The OFFICIAL JBL Owners Thread - Page 517 - AVS Forum
post #15481 of 15492 Old 10-21-2014, 04:42 PM
NismoZ's Avatar
I have a question about timbre matching JBL speakers. Currently, I have S312IIs and a S Center II up front with S36IIs for sides and rears. All of these speakers are from the same line and matched. If I upgraded to the performance series PC600 Center, would the timbre still match? Reading the specs of the speakers, they seems to use a lot of key words in them that make me think they would blend ok with each other. let me know if you guys have heard the difference between the old Studio line and the Performance line and if you think it would work.
PC600 description:
This 3-way, dual 6-inch center speaker reproduces sound with incredible power, while preserving the clarity and detail of the original recording.
Pure-titanium, high-frequency-transducer domes with neodymium magnet structures are ultralight to accurately reproduce lightning-fast sounds like cymbal crashes, yet extremely rigid to eliminate distortion and ear fatigue in the transition between the midrange and high-frequency bands.
Elliptical Oblate Spheroidal™ (EOS) waveguides were first developed for our JBL Professional LSR studio monitors. They enable Performance Series speakers to evenly disperse high frequencies and create precise stereo imaging over a wide listening area.
Pure-titanium, inverted dome midrange transducers seamlessly blend with the titanium dome tweeters by offering nearly perfect pistonic motion that eliminates uncontrollable flexing found in conventional cones. The inverted dome is driven precisely at its center, which cancels resonances inherent in cone materials. The result is ruler-flat frequency response well beyond the crossover point.
Titanium-alloy, inverted dome low-frequency transducers deliver precise, undistorted bass reproduction that matches the titanium tweeters and midranges. The powerful neodymium magnet provides its own video-shielding, allowing flexible placement, even near video monitors. Cast-aluminum frames remain rigid even at the highest volumes, avoiding distortion found in some other speaker designs. And aluminum doesn't affect the magnetic flux, so that driver movement is precise and unmuddied.
S Center II description:
The amazing 3-way S-Center ii brings dialogue and sound effects to life with outstanding clarity and realism, thanks to pro-style JBL technology! A 1" titanium tweeter and 4" PolyPlas midrange are mounted on an LFP (Linear Field Proximity) bezel for precise localization — on-screen sounds are firmly anchored in place. Two 5-1/2" PolyPlas woofers and rear-firing ports provide ample sonic depth. The molded poly cabinet, with graceful curves and dark gray finish, looks right at home on top of your TV
NismoZ is offline
post #15482 of 15492 Old 10-21-2014, 05:30 PM
JESSIE DART's Avatar
Quoted: 12 Post(s)
A quick poll..
Do Studio L owners toe in their speakers, or leave them straight firing?
I've read different views on this....
Is there a definite right or wrong way for placement.
JESSIE DART is offline
post #15483 of 15492 Old 10-21-2014, 06:30 PM
89grand's Avatar
Quoted: 156 Post(s)
Liked: 73
Originally Posted by JESSIE DART View Post
A quick poll..
It's pretty dependent on each and every setup. There is no right or wrong answer. Some speakers respond better to some toe in more than others, but it's still a setup related thing.
There are some speakers that are specifically meant to fire straight ahead, my DCM Time Windows come to mind, but most speakers aren't that way.
89grand is offline
post #15484 of 15492 Old 10-21-2014, 07:47 PM
rdgrimes's Avatar
Quoted: 285 Post(s)
Liked: 233
The PC600 is a formidable speaker, center or otherwise. But I'd suggest that you leave well enough alone since you already have a good match.
I'd add that if you get one PS speaker, you'll be hard pressed to think about anything else but getting more. I can't think of a really good match for your S312 other than the S-Center, but if pressed you might look into an LC2. The S-Center has a bit of a "plastic box" sound to it, which you might avoid with the LC2 or even an EC35.
rdgrimes is online now
post #15485 of 15492 Old Yesterday, 08:53 AM
SyntheticShrimp's Avatar
Quoted: 89 Post(s)
Liked: 97
@Gooddoc
Do you know if it is absolutely necessary to buy the Crown or Mark Levinson amps with the M2s? My question really is, is the DSP used for the active crossover only? Or are there filters included that flatten the anechoic response?
If it's the former there's no reason why one couldn't just use a minidsp to do the crossover and use whatever amp is desired. If it's the latter it's probably worth buying the amps since JBL has access to the full anechoic measurements.
Theater room: Sony VPL HW30ES, DIY 100" screen with Seymour Centerstage XD, 5 Revel M105, 2 JBL Studio 210, 4 SVS SB12-NSD, Anthem MRX-300
Living room: Panasonic TC-P60VT60, 3 KEF LS50, Pioneer SW-8, Marantz NR1603
SyntheticShrimp is online now
post #15486 of 15492 Old Yesterday, 09:33 AM
Gooddoc's Avatar
Quoted: 400 Post(s)
Liked: 317
Originally Posted by SyntheticShrimp View Post
@Gooddoc
It's more than just crossovers. There are other filters in there.
But you don't need to buy any special amps, so long as they deliver sufficient power. But you do need the BSS processor at a minimum, it's just convenient that it's built into the Crown amps.
But I may be sending the Crowns back and getting a BSS processor and just use my LG10000Q amp to drive the M2's. I've got some hiss in the CD with the Crowns and I'm not liking that I have to reduce input voltage and gains to reduce it to acceptable levels. Input clipping is a concern at high volumes. But I'm waiting on my new prepro and I'll see how high the output on that can be driven before making a decision.
I've been told by JBL that the Crown amps are the most transparent with the active crossovers and filters, so I don't want to ditch them unless I have to.
SyntheticShrimp likes this.
Gooddoc is online now
post #15487 of 15492 Old Yesterday, 07:58 PM
Quoted: 89 Post(s)
Liked: 97
Thanks. So many setup options to consider.
post #15488 of 15492 Old Today, 04:00 AM
Gooddoc's Avatar
Quoted: 400 Post(s)
Liked: 317
Are you considering the M2's for purchase?
post #15489 of 15492 Old Today, 06:22 AM
Quoted: 89 Post(s)
Liked: 97
Yeah I'm gonna get them. Just rustling up the money now.
post #15490 of 15492 Old Today, 06:51 AM
Gooddoc's Avatar
Quoted: 400 Post(s)
Liked: 317
Have you heard them yet, or is this a blind purchase?
post #15491 of 15492 Old Today, 07:07 AM
Quoted: 89 Post(s)
Liked: 97
Blind, but I've heard enough wide dispersion, constant directivity speakers to know that's the sound I'm after. I just need the output to back it up.
post #15492 of 15492 Old Today, 08:41 AM
Gooddoc's Avatar
Quoted: 400 Post(s)
Liked: 317
Wow, you're bold man! I like that . But don't you think you should listen first . They are, after all, just step above "budget" speakers from a cost perspective, hehe. If you're anywhere close to New Jersey, you're welcome to audition them at my place. But if not, I'm sure there's other places near you that have them for audition, no?
Reply Speakers
Jbl Professional , Jbl Harman Kardon , Jbl G200 Bookshelf Speakers , Jbl S Center Center Channel Speaker , Jbl Balboa Sub 10 Inch Powered Subwoofer , Center Channel Speaker Sku Pas749099 , Jbl , Jbl Northridge E30 2 Way 6 Inch Bookshelf Speakers Pair Black Ash , Jbl Lc1 3 Way High Performance Dual 5 1 4 Inch Center Channel Loudspeaker Black , Jbl Lc2 4 Way High Performance 6 Inch Dual Wall Mountable Center Channel Loudspeaker Black , Center Channel Speakers , Athena
Gear in this thread - G200 by PriceGrabber.com
