The OFFICIAL JBL Owners Thread - Page 530 - AVS | Home Theater Discussions And Reviews
post #15871 of 15888 Old 04-02-2015, 01:57 PM
mikeronesia's Avatar
Quoted: 37 Post(s)
Originally Posted by rdgrimes View Post
Do your PS1400 make a squeaky noise when you turn the power on? I have mine on a slave power strip, and when it comes on they both squeak. They don't do that if I use normal standby mode.
Like a chirp indicator?
One of mine makes a louder noise when it comes on. It would be fine if it had a longer delay and didn't shut off during movies and programs. The other one doesn't do it, so it is still on auto.
In over my head.
mikeronesia is offline
post #15872 of 15888 Old 04-02-2015, 02:03 PM
rdgrimes's Avatar
Quoted: 750 Post(s)
Liked: 376
You have to cut the power and turn it back on in "on" mode to get the squeak. If I turn them on in "auto" mode they don't squeak. I do get little thumps though when they do the auto standby thing. Some worse than others. (I have 4)
rdgrimes is online now
post #15873 of 15888 Old 04-02-2015, 07:21 PM
Mad Norseman's Avatar
Liked: 100
Originally Posted by guigui668 View Post
Hi, does someone know how to set up an ES250 PW subwoofer to 'always on'.
Regards.
I have two of these subwoofers, and they're supposed to always be "on".
In other words, you leave the on/off switch in the "on" position, attach the subwoofer cable to the LFE (left) input, and it awaits a signal from your receiver/pre-amp. When it receives a signal it automatically comes to life (LED atop turns green), and when no signal is present it automatically goes to sleep after about 7 or 8 minutes (LED atop goes back to red).
Just follow the setup instructions for the sub, and for set up of your receiver's room correction software and all will be well...
The Insane Pink Care Bear's Home Theater Set Up:
Marantz AV 8801 Processor, Emotiva XPR-5 Amplifier, Panasonic 65" ST30 Plasma, Yamaha BD-S2900 Blu-ray, Yamaha CDC-697 CD Player, Yamaha TT-500U Turntable, w/Signet TK5e, JBL ES100 Fronts, JBL LC2 Center, JBL ES30 Surrounds & 2 JBL ES250P Subwoofers
Mad Norseman is offline
post #15874 of 15888 Old 04-03-2015, 05:45 PM
guy80's Avatar
580 & 560p (12" which seems rare as hens teeth, let alone in cherry)
I'm in a temporary living situation & haven't even connected the sub yet.
Name:	Screen Shot 2015-04-03 at 6.43.41 PM.jpg
guy80 is offline
post #15875 of 15888 Old 04-05-2015, 09:04 PM
Gooddoc's Avatar
Quoted: 1017 Post(s)
Liked: 562
Just a little JBL news.
http://www.onscreenasia.com/article/...monitors/17137
Gooddoc is offline
post #15876 of 15888 Old 04-06-2015, 06:32 AM
Liked: 0
Ok Thxs for the answer but... when i listen to low vol. The ES250 doesn't receive enough power to go 'on' and a loose a little sound because of this damn auto-off function !
Could a JBL officiel maintenance shop could remove this function ?
Rgds.
guigui668 is offline
post #15877 of 15888 Old 04-06-2015, 03:48 PM
Liked: 100
Rgds.
Your volume level makes no difference as to whether or not the subwoofer is receiving a signal. It sounds like you're subwoofer is not receiving a consistent signal, which may point toward a defective LFE input jack that's not maintaining contact all the time. It could be a bad solder joint inside(?). I'd email JBL's customer service and describe the problem, and if still under warranty they may be able to recommend a local authorized repair outlet. If not, you'll need to take it in and get it diagnosed and fixed yourself. Sounds like a bad internal solder joint to me...
post #15878 of 15888 Old 04-07-2015, 01:13 AM
Bob7145's Avatar
Liked: 33
My dual L8400P subs have been on or standby, I don't remember, but they come on whenever they get a signal and turn off after a few minutes without. Been like that for maybe 7 years and I always enjoy hearing the "chirp" that lets me know they both activated. I remember some folks returned their L8400P because of the "chirp" thinking it was defective, lol.
I had to get a new AVR and the new one had an unfamiliar to me setup and the subs had a hard time activating until I figured out the sttings and set boost to 20dB. All is well now.
Those 2 Cherry L8400Ps were the the best deal assembling my surround rig. Well the one in the Living Room anyway. They are sandwiched between 3 Cherry L880s now.
Bob7145 is offline
post #15879 of 15888 Old 04-07-2015, 06:54 AM
Liked: 0
JBL LSR4326: Troubleshooting digital pcb
Hey there!
Who may be faced with the problem in the digital board?
JBL lsr4326 Monitor stopped. Sometime sounds: crackling, gnashing.
If you put a digital pcb from another monitor - and it works.
ID:	652625   Click image for larger version
an2an is offline
post #15880 of 15888 Old 04-07-2015, 06:59 AM
JT78681's Avatar
Quoted: 499 Post(s)
Liked: 315
Do you guys think the JBL L880's would be an upgrade over my Infinity P363's?
Receiver - Denon 4311CI
Speakers - Infinity P363's, PC351, P153's
Subs - Rythmik FV15HP's
JT78681 is online now
post #15881 of 15888 Old 04-07-2015, 07:15 AM
rdgrimes's Avatar
Quoted: 750 Post(s)
Liked: 376
Yes. But for the money, the L890 is a better value.
post #15882 of 15888 Old 04-07-2015, 07:22 AM
JT78681's Avatar
Quoted: 499 Post(s)
Liked: 315
Even if I tend to cross over my speakers at 100-120hz?
post #15883 of 15888 Old 04-07-2015, 07:29 AM
rdgrimes's Avatar
Quoted: 750 Post(s)
Liked: 376
Yes, although 120 would be an inappropriate XO for the 890, or 880. Subs are not particularly good at reproducing 80+ Hz audio, especially music.
post #15884 of 15888 Old 04-09-2015, 04:19 PM
aracGuate's Avatar
Studio L890
+1 Go for the L890. You wont regret it!
aracGuate is offline
post #15885 of 15888 Old 04-09-2015, 04:51 PM
4DHD's Avatar
Quoted: 142 Post(s)
Liked: 95
100~120 is way too high, especially if the subs are located anywhere but between the mains. Sub localization starts above 80 htz.
Let those towers do their thing.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Denon disc player, MacBook Pro w/ DragonFly DAC.
4DHD is offline
post #15886 of 15888 Unread Today, 03:03 PM
ethompson6's Avatar
I am finally moving out of a apartment and into a house and am considering upgrading to a pair of JBL l890's.
I don't think I will have enough room for the 2 pairs of JBL l820's I currently have. That said, if anyone is interested in a pair of L820's with speaker stands, please send me a pm.
If you are in the Virginia area, I can deliver them.
ethompson6 is online now
post #15887 of 15888 Unread Today, 03:04 PM
ethompson6's Avatar
post #15888 of 15888 Unread Today, 03:20 PM
Wrager's Avatar
Quoted: 39 Post(s)
Liked: 24
Trust these guys. You're getting great advice from some hard core JBL aficionados! Priceless...
Wrager is online now
Reply Speakers
Jbl Professional , Jbl Harman Kardon , Jbl G200 Bookshelf Speakers , Jbl S Center Center Channel Speaker , Jbl Balboa Sub 10 Inch Powered Subwoofer , Center Channel Speaker Sku Pas749099 , Jbl , Jbl Northridge E30 2 Way 6 Inch Bookshelf Speakers Pair Black Ash , Jbl Lc1 3 Way High Performance Dual 5 1 4 Inch Center Channel Loudspeaker Black , Jbl Lc2 4 Way High Performance 6 Inch Dual Wall Mountable Center Channel Loudspeaker Black , Center Channel Speakers , Athena
Gear in this thread - G200 by PriceGrabber.com
