The OFFICIAL JBL Owners Thread - Page 575 - AVS Forum | Home Theater Discussions And Reviews
 390Likes
post #17221 of 17238 Unread 04-05-2017, 09:33 AM
tom703's Avatar
Quoted: 30 Post(s)
Originally Posted by barasn View Post
Hey guys i have studio 580 front,520c center and studio 530 as a surround looking for a new receiver denon x3300 good for them or i need to go x4300?
You might want to consider if you will want four Atmos or DTS:X overhead speakers in the future. I believe the x3300 only provides for two overhead channels.
Tom
Samsung UN55HU8550/SEK-3500U 4K TV, and UBD-K8500 BR Player. Receiver: Denon AVR-X2200W configured 5.1.2.
JBL Spearkers: Center Studio 235C, 2ea- Studio 590 for L&R, ES250PBK Sub,
2ea - ES90 Towers for L&R surround, 2ea - Studio 230 for front height (Atmos).
tom703 is online now
post #17222 of 17238 Unread 04-05-2017, 10:02 AM
rokbyter's Avatar
Quoted: 49 Post(s)
Liked: 33
Originally Posted by rdgrimes View Post
I'll suggest that you put the Arrays on a 40Hz crossover to the HTPS400s. Or if you feel you are lacking in power to the Arrays, 60 or even 80Hz. But given enough power they are very strong down to 40Hz.
That is exactly what I had in mind. They'll be running from my Parasound Halo Integrated, so I hope they'll be getting plenty of power.
Which leads me to another question - do you think it would be better to run each HTPS-400 from the LR subwoofer channels (same mono signal) on the integrated or daisy chain them via the line output on the sub? It would also be possible to run them from the pre outs on the integrated and use the crossover in the HTPS-400 for a stereo sub setup. I suspect that may make them more difficult to integrate.
Picture of the rear of the amp:
rokbyter is online now
post #17223 of 17238 Unread 04-05-2017, 10:28 AM
rdgrimes's Avatar
Quoted: 2178 Post(s)
Liked: 1512
You should consult Parasound as to whether those 2 sub outputs are mono or stereo. I avoid "stereo" type sub setups because it halves the output from each sub. So I'd go with mono x2 however you wish to achieve that. Daisy chain works as well as anything unless they are on opposite sides of the room and not easy to connect.
rdgrimes is offline
post #17224 of 17238 Unread 04-05-2017, 10:54 AM
rokbyter's Avatar
Quoted: 49 Post(s)
Liked: 33
The manual states that the two outputs are mono (bold portion):
"Subwoofer Outputs (Balanced and Unbalanced)
The Halo Integrated provides one XLR connector and two RCA jacks for one or more
subwoofers. The two unbalanced and one balanced subwoofer outputs all carry the same
mono signal.
You can select whether the mono signal is full range or crossed over according
to the frequency you select for the Low Pass crossover.
Using Stereo Subwoofers
If you have two subwoofers and want them to operate in stereo you can connect them to
the Left and Right Pre Out jacks instead of to the Sub Output jacks which are mono. In
this case you would need to set the High Pass crossover switch to Off. With this
configuration the front panel Sub Level control does not function."
I wonder what the slopes are for each crossover - integrated vs sub. More research!
post #17225 of 17238 Unread 04-05-2017, 11:12 AM
rdgrimes's Avatar
Liked: 1512
mono signal.
Slopes (differences) aren't likely to be noticed much at 40Hz. Unless you combine and use them both, which is a no-no. Most music is rolled off at 40 anyway.
rdgrimes is offline
post #17226 of 17238 Unread 04-05-2017, 11:30 AM
rdgrimes's Avatar
Liked: 1512
I had one other thought on the crossovers. I assume it might be easier to access the sub's knobs than the amp's, so if you want to do a lot of fiddling it might be easier to just use the subs at first.
rdgrimes is offline
post #17227 of 17238 Unread 04-05-2017, 12:53 PM
rokbyter's Avatar
Quoted: 49 Post(s)
Liked: 33
You'd be right about that, but the crossover points on the integrated are better marked, so there's that. Continuously variable has its drawbacks, especially when only the top and bottom are labeled. If memory serves, the bottom frequency on the HTPS-400 crossover is 50Hz too, while the Parasound dips down to 20Hz. My thought on the slope was that perhaps if one slope was steeper than the other, it might be worth trying each to see which integrates better. The integrated has a 12dB/octave slope, but I'm not finding any information for the slope in the HTPS-400, though it's likely the same.
Like you said though, my plan is start with a 40Hz crossover and proceed from there, if needed.
post #17228 of 17238 Unread 04-05-2017, 01:27 PM
EZ-Rhino's Avatar
Liked: 32
Great news on the HTPS400's. I use 40-hz with mine as well.
EZ-Rhino is offline
post #17229 of 17238 Unread 04-06-2017, 07:49 PM
rokbyter's Avatar
Quoted: 49 Post(s)
Liked: 33
The arrays came today. They're fantastic. Pictures do not do justice to the finish on them; so much nicer than I expected. It amuses me that the woofers in my mains are now larger than my subs.
post #17230 of 17238 Unread 04-07-2017, 01:52 PM
Quoted: 14 Post(s)
Liked: 4
JBL Studio 220 vs JBL LSR 305
Any idea which is better, from a sound point of view? Cost is roughly the same, although the 220 would require an amp.
dcofficehack is offline
post #17231 of 17238 Unread 04-07-2017, 02:03 PM
rokbyter's Avatar
Quoted: 49 Post(s)
Liked: 33
I have not heard the 220s, but I have the LSR 305s on my computer desk at home and they are very, very good.
post #17232 of 17238 Unread 04-13-2017, 02:24 PM
rokbyter's Avatar
Quoted: 49 Post(s)
Liked: 33
What I like best so far is running the Arrays full range and no sub at all, which surprises me. I have not gone to the trouble yet of level matching the sub though, but in my first tests I could barely tell it was there.
Do you bi-amp yours? Mine were mistakenly shipped without the terminal bridges, so I just made some out of speaker wire, but it got me thinking...
post #17233 of 17238 Unread 04-13-2017, 03:24 PM
rdgrimes's Avatar
Liked: 1512
Any attempt at bi-amp should be a true bi-amp with external active crossovers and the like, otherwise don't bother. I agree they are pretty strong at 40 Hz, the only time I really hear much benefit from a sub at 40Hz is organ music or the like - with sustained LF. If you raise that to 60 or 80 you'll give your amp more headroom. Just enjoy them for now, they really don't need much help.
rdgrimes is offline
post #17234 of 17238 Unread 04-13-2017, 03:53 PM
rokbyter's Avatar
Quoted: 49 Post(s)
Liked: 33
From looking at the technical documents on them, it looks like the low and high frequency drivers have separate internal crossovers, so you could actually bi-amp. Here's the diagram:
And when I say bi-amp, I mean another amplifier for the other section, not all from one amp.
post #17235 of 17238 Unread 04-13-2017, 07:43 PM
rdgrimes's Avatar
Liked: 1512
But all you're doing is adding more power, and still using the same passive electronics.
rdgrimes is offline
post #17236 of 17238 Unread 04-14-2017, 06:44 AM
rokbyter's Avatar
Quoted: 49 Post(s)
Liked: 33
Right, but I thought the reason this was useless with normal speakers was because they don't divide the HF and LF sections, so you'd be sending all the power through the same board.
post #17237 of 17238 Unread Today, 10:21 PM
YonathanZ's Avatar
Quoted: 183 Post(s)
Hi, does anyone here own a JBL 235c center speaker?
If so, how does it compare with the rest of the Studio 2 series speakers?
Sent from my SM-G930F using Tapatalk
YonathanZ is online now
post #17238 of 17238 Unread Today, 11:05 PM
tom703's Avatar
Quoted: 30 Post(s)
I have a 235C that I am very happy with. I have a mix of Studio 2 and Studio 5, so I can't make the comparison you want. Of course, it matches my 230s. My primary use is for movies, and for this purpose, any mismatch with the 590s is so minimal that I have gotten used to it, that is if there actually is any. With this center, I can understand all the dialog in a movie, and this was my goal. When I get in a purist mood for music, I do not use the center, and the 590s provide a very nice center image.
The one thing that surprises many people is the size. This is a very large center, so make sure you have room for it.
Tom
Reply Speakers
520c , Athena , Center Channel Speaker Sku Pas749099 , Center Channel Speakers , Jbl , Jbl Balboa Sub 10 Inch Powered Subwoofer , Jbl G200 Bookshelf Speakers , Jbl Harman Kardon , Jbl Lc1 3 Way High Performance Dual 5 1 4 Inch Center Channel Loudspeaker Black , Jbl Lc2 4 Way High Performance 6 Inch Dual Wall Mountable Center Channel Loudspeaker Black , Jbl Northridge E30 2 Way 6 Inch Bookshelf Speakers Pair Black Ash , Jbl Professional , Jbl S Center Center Channel Speaker , jbl studio 5 series
