SVS MTS Family - Page 17 - AVS Forum | Home Theater Discussions And Reviews
post #481 of 640 Old 01-10-2009, 06:35 PM
Cam McFarland's Avatar
So, nobody has ordered the rear wall mounts from SVS??
If there are no dogs in Heaven, then when I die I want to go where they went.
-Will Rogers
Cam McFarland is offline
post #482 of 640 Old 01-10-2009, 08:35 PM
UHD Addict
aaronwt's Avatar
Quoted: 6207 Post(s)
Liked: 3850
I ordered the stands. I'm glad I didn't order the rear mounts(I considered it) The speakers are much larger than I thought they were and wouldn't have worked well on my wall since they are too big for the wall in my setup. But they do sound excellent.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #483 of 640 Old 01-10-2009, 08:55 PM
allredp's Avatar
+1 on both points--the MBS are healthy-sized for sure and take a special room/situation to use them on the wall, and they do sound fantastic!
creative>energy
allredp is offline
post #484 of 640 Old 01-10-2009, 09:31 PM
Unfortunately, I dont think I could use the stands, I would have to put one right next to me head & the other about 6ft away.
I know the rears are large but mounting them on the walls gives me more (& equal) distance from the seating area.
-Will Rogers
post #485 of 640 Old 01-10-2009, 09:50 PM
allredp's Avatar
No worries, that's how Ron (of SVS) has his! Just know that those MBS will handle anything the surround channels can throw at them--they are exceptional at getting loud!
creative>energy
allredp is offline
post #486 of 640 Old 01-10-2009, 09:52 PM
When you got yours, did the speakers & sub come via 2 different shipping companies, if so, did they arrive the same day???
-Will Rogers
post #487 of 640 Old 01-11-2009, 07:50 AM
robbroy's Avatar
There is not enough room in the box for the rear mounts. Those are probably in the same shipment as box 2 of X.
Fair warning: you will need help from a friend to hang these. And when you think you have the teeth tight enough around the rubber ball on the mount, keep tightening. I woke up the next morning with the speakers sagging against the wall and had to start over.
-Robb
robbroy is offline
post #488 of 640 Old 01-11-2009, 07:57 AM
DamageMcRamage's Avatar
Quoted: 42 Post(s)
Liked: 57
I have a question about the speaker stands that SVS has for the surround speakers. I bought two pairs for my four surround channels and they look fine.
I'm just a little concerned that the speaker stands say the max speaker weight for the stands is 25lbs. But the bookshelf speakers are 27lbs.
Has anyone had any problems with these stands since they are supporting more weight than the specs say they are designed for?
I ordered those stands as well, haven't had a problem since the end of Sept. It's only 2lbs, they'll be fine.
I like Ice Cream!
DamageMcRamage is offline
post #489 of 640 Old 01-11-2009, 10:11 AM
-Robb
Thanks for the info I will not be doing it by myself...
That's just it (see bold) the speakers are coming in 2 shipments from 2
different shipping companies...UPS & BaxGlobal.....the UPS shipment contains 5 boxes (5 speakers, correct?) & the BaxGlobal contains 1 box which has to be the sub due to the weight of the box.
Unless they packed the mounts in one of the speaker boxes I am 1 box short...unless two of the speakers come in one box.
I hope this made sense...
- Cam
-Will Rogers
post #490 of 640 Old 01-14-2009, 09:13 AM
It iturns out the two rear speakers comer in 1 box, so my mounts are coming via UPS with the speakers.
Now, how does one go about removing the pb13 ultra from it's box without destroying it (the box) in the event I need to send the sub back???
-Will Rogers
post #491 of 640 Old 01-14-2009, 10:23 AM
bearchan's Avatar
Hi Cam,
Open the bottom, pull box up and over the pb13.
or
Open top and bottom, slide/push pb13 on it's side.
Fold boxes and store.
bearchan is offline
post #492 of 640 Old 01-14-2009, 11:31 AM
Originally Posted by bearchan View Post
Hi Cam,
or
This is what I was thinking, but I was worried about rolling it over on it's side.....and I hadn't thought about opening both top & bottom to fold for storage...
-Will Rogers
post #493 of 640 Old 01-14-2009, 01:57 PM
robbroy's Avatar
You all probably already saw that the SV Sound MTS package received "Certified and Recommended" by Sound & Vision, but they also received one of the 20 "2008 Editor's Choice Awards" from them as well:
http://www.soundandvisionmag.com/fea...t-1-page4.html
-Robb
robbroy is offline
post #494 of 640 Old 01-14-2009, 02:29 PM
380hpSC@12's Avatar
Can anyone tell me how the MTS-01 compare to a Rocket 850, 450 and SC200 (Big Foot) HT system? I already own the PB-13 which will be integrated to either system.
380hpSC@12 is offline
post #495 of 640 Old 01-14-2009, 02:50 PM
robbroy's Avatar
I'm openly biased, but a guy near me has the Rocket set, and I thought they looked a lot better than they sounded. I think the SVS look good, and sound better.
-Robb
robbroy is offline
post #496 of 640 Old 01-17-2009, 01:17 PM
dixlon's Avatar
-Robb
I agree with Rob as well. I have a friend who has Rocket 1000 and I thought the MTS Towers had more detail than the Rockets did for both 2 channel and HT audio.
For the longest time I was auditioning for tower speakers from Axiom M80's, Polk Audio LSi 15's and the SVS MTS line.
In my opinion I thought Axioms M80's were good but not as detailed as the LSi15's. The SVS towers I thought had the best detailed sound out of the three speakers and for the price of the SVS towers it was a no brainer for me to pick the MTS line.
These are just my thoughts and my thoughts only.
Dixlon
dixlon is offline
post #497 of 640 Old 02-18-2009, 12:24 PM
lakebum431's Avatar
Can someone give me a real life measurement of the height of the MCS-01 center speaker. The web specs say 10". I just checked my Entertainment center and I literally have 10 1/8" so it is going to be tight. Should I be worried about the speaker being so tight in there? Considering pulling the trigger on the full MTS-01 family.
lakebum431 is offline
post #498 of 640 Old 02-18-2009, 12:32 PM
UHD Addict
aaronwt's Avatar
Liked: 3850
it is 10 inches if i remember correctly. Possibly 9 and 7/8 ths.
I wish I had 10 1/8" of space.
aaronwt is offline
post #499 of 640 Old 02-18-2009, 12:37 PM
lakebum431's Avatar
Any concern with it being so tight for me?
post #500 of 640 Old 02-18-2009, 12:39 PM
+1
I ended up wall mounting the center above my screen, just resting the leading edge of the mount on top of the set.....if I was at home I could give you the true dimension.
-Will Rogers
post #501 of 640 Old 02-18-2009, 12:40 PM
I dont see why there would be any concern as long as it fits.....
my .02
-Will Rogers
post #502 of 640 Old 02-18-2009, 01:03 PM
lakebum431's Avatar
Cam if you remember and don't mind measuring I would really appreciate it.
post #503 of 640 Old 02-18-2009, 01:48 PM
check back in about 1 1/2 hours....gives me enough time to get home, measure & get back online....
-Will Rogers
post #504 of 640 Old 02-18-2009, 02:30 PM
Ed Mullen's Avatar
Quoted: 122 Post(s)
Liked: 334
I just measured mine. 9-7/8" flush with the top.
Ed Mullen
Director - Technology and Customer Service
SVS
"What We Do In Life, Echoes In Eternity"
Ed Mullen is offline
post #505 of 640 Old 02-18-2009, 02:59 PM
lakebum431's Avatar
Perfect! Thanks Ed!
post #506 of 640 Old 02-18-2009, 03:17 PM
Well, one of us does not know how to measure...mine is 10.25".
I hope somebody else can chime in.....
-Will Rogers
post #507 of 640 Old 02-18-2009, 03:45 PM
UHD Addict
aaronwt's Avatar
Liked: 3850
I think mine is between 10.125 and 10.25
I thought it was right at 10 inches or slightly below.(it doesn't matter for me either way since my stand only has around 9.5 inches)
It's kind of difficult for me to measure exactly since it's curved on the sides.
aaronwt is offline
post #508 of 640 Old 02-18-2009, 04:26 PM
Take the front grill off & measure the flat surface for a true height...
-Will Rogers
post #509 of 640 Old 02-19-2009, 01:03 PM
lakebum431's Avatar
Hmm, quite the range. Now I'm worried. If it won't fit in the stand I'm not sure it will pass the WAF. The difference between what Ed measured and what Cam measured is only .375" but if on the top end of that then it won't fit
post #510 of 640 Old 02-19-2009, 01:14 PM
Maybe Aaron will take the grill off his & measure it as I suggested to get a more accurate dimension......
-Will Rogers
Reply Speakers
