SURROUND SPEAKERS - Bipole, Dipole, Quadpole, Omnipole... WHICH ONE? - Page 11 - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: There are many surround speakers out there now, but the ones below would have to get my highest reco
Mirage OMD5 (or any other Mirage Omnipole) 48 21.24%
JBL P520WS / Infinity ES-250 / Infinity Classia C255ES (Dual-monopole for 4 channels from 2 speakers, but also Bipole & Dipole switchable) 15 6.64%
Axiom QS8 or QS4 (Unique Quadpole design) 56 24.78%
Paradigm ADP (Many models available with this design, where the tweeters run Dipole, but the woofers are Bipole) 44 19.47%
Monitor Audio BXFX or RXFX (Single woofer, but the tweeters can switch to either Dipole or Bipole) 26 11.50%
Monitor Audio GXFX (6 drivers, including a ribbon. (Monopole / Dipole switchable) 23 10.18%
KEF 26/2DS (Dipole only, alas... but with two 6.5 inch side woofers and a front-firing 8 inch!!! ) 20 8.85%
Multiple Choice Poll. Voters: 226. You may not vote on this poll
 36Likes
post #301 of 982 Old 10-06-2011, 03:14 AM
norcis's Avatar
hi everybody,
I got Monitor audio BX2, BX1 and BXFX with Yamaha 3067 AV receiver (centre and sub are coming next). Could could please advice how to place them?
Room is 5.5m x 3.5m. with corner sofa at the end of the room side to the wall. Look at attached image for current placement.
As BXFX has Di/Bi-pole switch and I'm thinking to put it on the walls parallel with listing position at the end of the sofa, and with 90 degrees with the wall with windows.
I can place BX1 on windowsills which is 1 feet above and 1 feet away from listeners ears. Also I could use Yamaha's presence and place these speakers in the front top corners as height speakers.
What do you think?
norcis is offline
post #302 of 982 Old 10-07-2011, 02:49 PM
Timothy91's Avatar
Liked: 37
I found another speaker with a multi-pole design that is quite promising:
The Legacy Phantom HD
http://www.home-theater.com/index.ph...mart&Itemid=89
Timothy91 is offline
post #303 of 982 Old 10-09-2011, 03:17 PM
mlknez's Avatar
Quoted: 222 Post(s)
Liked: 60
How important is it for the surround speakers to match the front and center? I have expensive fronts and center and the company does not make an on-wall surround. They are ribbon mids and ribbon tweets. Any suggestions for alternative speakers to use?
mlknez is offline
post #304 of 982 Old 10-09-2011, 03:43 PM
goros's Avatar
Liked: 35
They don't need to match perfectly. I would try to match the tweeter size and material (don't mix horns and domes, fabric and aluminum) and try to keep the drivers around the same size and frequency response to get as close to voice matched as you can.
goros is offline
post #305 of 982 Old 10-09-2011, 06:25 PM - Thread Starter
Electric_Haggis's Avatar
Quoted: 24 Post(s)
Nah. I've tried every possible configuration over the years, including identical satellites (NHT) and even near-matching towers (VAF Research DC7, a smaller version of my front DCX towers).
Personally, I found that having different-brand surrounds was a non-issue, so long as the sonic signature was a close enough match - especially these days with Audyssey EQ.
(Having an identical centre speaker, on the other hand... very important!)
Electric_Haggis is offline
post #306 of 982 Old 10-11-2011, 03:45 PM
dunan's Avatar
Quoted: 62 Post(s)
Originally Posted by dunan View Post
Hey I'm looking for some bi-poles, but the only ones I seem to be interested in so far is the emotiva ERD-1s but they are 4 OHM, and my receiver is a Denon 3310. Seeing as they will only be pulling surround duty, will they be OK?
Anyone have any insight on this? Also, will they work on a back wall that my couch is up against?
dunan is offline
post #307 of 982 Old 10-11-2011, 06:03 PM
Knucklehead90's Avatar
Quoted: 504 Post(s)
Liked: 435
Yeah - I'm on my second set of these. Unless you have a very wimpy AVR buy them. They are very good at what they do.
Yamaha CX-A5000 - VTA ST-120 (6550 output tubes) - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - Acurus A100 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #308 of 982 Old 10-11-2011, 06:23 PM
dunan's Avatar
Quoted: 62 Post(s)
You mean second pair as in you blew them or got a second cause you liked them? A Denon 3310 is the AVR, but seeing as these are 4ohm, hopefully they should work just fine, at least in the reviews they did on an average receiver ( i think).
I'm more concerned about how they will perform on the wall right behind me.
dunan is offline
post #309 of 982 Old 10-13-2011, 03:56 PM
mlknez's Avatar
Quoted: 222 Post(s)
Liked: 60
Can I get a recommendation for a good pair of diplole/bipole on-wall surround speakers to go with my Piega P10 fronts and coax center? The room is 15x15 that is open on 2 sides and has a cathedral 2 story open ceiling. It needs to have either a white or black finish. The Piega speakers use ribbon tweeters and midranges. My amps are stable for a 4ohm load and are rated at 200wpc 8ohm and 350wpc 4ohm.
Thanks in advance
mlknez is offline
post #310 of 982 Old 10-28-2011, 12:48 PM
Warder45's Avatar
Quoted: 28 Post(s)
Hi all,
Attached is a mockup of my living room. I'm trying to find the best surround option since I don't think 7.1 is an option and with the configuration there isn't really a sweet spot.
Would Bipoles or the before mentioned dual-monopoles be the best solution to diffuse the surround audio for everyone in the room?
Thanks - John
Warder45 is offline
post #311 of 982 Old 10-28-2011, 03:11 PM
mlknez's Avatar
Quoted: 222 Post(s)
Liked: 60
Originally Posted by Warder45 View Post
Hi all,
Thanks - John
Could you do ceiling mounted speakers?
mlknez is offline
post #312 of 982 Old 10-31-2011, 05:19 AM
Warder45's Avatar
Quoted: 28 Post(s)
Yep, the attic above is all open, I was planning on running the wires that way as well. Would mono/di/bi - pole in ceiling speakers work best? Where would you stick then, above the seating or behind it?
The only con with in-ceiling would be the more "permanent" nature vs a tiny hole in the ceiling for speaker wire for wall mounted.
Warder45 is offline
post #313 of 982 Old 11-02-2011, 10:55 AM
Timothy91's Avatar
Liked: 37
Hi all,
Thanks - John
I have been trying to put together an idea for a 5.1 combo for small/mid sized rooms.
A wall-mounted Pinnacle QP-9 sound bar (or placed at the base of the TV) can be had on ebay and other places for under $500.
The surrounds can be any of the Mirage Omnipolar series speakers (floor standing towers or wall mountable bookshelf models).
Buy an affordable sub like one of the BIC subs for under $250.
That will give you a system that is discrete and will sound GREAT for around $1000. The titanium based tweeters on will be a ballpark match and with a good auto-tune up from a nice A/V receiver, the speakers should all sound pretty close. My next home theater will be using the Mirage omnipolar speakers as surrounds. Depending on the proximity and space available, I may end up using a nice LCR sound bar under big TV both wall mounted. I found the Pinnacle speakers have a titanium-based tweeter, so there is a good chance at similar character/voice between the speakers after an auto-calibration is run on an A/V receiver.
This setup will only be as dynamic and strong as your subwoofer choice. This speaker system will only work well in a room that is around 2000 cuft or less. If the room is larger, you'll need to look into higher efficiency speakers.
For room acoustic purposes, it's my opinion based on much research that ANY room being used for the purposes of sound reproduction NEEDS to be carpeted and furnished, and if it's a large enough room, it will need sound-absorbing wall treatments. If your room has tile, nothing will sound good. (At least, that has been my experience).
post #314 of 982 Old 11-08-2011, 06:58 AM
carter840's Avatar
Anyone have a suggestion of a good surround speaker to pair with my Polk Monitor 70's and CS2? I am looking for better rear channel than the Polk monitor 30 are providing. I just made a really rough sketch of my room. The issue I have is that there are two columns that protrude from my rear wall and prevent optimal placement. One side of the room is also open. I am wondering if using dipole speakers could help get more presence in my rear channel. Also as it stand the rear speakers are elevated about 4 feet above ear level of the listener, but then are aimed down. I have run audyssey in case you were all wondering. My budget is no more than $300 for both rears.
carter840 is offline
post #315 of 982 Old 11-08-2011, 08:29 AM
centauro74's Avatar
I have the fxi-a6 and absolutely love them, I bought them from the Polk eBay store and they look new with 2 years warranty.
centauro74 is offline
post #316 of 982 Old 11-11-2011, 07:10 AM
Michael James's Avatar
Quoted: 76 Post(s)
Wanted to see if you had some suggestions. Take a look at the photo below.
I need to replace the in-wall direct firing speakers. Due to WAF, would like to keep with a in-wall design. Any suggestions here?
I'm using Focal 918's w/metal tweeters and a Speakercraft Center angled down to the listening position. The Onkyo PR-SC885 is using audyssey. I play 60% movies, 40% music
Couch is against the back wall. Rear Channels are 6 feet off the ground (6 feet to the bottom of each speaker) and Right Rear and Left Rear are 5 feet apart at the edges of the couch.
From my ear to the bottom of the current in-walls is 3 feet. The current in-walls with frame are 12" long.
Any help is greatly appreciated. (I used a Sony Camera with panorama to take the photo..which is why it looks a little strange)
Michael James
Cincinnati, Ohio
Michael James is offline
post #317 of 982 Old 11-12-2011, 11:04 AM
Quoted: 76 Post(s)
Are there any good in-wall Bipole Speakers, that can be switched to Dipole? I assume you would have to re-run Audessey when you do the switch
Michael James
Cincinnati, Ohio
post #318 of 982 Old 11-12-2011, 03:51 PM
centauro74's Avatar
Man does your neck hurt after a movie. That tv is really high.
post #319 of 982 Old 11-12-2011, 06:01 PM
Quoted: 76 Post(s)
you get used to it..when laying your head on the top of the couch, its kinda a natural angle..similar to laying reclined in a lazy boy
Michael James
Cincinnati, Ohio
post #320 of 982 Old 11-13-2011, 08:25 AM
Quoted: 76 Post(s)
Michael James
Cincinnati, Ohio
post #321 of 982 Old 11-13-2011, 08:47 AM
Vaison's Avatar
I'm considering getting a BIC Acoustech 5.1 system, which incorporates the PL-66 surrounds (pictured at the bottom of my post).
My couch will be against the back wall and I'd like advice as to where I should put the surrounds? My thoughts were the side walls as I'm not sure having speakers right at my head that close, would be ideal. But if these should be on the back wall, at what height? The room is just under 8' high. Can someone help? Thanks.
Vaison is offline
post #322 of 982 Old 11-13-2011, 04:36 PM
Quoted: 76 Post(s)
I have found the following that are in-wall switchable between bipole and dipole..any thoughts?:
Jamo IW 606
PSB CW260
Atlantic Technologies IWTS-14 and IWTS-30SR-P
SpeakerCraft AIM CINEMA DIPOLE Three IN-WALL
**I have the couch against the back wall, can't move, no space**
Michael James
Cincinnati, Ohio
post #323 of 982 Old 11-17-2011, 08:46 AM
Maxs_dad's Avatar
I have dilemma similar to those you are experiencing. Seating position is along the back wall and cannot be changed. Some logic seems to be pointing towards dipole purchase with placement in line with the seating, but I have some remaining concerns about this side-wall placement so close to the back wall.
I have found it quite frustrating that every reference diagram is based on the premise that seating is in the center of a room, even though the reality for most of us is that we simply do not have the space for such an arrangement.
Maxs_dad is offline
post #324 of 982 Old 11-17-2011, 04:24 PM
Quoted: 76 Post(s)
I really hope that someone responds back with an educated opinion!!!
I need to make some selections here soon
Michael James
Cincinnati, Ohio
post #325 of 982 Old 11-18-2011, 05:06 AM
goros's Avatar
Liked: 35
Honestly, audio setup in most cases is about compromise, either with budget, or with placement, or with size.
Sometimes it's all 3.
My advice, try a few different speakers before committing to one solution and see what you like best.
goros is offline
post #326 of 982 Old 11-18-2011, 05:24 AM
Theresa's Avatar
Liked: 51
I don't think anyone mentioned the Emotiva ERD-1 which I've found to be a very good surround. My fronts are DIY and very different but still there is no problem with them having a different "signature."
Theresa is offline
post #327 of 982 Old 11-18-2011, 09:16 AM
Quoted: 76 Post(s)
I know there are a lot of "on-wall" solutions like the Emotiva, but I'm looking for an in-wall. With in-walls, its reall hard to "try out" products without ruining your walls. That's why I was asking if anyone has experience with any of the following. As a side not, I saw the pair of Atlantic Technologies IWS-30SR-P's going for $500 (retail is $1500)
Jamo IW 606
PSB CW260
Michael James
Cincinnati, Ohio
post #328 of 982 Old 11-18-2011, 09:31 AM
Maxs_dad's Avatar
Just to add another data point here I wanted to relay the gist of my conversation yesterday with a customer support specialist (technical fella) from Emotiva. I had called to express some concern about using ERD-1 (well thought of on-wall dipole/bipole surround speakers) in my application. This is a small room used for TV/movies/games with the seating all along the rear wall. Placement-wise, the speakers would have to be very close (within a foot) of the rear wall in order to get that row of seats in the correct null position. My concern was that the diffusion effect would get lost because of the speaker's proximity to the back wall. The Emotiva rep agreed without any reservation and instead recommended in-wall monopoles for this particular application.
I always treat vendor advice with skepticism, especially those cases where they point you to another, more expensive product. However, their in-wall speakers are half the price of the ERD-1 so that doesn't seem applicable here. I am inclined to accept this argument but would be interested in any other comments.
Maxs_dad is offline
post #329 of 982 Old 11-21-2011, 10:11 PM
masterbrain's Avatar
I ran across a pair of Fosgate Audionics Dipolar SD-180 THX surround speakers (John Dunlavy's design) I can't find any information on the rear jumper settings to put them in dual drive, dipole, source point. I contacted Fosgate Audionics and was told that they have no information or support for the speakers since they were manufactured before the ROFO purchase in 2000. Does anybody own a pair of these or know the jumper settings?
masterbrain is offline
post #330 of 982 Old 11-23-2011, 05:12 AM
Solid-State's Avatar
It's a real shame the Mirage Omniguide is being killed by the Klipsch Group as it's acoustic properties make it the BEST SURROUND available IMHO.
It creates a much more convincing rear channel than any dipole or bipole I've ever heard.
It's a shame no one at KG has any vision or creativity...
That omniguide in a wedge tri-pole configuration would theoretically make the best surround speaker I can think of.
Solid-State is offline
Reply Speakers
Infinity Es 250 Bipole Dipole Dual Monopole Surround Speaker
