Martin Logan Owners Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 190Likes
post #541 of 2119 Old 01-02-2014, 10:23 PM
panzer's Avatar
Quoted: 24 Post(s)
I have 1 pair of golden ear aons 3's and 1 golden ear super center X, that I would trade for a martin logan motion soundbar.if interested pm me, thanks
panzer is offline
post #542 of 2119 Old 01-03-2014, 12:30 AM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
I am looking for ML slim XLx3. Possible trade in, swap for Encorex3
zoro is offline
post #543 of 2119 Old 01-15-2014, 11:33 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3352 Post(s)
Liked: 3322
Question for the forum: I was watching Don Jon last night and during a club scene I heard my right rear motion 15 distort during the low bass moments. I switched the left and right and the same thing happened. I have the Crossover set at 80Hz for the rears and they are supposed to be rated to 60Hz. I changed the crossover on the Pre-pro (Marantz 8801) to 100Hz and it did not distort. I don't want to have my crossover set at 100Hz while my center is 80Hz and fronts are full range. Do you think it is something wrong with the woofers on the speakers? Any other ideas? Your help would be greatly appreciated.
I have never heard distortion from my LX16, but I'm using mine for wide channel speakers. Are you using the speaker for surrounds ( you say right rear )? Are you running a subwoofer? I have never heard any of my surround speakers distort even at ear splitting beyond reference level volumes ( ML or otherwise ). After running Audyssey, and setting crossovers at 80 or 100Hz on the surrounds ( why are you running fronts full range if you do have a sub ? - should probably be set at 60Hz ) I've never gotten the surround channels loud enough to distort. My wife would distort my head at those volume levels.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #544 of 2119 Old 01-18-2014, 01:05 PM
whitecamaross's Avatar
Quoted: 18 Post(s)
Anybody selling the em c2 center channel.? I need one asap..please text me 305 934 0434
whitecamaross is offline
post #545 of 2119 Old 01-18-2014, 04:51 PM
Goat1's Avatar
I have.. I had gloss black RX8's and they were very nice.. The ML's are just better in every way. With the dipole sound it lights up the whole wall and the sounds you get from music is insane.. You can almost pin point every instrument in space. The sound stage is wide and deep. The RX8's are great tho,but I went with ML Electromotion ESL's. They are awesome for home theater also. I'm using ML motion 4's for height speakers also. It adds another dimension to the sound for movies,but not music. I also have a XS30 to fill the bottom end.. Sounds absolutely brilliant..
Goat1 is offline
post #546 of 2119 Old 01-18-2014, 04:52 PM
Goat1's Avatar
Does anyone on here have a depth i or decent i? I'm curious how it sounds..
Goat1 is offline
post #547 of 2119 Old 01-19-2014, 07:10 AM
liltalkm's Avatar
Quoted: 205 Post(s)
Liked: 274
I see you have a 305 area code. Check with Sound Advice. They have two stores. One in Lauderdale and one in Boca. Easy to deal with.
I have dual Depth i's and they sound great. Having said that, I would love to get a hold of a couple of the new BalancedForce subs from ML.
Audio Advisor is running great deals on the Depth and Decent i's as they are being closed out.
(Theater)Speakers: Martin Logan Montis, Stage X, Dual Depth I Subs, Vanquish in ceiling (surrounds) | Processor: Marantz AV8802(A) | Amp: Three Moon Simaudio 400m monoblocks,One Moon Simaudio 330a, PS Audio Directstream | Sources: DirecTV HR54, HTPC, Mac Mini, Oppo UDP-203, PS4 Pro, Xbox One S | Television: LG 77G6P | Remote: Logitech Harmony Elite
(Bedroom)ORB Audio Mod 2 5.1, Yamaha RX-A2050, LG 55E6P, LG UP970, Harmony Elite.
liltalkm is offline
post #548 of 2119 Old 01-19-2014, 07:36 AM
AVfile's Avatar
Quoted: 271 Post(s)
Liked: 137
Awesome deal! At those prices it should be a no-brainer.
I recently got a Descent i and I'm very happy with it. It replaced a mighty Mirage BPS-400. I think it is on par with the Paradigm Sub-1 at less than half the price.
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is offline
post #549 of 2119 Old 01-19-2014, 10:14 AM
jake9's Avatar
Quoted: 18 Post(s)
Hi, folks. Question from a ML newbie. I have the opportunity to purchase a set of ML Quest stats for about 1k USD. They are from 1991, so they are pretty old. I will most likely have to upgrade my amp as it may stress my current AVR. What do y'all think about this? Good deal or am I about to go down the rabbit hole?
Oppo BDP-105D | Parasound Halo A 21 | Parasound Halo P 5 | Rega Planar 3 | Martin Logan Theos | Martin Logan Dynamo 1000
jake9 is offline
post #550 of 2119 Old 01-19-2014, 05:59 PM
|Tch0rT|'s Avatar
Quoted: 185 Post(s)
Liked: 128
You're probably going down the rabbit hole. Those are old enough that they might need new panels and that's expensive. I'm not sure on particular cost on that model but I wouldn't be surprised if they cost $1500 or more. The older ML panels only last about 20 years from what I gather so it's kind of a crapshoot. You can give the panels a bath (look it up on MartinLogan Owners forum) or make your own replacement panels. IMO you'd be better off buying a newer model which won't be as hard on your current AVR.
My Home Theater/Video Gaming/HTPC/2 Channel rig (Mitsubishi, MartinLogan, Marantz, DIYMA, and others)
|Tch0rT| is offline
post #551 of 2119 Old 01-19-2014, 06:10 PM
Quoted: 18 Post(s)
guys, the panel does not work on one of my electromotion esl's.. why? the woofer works, but i have tried switching power supplies, tried changing speaker posts on the amp, new speaker cable, etc and i cant get the panel to sound loud like the woofer..i have to get my ear really close to it in order for me to hear just a little bit of high frequencies and mids.....please help... i tried vacumming the panel and also tried cleaning the binding posts with alcohol and nothing.... hellp please..
post #552 of 2119 Old 01-19-2014, 09:36 PM
|Tch0rT|'s Avatar
Quoted: 185 Post(s)
Liked: 128
I'd call ML about that problem ASAP.
|Tch0rT| is offline
post #553 of 2119 Old 01-19-2014, 09:39 PM
jake9's Avatar
Quoted: 18 Post(s)
Thanks for the reply. Having to buy new panels would kill me after buying them. Don't wanna do that. My girlfriend said the same thing about a buying a newer model instead. If I do that, the ElectroMotion ESLs are most likely what I would be looking at. My Denon AVR-2312CI is rated down to 6 ohms 135W/channel, which is within range of ML's recommendations, but I know that often doesn't tell the whole story.
jake9 is offline
post #554 of 2119 Old 01-19-2014, 09:52 PM
|Tch0rT|'s Avatar
Quoted: 185 Post(s)
Liked: 128
Depending on your room size you'll probably be fine with that AVR. My EM ESL's are a little more than 65" apart and I sit 8ft away from them and they got plenty loud without distortion when I ran them off my ancient Marantz SR7200 (110watts @ 8ohm, dunno the 6ohm rating) AVR. I later added a Marantz MM9000 amp (170 watts @ 8ohm/230watts @ 4ohm) and it just makes them louder without distortion and when it goes from quiet to loud the louder part had a higher ceiling (I only notice this on like classical and jazz, no so much with rock/metal or electrically amplified instruments).
|Tch0rT| is offline
post #555 of 2119 Old 01-20-2014, 02:50 PM
Holiday121's Avatar
Quoted: 550 Post(s)
Liked: 148
Purchased a new pair of Esl for my fronts should be here in a week. They will be matched with a Martin Logan theater center channel and a pair of motion 10s for my rears.
Picked up a psa xv15 as well and hopefully will have that this week. How is that xv30?
Are you watching movies on those Esl?
Holiday121 is online now
post #556 of 2119 Old 01-20-2014, 03:15 PM
Nighthawk26's Avatar
In 4-6 weeks, I should be up and running with my Theos fronts and Stage X Center which will be powered by 3 Emotiva XPA-1's. sadly they will be behind an AT screen so wont even see them. frown.gif
Nighthawk26 is offline
post #557 of 2119 Old 01-20-2014, 06:15 PM
Holiday121's Avatar
Quoted: 550 Post(s)
Liked: 148
Wow very nice.
post #558 of 2119 Old 01-21-2014, 10:26 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 3322
If anyone reading this thread is in Northern California ( Sacramento area ) Sat., Feb 8th, I am having a home theater demo day, including my 11.2 channel Martin Logan Motion series speakers ( SVS subs ) -
http://www.avsforum.com/t/1512482/av-science-home-theater-equipment-demo-day-saturday-february-8th-2014-sacramento-ca-area
post #559 of 2119 Old 01-21-2014, 07:38 PM
Holiday121's Avatar
Quoted: 550 Post(s)
Liked: 148
Wish I could make it but I'm to busy freezing here in ohio
post #560 of 2119 Old 01-23-2014, 09:48 AM
jake9's Avatar
Quoted: 18 Post(s)
Still thinking about getting these. A little concerned if my amp will power them sufficiently as everywhere I look it seems guys are powering them with some serious juice. My room is about 16' x 15' w/ an average 8 foot ceiling. The room is open to the hallway and kitchen, however. Thanks for providing your experience so far. It helps.
jake9 is offline
post #561 of 2119 Old 01-23-2014, 11:51 AM
sdolen's Avatar
Quoted: 50 Post(s)
Liked: 31
I run my EM ESLs with a 60wpc Rogue Audio tube amp in a 2ch rig with plenty of headroom. That being said, when I ML Clarity in a HT setup and added a Rotel RB990BX to my Onkyo TXNR1008 , it was a pretty substantial improvement. I believe that to be the mediocre amps in the Onkyo.
sdolen is offline
post #562 of 2119 Old 01-23-2014, 01:34 PM
simp1yamazn's Avatar
Quoted: 111 Post(s)
Liked: 78
Hm, asking if a better amp will improve sound quality. Big can of worms with that kind of question wink.gifbiggrin.gif All I will say on the subject is that tons of people run them with high quality AVRs (upper end denon, marantz, or pioneer) and just as many people run high-end high-powered amps. And with that, I'm running away from this subject!!!
simp1yamazn is offline
post #563 of 2119 Old 01-24-2014, 03:38 PM
SubSolar's Avatar
Quoted: 119 Post(s)
Liked: 40
Excellent have Theos and Stage myself and love them!
Samsung 85" 4K, Dolby Atmos 7.1.4 with MartinLogan Theos, Stage, Motion 15, EM-R, Seaton Submersive F2, Denon AVR-X5200W
SubSolar is offline
post #564 of 2119 Old 01-27-2014, 07:24 AM
EvanDef's Avatar
(Moved to "Martin Logan Owners Thread")
Hello there fellow enthusiasts,
I have a simple setup including a single ML Dynamo 200w 10" sub in a relatively small room. Recently the sub will no longer work. I did the usual checks of the power cord, settings and connection to the reciever (Pioneer Elite VSX-52). The fuse was blown so i replaced it which it fried once again. The next fuse i plugged in did not fry but the unit will not turn on.
I am pretty handy with a soldering iron and not afraid to take that sucker apart but i was look for suggestions in the event the repair is beyond my capability. There was very light use out of the sub so the speaker and cabinet are fine. Some options I was exploring would be first to fix it, going after the fried component in the exisiting unit. Second would be to replace the plate amp with a similar or better one; or if this is even an option, bypass the amp using a direct connect and have the reciever power the sub through speaker wire.
Any thoughts?
Thanks all, Evan
EvanDef is offline
post #565 of 2119 Old 01-27-2014, 09:10 AM
liltalkm's Avatar
Quoted: 205 Post(s)
Liked: 274
Any thoughts?
Thanks all, Evan
You may want to email Dana at martinlogan. His email is dbrown@martinlogan.com
Let him know your problem and he should give you some good advice.
liltalkm is offline
post #566 of 2119 Old 01-27-2014, 10:24 AM
EvanDef's Avatar
Thanks, i just sent him an email.
EvanDef is offline
post #567 of 2119 Old 01-27-2014, 05:13 PM
newAVphile's Avatar
Quoted: 17 Post(s)
Liked: 25
I have a couple Descent i's thanks to Audio Advisor's sale, and I love them. I have them playing with my Montis and I have plenty of bass, more than I need. I will say that in comparison to my 1 SVS PB13-Ultra they aren't perfect. My short story: I had a PB13-Ultra and it shook my house and gave me all the deep bass I wanted, and it was awesome. I bought my Montis speakers and the bass was cancelling out probably because I had sealed and ported bass modules fighting each other. I sold my SVS and bought 2 Descent i's. They integrated much better. The Descent i's sound phenomenal and I still have plenty of slam for movies, but I will say that my 1 SVS produced more extreme low end punch. If I had to pick between them, I'd still go with the Descent i's because they are so good at what they do, but I'm really excited to see what the 212's can do.
My work in progress: Sony KDL65w850a, Oppo 105D Darbee edition, Marantz 7702, Marantz 8077, W4S mAMPs, W4S DAC1-LE, Sonus Faber Olympica III, Dual Funk Audio 18.0, Sonos, ML center and surround speakers, cheap Onkyo Atmos speakers for now, decent cables (Cardas, Pangea, Bluejeans), APC H15 power conditioner, Logitech Harmony Ultimate (for the wife obviously), Roku, minimal GIK acoustic panels...
newAVphile is offline
post #568 of 2119 Old 01-27-2014, 06:19 PM
liltalkm's Avatar
Quoted: 205 Post(s)
Liked: 274
I will sell my depth i's one day to get a pair of 210's or 212's. I really want to use/try the Perfect Bass Kit sub eq it uses.
I am more than happy with my Depth's but I can only imagine what the Decent's must sound like. cool.gif
Montis is awesome.
newAVphile likes this.
liltalkm is offline
post #569 of 2119 Old 01-28-2014, 06:04 AM
Holiday121's Avatar
Quoted: 550 Post(s)
Liked: 148
Looking for some help for my new ESLs. Trying to figure out which would be the best way to setup for home theater use.
Should I leave the rake as is or should
I tilt it forward. The speakers are actually on my stage so it puts them around a foot or so above ear level
post #570 of 2119 Old 01-28-2014, 07:26 AM
liltalkm's Avatar
Quoted: 205 Post(s)
Liked: 274
I would think with that elevation you should try to get them as close to 90 degrees as possible.
But ultimately you will need to experiment as the panels imaging changes quite a bit with its rake and toe angles. For what its worth, I have tilted my Montis forward quite a bit, not quite 90 degrees, but close. Mine are pretty much on the floor except for the spikes and the Aurelex Sub Dudes they are on.
liltalkm is offline
Reply Speakers
Polk Audio Monitor 50 2 Way Floorstanding Speaker Single Cherry
