The OFFICIAL JBL Owners Thread - Page 508 - AVS Forum | Home Theater Discussions And Reviews
 384Likes
post #15211 of 17212 Old 06-11-2014, 08:37 PM
filecat13's Avatar
Quoted: 35 Post(s)
Liked: 102
Hi, Serg, and welcome..
Originally Posted by husq2100 View Post
Thought id say high as im new here.
Bit of a JBL fan, I have Xti100, LS80 and some L15 that im fixing up. I also hope to be getting the components to some L26 so I can build some myself.
I also had Xti20 and a Xti 300 sub, but had to let them go due to moving.
Cheers
Serg
What I can afford, when I can afford it...
filecat13 is offline
post #15212 of 17212 Old 06-13-2014, 08:22 PM
rokbyter's Avatar
Quoted: 38 Post(s)
Liked: 29
Originally Posted by rdgrimes View Post
The HTPS400 has never failed to impress anyone.
Picked one up last week and hooked it up, but haven't had time to do the sub crawl or optimize it. Still, I'm very impressed so far. Outstanding sub, has exactly the sound I was looking for - controlled, tuneful, just sounds right. My use is about 60% music, 20% each of TV and movies - it works for everything.
rokbyter is offline
post #15213 of 17212 Old 06-14-2014, 08:25 AM
rdgrimes's Avatar
Quoted: 2087 Post(s)
Liked: 1416
I'm sure you'll come to appreciate the HTPS400 more as time goes by. If you want another one, there's one on eBay at a very reasonable price.
2 is better than one.
rdgrimes is offline
post #15214 of 17212 Old 06-17-2014, 08:29 AM
rokbyter's Avatar
Quoted: 38 Post(s)
Liked: 29
A second one is very tempting. I think I'm already pushing it though, having one in a 850 sq ft apartment
rokbyter is offline
post #15215 of 17212 Old 06-17-2014, 08:31 AM
kpotier16's Avatar
Quoted: 14 Post(s)
Just got a jbl studio s center used for $30. Great sounding center channel
kpotier16 is offline
post #15216 of 17212 Old 06-20-2014, 11:43 AM
floorhor's Avatar
Liked: 1
I am putting together my first 5.1 system. I have a pair of L112's I bought when I was in high school...32 years ago, ooomph! Now I'm glad I was stupid with my money! I assume they will do fine as the fronts. From reading, everyone is saying the front three speakers need to match up. Any recommendations on a center for my L112's?
floorhor is offline
post #15217 of 17212 Old 06-20-2014, 01:19 PM
rdgrimes's Avatar
Liked: 1416
If it hasn't already been done, those L112 need a re-foam on the woofers. Otherwise they're good to go. You can buy used L-series speakers on eBay and elsewhere that will be a great match. The best options are L46, L86, L96. An L46 would make a very good center.
A lot depends on how good your AVR is with auto-EQ, which is necessary when matching un-matched speakers. I'd say that of the current JBL line, the Studio L series is the closest for you. My recommendation would be LC2 for center and L820 or L830 for surrounds.
rdgrimes is offline
post #15218 of 17212 Old 06-20-2014, 02:09 PM
floorhor's Avatar
Liked: 1
When I found out what they were worth, I did the refoam. Also replaced the mid with the hole in it from one the yung uns.
Looks like the build and drivers on the L46 are similar to the 112's. I suppose i would have to position it vertically, or would horizontal work? Horizontal would be great so I wouldn't have to move the equipment cabinet.
If I have to do vertical, the L86 would probably be a better choice because it's got a mid. What say you?
floorhor is offline
post #15219 of 17212 Old 06-20-2014, 02:36 PM
rdgrimes's Avatar
Liked: 1416
The L46 is an outstanding speaker. Its only a little smaller than the L86. Either would work great. The issue is that it takes time to round them up unless you're willing to spend too much. As for horizontal placement, it won't make a huge difference. I've had both the L86 and L46. The L86 is a wonderful speaker. You could just as easily dig up another L112 if you have the room for it, that would sound amazing. But they do bring a bigger price. I have a pair of L96 and L112 here, neither of which I will ever let go of. The L86 has less power handling and lighter drivers, but sounds just as good at reasonable volume.
I once set up a 7.1 surround system with L250 L-R, L112 SR-SL and L96 SBR-SBL. It sounded pretty nice. I used a PC600 for center after failing an attempt to build a custom center.
rdgrimes is offline
post #15220 of 17212 Old 06-22-2014, 11:05 PM
WilliamDj's Avatar
Hello I need your help with a ceiling mounts for jbl l820 recommend me any?
WilliamDj is offline
post #15221 of 17212 Old 06-23-2014, 07:48 AM
velvet396's Avatar
Quoted: 14 Post(s)
Liked: 33
Found a like-new pair of S38II for $300.
Bite?
I've had my eye on this speaker since forever...but will have a hard time finding a place to use it. I feel like they would be wasted as rear/surrounds.
velvet396 is offline
post #15222 of 17212 Old 06-23-2014, 08:03 AM
rdgrimes's Avatar
Liked: 1416
Bite?
You can get them a lot cheaper on eBay, but then you have to deal with shipping.
In a 7.1 system the back speakers get as much or even more usage than the side surrounds, especially when using PLIIx to matrix 7.1 from 5.1. In any case you should work for having identical speakers in both positions. But as surrounds in a 5.1 system, yes by all means use S38.
rdgrimes is offline
post #15223 of 17212 Old 06-23-2014, 08:28 AM
velvet396's Avatar
Quoted: 14 Post(s)
Liked: 33
Pardon my usage of rear vs. side - I have a 5.1 setup. LC2 center, Venue Front L/R, Polk R30 surrounds.
With just movies & games, the rears really only get used for effects, so I would have a hard time putting them there. Although I don't have a large house and finding another place that would meet WAF is probably the largest challenge.
Thanks for the info on pricing, it was an ebay pair including shipping at $300.
post #15224 of 17212 Old 06-23-2014, 09:22 AM
rokbyter's Avatar
Quoted: 38 Post(s)
Liked: 29
if it were me, I'd pick up the S38s and upgrade the front L/R.
rokbyter is offline
post #15225 of 17212 Old 06-23-2014, 10:28 AM
Smarty-pants's Avatar
Quoted: 749 Post(s)
Liked: 627
^ Heck if you're willing to pay $300 for a pair of S38, why not opt for a pair of L820 (or L880 for a bit more) to upgrade the front speakers.
The L series will outperform the S38, and walk all over the Venue. Plus it will be a perfect match to the LC2.
Smarty-pants is offline
post #15226 of 17212 Old 06-23-2014, 10:34 AM
rokbyter's Avatar
Quoted: 38 Post(s)
Liked: 29
^very true. I have a pair of l820s I'd part with for that, actually. PM me if interested.
rokbyter is offline
post #15227 of 17212 Old 06-23-2014, 11:24 AM
velvet396's Avatar
Quoted: 14 Post(s)
Liked: 33
love my Stadium fronts. If upgrading were only $300, I might listen to you. But it most definitely would not be, to upgrade the quality from the Stadiums...
You would have a hard time convincing me to pick up 820's to replace the Stadiums with two 8" woofers. Who do I have to rob to get them anywhere near "a bit more"? Let's say 33% more, $400, for a pair.
Edit: I was really just looking to see if the 38's were a good price. Having received that feedback, I'm going to back away slowly now. I'd rather not fight. I won my battle with upgrade-itis, I enjoy my system as-is and my bank account thanks me for it. I wish the rest of you the best in your hunt for audio perfection. Don't forget to stop and enjoy your setups.
post #15228 of 17212 Old 06-23-2014, 03:43 PM
Quoted: 749 Post(s)
Liked: 627
^Sorry, I didn't realize those were the models you had.
For some reason I was under the impression you had bookshelf speakers.
So ya, in order to do a decent upgrade you would have to go with the L880s or L890s.
post #15229 of 17212 Old 06-24-2014, 05:55 AM
WilliamDj's Avatar
This ceiling mount is a good choice for the l820?
http://www.amazon.com/dp/B00FZ136AU/...I2W8HEKWU5L73G
Enviado desde mi iPhone con Tapatalk
post #15230 of 17212 Old 06-24-2014, 07:20 AM
velvet396's Avatar
Quoted: 14 Post(s)
Liked: 33
Those S38II's I had my eye on might only be $225. That's maybe a different discussion than $300.
Damn!
Edit: Some lucky bastard got them for $232 shipped. I was in a meeting when it ended. Saved me some money, I guess!
post #15231 of 17212 Old 06-24-2014, 07:52 PM
birdseye40's Avatar
jbl studio series for sale
just read this thread.....I so happen to have JBL L7s ; Studio Series Center Channel LC2 ;
Studio Series L820 ; Studio Series S36 II. selling as set or any speakers you need.
birdseye40 is offline
post #15232 of 17212 Old 06-25-2014, 09:46 AM
rdgrimes's Avatar
Liked: 1416
I'm surprised that someone hasn't yet grabbed this deal:
http://www.ebay.com/itm/271519298562...84.m1423.l2649
This HTPS400 has been sitting on eBay for some time. UPS shipping will be close to $100.
I'm tempted to grab it just to have as a spare.
rdgrimes is offline
post #15233 of 17212 Old 06-25-2014, 10:34 AM
Quoted: 749 Post(s)
Liked: 627
^ I don't think it would even be 100. I'm in the northern end of Ohio and it's showing 75 for me.
It's also a BIN auction OR BEST OFFER. Shows there has been 1 offer that was declined, but who knows what that offer was.
A decent deal for someone, but not me. My fun budget is the size of a peanut these days.
The description doesn't exactly instill confidence that it isn't half broken.
..."working condition"...
post #15234 of 17212 Old 06-25-2014, 10:40 AM
rdgrimes's Avatar
Liked: 1416
I shipped one in factory packing from here to Omaha and it was about $90. Weight is ~70# packed.
rdgrimes is offline
post #15235 of 17212 Old 06-25-2014, 10:43 AM
Quoted: 749 Post(s)
Liked: 627
^Maybe he has the weight under-estimated then.
post #15236 of 17212 Old 06-25-2014, 10:48 AM
filecat13's Avatar
Quoted: 35 Post(s)
Liked: 102
Some of us already have too many subs, including you and me, and it would be a shame to have it sit lonely and unused as a spare.
post #15237 of 17212 Old 06-25-2014, 10:54 AM
rdgrimes's Avatar
Liked: 1416
Except that sooner or later they all die. I have spare PS1400s collecting dust. As I recall, you sold a few of these not long ago. Certainly at this price you get a sub performing closer to the $1000 class. Nobody ever believes what these little bundles of muscle can do till they try one.
rdgrimes is offline
post #15238 of 17212 Old 06-25-2014, 10:59 AM
filecat13's Avatar
Quoted: 35 Post(s)
Liked: 102
If by "a few" you mean six PS1400s, yes I did, along with four HTPS400s...
and I still have too many subs!
post #15239 of 17212 Old 06-25-2014, 11:07 PM
Mudslide's Avatar
Quoted: 74 Post(s)
Liked: 87
The L series will outperform the S38.
This notion seems to get passed around a lot. I wonder how many people that report same actually did an A/B listening test in a controlled environment to come to this decision. Well...I did, and there is virtually NO advantage to either model. In fact, they sound incredibly alike. YMMV.
MARGARITAS,
they're not just for breakfast anymore.
Mudslide is offline
post #15240 of 17212 Old 06-26-2014, 01:52 AM
Quoted: 749 Post(s)
Liked: 627
Well there's something wrong with your ears then. I had a full set of E-series and a pair of S38.
The Es were sold to help pay for the Ls and I held on to the S38 for a while, but ended up selling them since I couldn't use them anywhere practical.
I have a dedicated theater room with proper acoustical treatments for accurate sound.
I hear a distinct difference between the S38, the E50 and the LC2 / L820. Better clarity, better imaging, smoother frequency response for the Ls.
It's not like night and day difference, but it's not so subtle either.
Reply Speakers
520c , Athena , Center Channel Speaker Sku Pas749099 , Center Channel Speakers , Jbl , Jbl Balboa Sub 10 Inch Powered Subwoofer , Jbl G200 Bookshelf Speakers , Jbl Harman Kardon , Jbl Lc1 3 Way High Performance Dual 5 1 4 Inch Center Channel Loudspeaker Black , Jbl Lc2 4 Way High Performance 6 Inch Dual Wall Mountable Center Channel Loudspeaker Black , Jbl Northridge E30 2 Way 6 Inch Bookshelf Speakers Pair Black Ash , Jbl Professional , Jbl S Center Center Channel Speaker , jbl studio 5 series
