does it seem overly treble-y still?
I have space issues so can't really fit a 2000 right now, just wondering in case I run across a deal on it one day ... if it was a huge upgrade and fixed the voice deepness/treble issues, I may get it and worry about fitting it in later.
post #7631 of 7633 Old Yesterday, 12:26 PM
Quoted: 157 Post(s)
Liked: 178
Yes, I own the PC2000 and love it, and if you search this thread, you will read that the PC2000 is a very big improvement over the PC1000. It is night and day. No issues whatsoever on the treble. You will not regret it in the least. Get one from bayhawaverunner.
Doe Doe likes this.
post #7632 of 7633 Old Yesterday, 12:37 PM
Quoted: 459 Post(s)
Liked: 124
Well, for now I'll keep an eye out for it on CL. I got my 1000 super cheap from CL .. (<$50) so tend to do the CL thing when I can.
I'll put it on my very short list of centers to look for though. I don't need a def tech for matching reasons (my sides aren't def techs)... but I need a small center. 1000 is fine for its size, but again, I just sort of like male voices to sound normal and not feel like everything has treble turned up to max.
Just so I have the dimensions right, it's about 6.5" high, 6.5" deep? A couple of places list it larger than that, so want to double check.
Currently have about 5x5, so would need to find some sort of solution there.
post #7633 of 7633 Old Today, 11:56 AM
Quoted: 157 Post(s)
Liked: 178
6.5" x 6.5" x 17" is accurate.
Doe Doe likes this.
Reply Speakers
Definitive Technology Procinema 600 5 1 Speaker System , Definitive Technology Procinema 1000 5 1 Speaker System , Definitive Technology
