The OFFICIAL JBL Owners Thread - Page 520 - AVS Forum
post #15571 of 15573 Old 11-20-2014, 02:19 PM
4DHD's Avatar
Liked: 74
Originally Posted by gferrell View Post
So what are the principals of a bias XO? How do you go about doing it?
Go over to www.lansingheritage.org
Search for Charged-Couple Networks.
What it involves is changing the caps. Lets say the tweeter circuit has an 8uf cap and a 4uf cap.
The 8uf is replaced with two 16uf caps, wired in series.
The 4uf is replaced with two 8uf caps, also wired in series.
You do the same for all caps.
The common points of each pair of caps are connected to 2 megohm resistors.
The other ends of the resistors connects to the + side of a 9v battery.
This does two things, the 9vdc keeps the layers of the caps tight.
And it also keeps the audio signal above the 0 volt line.
W/O the 9v charge, the layers tighten, loosen, tighten, loosen as the frequency and amplitude change. And by keeping the signal above the 0 volt line the caps are always on, eliminating a slight phase sift as the signal changes direction.
As you can see, both the doubling of size and number of caps will require a lot more space. The original L212 XO fit on one 4.5 x 7 card. The Biased XO required 3 cards, one for each driver.
4DHD is offline
post #15572 of 15573 Old 11-20-2014, 05:42 PM
gferrell's Avatar
I will study that. How did you time align the L212? Those sure are fine looking speakers. I think the best looking JBL ever made.
Wishing I could post in the Ultra Hi-End HT Gear ($20,000+)
gferrell is offline
post #15573 of 15573 Old 11-20-2014, 06:44 PM
4DHD's Avatar
Liked: 74
I added two strips of 3/16" ply to the front edge of the original 1/2" spacer. That tiled back the box 1 1/4". Then cut a tapered doughnut for the tweeter to bring back to vertical position.
Notice, I replaced the old 066 tweeter with 052Ti.
And decided to really go reto with blue grille cloth. Bought a pair of L55s in '73 with the same shade of blue. Also going to use it on all the PT800s, subs. Really tired of cafe, black grille cloth.
Name:	2014-11-15 12.34.34.jpg
ID:	377529   Click image for larger version
Name:	2014-11-15 12.36.07.jpg
4DHD is offline
Reply Speakers
Jbl Professional , Jbl Harman Kardon , Jbl G200 Bookshelf Speakers , Jbl S Center Center Channel Speaker , Jbl Balboa Sub 10 Inch Powered Subwoofer , Center Channel Speaker Sku Pas749099 , Jbl , Jbl Northridge E30 2 Way 6 Inch Bookshelf Speakers Pair Black Ash , Jbl Lc1 3 Way High Performance Dual 5 1 4 Inch Center Channel Loudspeaker Black , Jbl Lc2 4 Way High Performance 6 Inch Dual Wall Mountable Center Channel Loudspeaker Black , Center Channel Speakers , Athena
Gear in this thread - G200 by PriceGrabber.com
