The OFFICIAL Jamo Speaker Owner's thread! - Page 193 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
Old 07-03-2015, 08:26 AM
witchdoctor's Avatar
Quoted: 754 Post(s)
Liked: 200
Is Jamo S-35 System Any Good?
I am considering getting the Jamo S-35 speakers for use as height channels in an Auro-3D setup:
http://www.amazon.com/Jamo-S-35-HCS-...=jamo+speakers
My main speakers are Paradigm Active 40, 20 and ADP. I like that these are so small making mounting easy and the omnipolar design,
Will this be a good match? Thanks
witchdoctor is offline
Old 08-24-2015, 06:09 AM
lemonslush's Avatar
Quoted: 823 Post(s)
Liked: 403
Anyone hear the D 600 THX speakers? They look halfway decent and are dirt cheap for a Ultra 2 certified speaker.
Wondering if anyone has actually heard them. I have not been able to find much about them online.
http://www.amazon.com/Jamo-D-600-LCR...words=thx+jamo
"we need more power" - My Wife.
Theater Build Thread - Wartooth
lemonslush is offline
Old 09-14-2015, 03:35 AM
nilankaperera's Avatar
Liked: 1
Jamo C91 Bookshelf speakers
Originally Posted by WILWRadio View Post
Has anyone listened to the new Concert Series speakers such as the C91, C93 etc. ? Can't find any reviews yet. Wondering what they sound like now that Klipsch has their engineers designing them.
Just got the Jamo C91 to replace my old Jamo A102. Do you think this will improve the sound quality?
pawel.brajczewsk likes this.
nilankaperera is offline
Old 09-14-2015, 04:31 PM
WILWRadio's Avatar
Quoted: 21 Post(s)
No idea. I can't find any reviews on the new line of speakers other than a couple on Amazon. I ended up buying a pair of 15 year old Jamo 68 3 way bookshelf speakers instead. They sound great and I got them for a mere $100.00. They are considerably better than the Jamo C601's I had been using for a couple of years.
WILWRadio is offline
Old 10-12-2015, 08:59 AM
Liked: 1
I just got a good deal on Jamo C91 and bought them. They sound great even at high volume. Much clear than the small Jamo A102 speaker set I used to have. Can anyone recomend any good AV Reciever to go with the new Jamo C91s? I currently run them on a Yamaha RX-V475 5.1 mode. Should I go for an upgrade?
Old 11-06-2015, 03:09 AM
pawel.brajczewsk's Avatar
Liked: 0
Hello to Everyone
My setup
Jamo classic 6 with center 160 all connected to denon AVR1611. I was afraid of overheating the Denon with those 4 ohm speaker but till now everything is okay.
Do you have some experience with this kind of connection ? Should I be worried?😓
I'm also searching for surrounding speakers for my system any suggestions? I was thinking about Jamo-Surround 200 but they are unavailable. Some alternative?
Thanks in advance
Wysłane z mojego SM-N910F przy użyciu Tapatalka
pawel.brajczewsk is offline
Old 11-23-2015, 02:41 PM
showmak's Avatar
Quoted: 198 Post(s)
Liked: 73
Any review on C109s?
showmak is offline
Old 01-17-2016, 04:10 AM
Abishek's Avatar
CC
i have bought E 570 old speakers used, i need to find a centre channel to timber match , i believe the exact match to it is Jamo E5CEN5: CENTRE CHANNEL SPEAKER. but its extremely hard to find now used in india. if i use a C09 or C10 instead its would not be a timber match?.Could any one advice. how about the E 6 CEN instead this is ported vs the E5 which is sealed.
Jamo E570 Floorstanding Front Speaker
3-Way 8`` Floorstanding speaker - the Jamo E570 also features a 1`` Neodymium Dome Tweeter - a powerful magnetic material 10 times more powerful than a normal magnet. It is rated at 100-170W.
The E570 is also equipped with MIR (Magnetic Interference Reduction) – a technology that reduces magnetic radiation from the loudspeakers, making it possible to place them close to a TV without distorting the picture tube.
Specifications:
System: 3 Way bassreflex
Woofer (in/mm): 8 / 203
Midrange (in/mm): 3 / 76
Tweeter (in/mm): 1/25 Dome
Power (w) long/short term: 100 / 170
Frequency Range (Hz): 45 - 20000
Impedance (ohm): 4
Dimension (W x H x D): 240 x 934 x 305 mm EA
Weight: 12.1 kg EA
ID:	1189874   Click image for larger version
Name:	Jamo E5CEN.5.jpg
Abishek is offline
Old 01-26-2016, 05:52 AM
eyoussef's Avatar
I know it's been discussed in this thread before but there are so many comments to go through, so my apologies, but what is the general consensus on the Jamo S426 HCS3 system? Gibby's has them for $180 and I'm looking for an upgrade from my hand me down Mirage Omnipolar speakers. I've heard mixed reviews on them and I'm not expecting to get big sound from them, just something to fill out the basement, I don't want to break the bank either. I'm going to be picking up a Denon AVR-S710W (maybe the 700W as a bundle on gibbys but I hear they're known for display failures). Would the speakers be useless with that receiver?
I should mention I'm in Canada so with the dollar it's hard to venture into US sites and I'm mostly looking for a home theatre system, not much music going to be played
eyoussef is offline
Old 03-25-2016, 05:47 PM
Liked: 102
I recently acquired a pair of E550's and can't seem to find much info on them (other than the C-Net article). Anyone have any thoughts or opinions on them?
Chaotic Bliss is offline
Old 03-28-2016, 07:56 PM
joey_truelove's Avatar
Got myself a pair of J110 subs a while back. These and the 112s are tighter and more precise than SVS 2000 series, and though the 110 in particular doesn't look like much it moves some serious air without lagging.
CowFish likes this.
joey_truelove is offline
Old 03-28-2016, 08:21 PM
infamo's Avatar
+1 on this......just got my j110 for $249 on woot.com.....great sub and I'd say you'd have a tough time telling the diff between the j110 and the r-110sw....
infamo is offline
Old 03-28-2016, 09:30 PM
That's a great price! On this side of the pond and neck of the woods those kinds of prices can only be had from Germany or The Netherlands. Got mine in black for perhaps $300 each (high quality cable included), seeing suggested price locally would be $600 a pop. Whites could be had for 275.
You actually A/B:ed the Jamo and the Klipsch then? Never got the chance to myself but according to Area DVD (via Google Translate) their opinion was the Jamo actually has the edge on the Klipsch in precision and rated 1Hz lower. But obviously they're about the same size, feature identical amps and the drivers are of Klipsch propriatory designs so I'm sure they're very much fruits of the same tree.
Old 03-28-2016, 09:50 PM
showmak's Avatar
Quoted: 198 Post(s)
Liked: 73
At least this thread is breathing now!
Sent from my iPhone6s+ using Tapatalk
MB_HT likes this.
Sony BRAVIA XBR55HX929, Yamaha Aventage RX-A3050, Front Mains: Jamo C109, Surrounds: Jamo C103, FH/RH: Jamo C93, Center: Jamo C10 CEN and Subwoofer: Jamo J112 SUB (5.1.4)
showmak is offline
Old 03-29-2016, 05:48 AM
infamo's Avatar
I haven't A/B'd them side by side, but I have a buddy who has a klipsch 112 which def moves more air (obviously due to it being a 12" and not a 10") but in terms of quality, it'd be hard to tell a difference.
The rest of my speakers are Klipsch as well (synergy series) so my sub has fit in quite well....i'd give it 8/10...
infamo is offline
Old 03-31-2016, 11:04 PM
I can tell they would as they utilise same material woofer drivers. You mean in aesthetics or in performance?
Would have been interesting to A/B the two brands though, I think. Jamos are supposed to be quite neutral throughout their range, a bit like SVS subs in this respect, just not as subsonical. Klipsches are supposed to be peakier and have more slam to them.
I so wish Jamo would make a 15" corresponding to the Klipsch 115, but perhaps they figure the ample amount of push would be more apt to the Klipsch brand.
In case I didn't say: I'm a fan of the skids on which these subs rest as these seem to decouple the sub from the floor in a rather positive way.
The only gripe that springs to mind would be the auto-on which produce a very audible pop at power-on. And these beasts being so loud the input sensitivity is a bit compromised from having the input signal set so low. This means they go into energy-save mode halfway into a movie and is then brutally turned back on in climactic scenes.
The J110 review https://translate.google.se/translat...r%2F&sandbox=1
The J112 review https://translate.google.se/translat...e%2F&sandbox=1
Old 05-22-2016, 12:09 PM
RenEH's Avatar
Quoted: 23 Post(s)
Liked: 25
Picking up a second set of Jamo c607's for my current HT running 2x c607, 2x c603 and one c60 cen. Are the c607's overkill for rear or sides?
CowFish likes this.
RenEH is offline
Old 05-22-2016, 01:04 PM
showmak's Avatar
Quoted: 198 Post(s)
Liked: 73
I don't have idea about C607, but I'm using C103 for surround, and I'm happy.
showmak is offline
Old 05-22-2016, 03:15 PM
wouldtoo's Avatar
Quoted: 24 Post(s)
I think it would sound great.
wouldtoo is offline
Old 06-03-2016, 04:00 AM
Soulviolence's Avatar
I know there's not much going on here at the moment, but I have to say I think I might have a sickness. I got into Jamo speakers back when the S606 set had just sold out at Vanns. Since I couldn't get those, I scoured ebay and craigslist till I found a pair of Jamo 507a's. Wow! Beautiful and beautiful sounding! I have since found and hoarded a pair of 707i, 407a, center 160, 2 center 200, 3 d500 lcr, pair of cornet 195, 165, 145 and surround 200 plus a d5sub. Like I said, I may have a sickness...
CowFish likes this.
Soulviolence is offline
Old 10-24-2016, 12:04 PM
chappatti's Avatar
Thumbs up Wanting to buy used Jamo speakers........
I would really love to buy a pair of used vintage Jamo Classic 10 speakers? Or Classic 8 or 6? Cannot find any anywhere....... Maybe someone this thread is "throwing" them away, or know somebody who is....
Seriously willing to buy........at reasonable price.
chappatti is offline
Old 10-24-2016, 08:53 PM
Liked: 0
Jamo e825
Hi all,
These JAMO E825 bookshelves have been with me since new, around 2006. They've served me very well and although they're not the brightest, most revealing speakers they keep surprising me with how dynamic and musical they sound. Definitely a keeper.
I just realized I don't have any good pics of just them, will have to take some in the daylight.
I run them without the grills and have blacked out their silver 'soul patch'. Within the next few days I'll be building new stands for them, gave the old ones away. While looking for stand ideas I stumbled across this thread.
The TEAC A-H500 amp has been driving them since new and they're quite a good match.
Just moved into a new listening room, hence the bare walls:
CowFish is online now
Old 10-24-2016, 08:59 PM
Liked: 0
Pics or it didn't happen!
Old 10-25-2016, 08:18 AM
chappatti's Avatar
Anybody?? Any info??
Old 11-23-2016, 11:14 PM
Quoted: 25 Post(s)
Liked: 0
Jamo 628
Lads, can you please give your feedback on Jamo S628 Towers. I am trying to find reviews on it. Anyone using it? I liked Klipsch but their RP series is very expensive.
khanbaba is offline
Old 11-28-2016, 06:58 PM
stash64's Avatar
Quoted: 255 Post(s)
Liked: 91
Concert Series
Just a heads up to anyone who might be interested... I have posted my 5.0 Concert Series system for sale in the Audio Classifieds, consisting of:
2x Jamo C809
2x Jamo C803
1x Jamo C80CEN
I will consider breaking it up, but only after giving it a week or two to sell the complete system.
I'm giving KEF and Canton a try, and hoping I will enjoy the new speakers at least as much as I did the Jamos.
Sean
stash64 is offline
Old 01-11-2017, 12:33 PM
vannuge's Avatar
Hi Folks. I may buy a used pair of Jamo C803, but I wanted to get some input from you folks. I have a pretty basic receiver (Panasonic VSX 520, 110 watt), but do I need a better receiver/dedicated amp to power them? Also, what would be a suitable center speaker to match them that are easily found for sale? I'd prefer the C80 CEN but I doubt I could find it anywhere.
I'm going to buy them for $200, with some cosmetic damage, but I think it's still a pretty good deal. I'm upgrading my Energy Take 5s, so I'm not in a rush to find new fronts and I'm open to hearing other suggestions. Thanks!
vannuge is offline
Old 04-25-2017, 09:47 PM
Liked: 1
I just ordered the Jamo J110 (wood finish) for $180 on Ebay.
My old Elemental Design A3-300 died and I don't really need a sub that big anymore.
I am hoping the J110 moves some decent air, it will mostly be used for music.
CowFish likes this.
Nick Johnson is offline
Old 04-26-2017, 09:20 AM
RenEH's Avatar
Quoted: 23 Post(s)
Liked: 25
So I can say that using Jamo 607's as rears is not overkill, they sound amazing. I was previously using 603's, but when watching a movie with good rear audio, or using Kodi to upsample my flac collection to 5.1 it's a big step up.
With that said, I used my old 603's in my bedroom with a HSU VTF3MK2 and added a c60 cen I picked up for $30 on craigslist. and I'm shocked out how good they sound. I bought a very cheap Onkyo 353 to run this set up and and it really is great step up from the TV speakers on my panny plasma.
How do I convince the wife that we need a 5.1 setup in the bedroom
RenEH is offline
Old Today, 08:29 AM
Liked: 0
Nice score!
I just received a JAMO J-112, bought on ebay for $220 in gloss white.
After a few hours of break in it's starting to sound very good! Super happy with the purchase.
In other news, I gave away the JAMO E-825s that were with me for over 10 years, because the highs were too rolled off / dull. One A/B listen with some NHT speakers was the final blow to replace the JAMOs (after years of running them with the treble boosted).
The NHTs sound phenomenal without any eq.
Jamo , Jamo Closed Subwoofer , Jamo S 426 Floorstanding Speaker , Jamo Sub 800 Subwoofer , Jamo S 506 Hcs 3 Home Theater System , Jamo S 606 Hcs 3 Home Theater System , Jamo A 804 Lcr Speaker , Jamo 7 W Center Speaker Black , Jamo D 500 Sur Lcr Speaker , Jamo S 426 Hcs 3 Wenge 5 Piece Home Theater System Wenge
