SURROUND SPEAKERS - Bipole, Dipole, Quadpole, Omnipole... WHICH ONE? - Page 30 - AVS | Home Theater Discussions And Reviews
View Poll Results: There are many surround speakers out there now, but the ones below would have to get my highest reco
Mirage OMD5 (or any other Mirage Omnipole) 33 22.30%
JBL P520WS / Infinity ES-250 / Infinity Classia C255ES (Dual-monopole for 4 channels from 2 speakers, but also Bipole & Dipole switchable) 8 5.41%
Axiom QS8 or QS4 (Unique Quadpole design) 39 26.35%
Paradigm ADP (Many models available with this design, where the tweeters run Dipole, but the woofers are Bipole) 24 16.22%
Monitor Audio BXFX or RXFX (Single woofer, but the tweeters can switch to either Dipole or Bipole) 19 12.84%
Monitor Audio GXFX (6 drivers, including a ribbon. (Monopole / Dipole switchable) 17 11.49%
KEF 26/2DS (Dipole only, alas... but with two 6.5 inch side woofers and a front-firing 8 inch!!! ) 10 6.76%
Multiple Choice Poll. Voters: 148. You may not vote on this poll
Old 01-29-2015, 02:47 PM
skads_187's Avatar
Quoted: 44 Post(s)
just a small question, im upgrading speakers to the psb imagine series. will have t2 in the front
I have a 7.1 setup and want to keep it that way, however, in the bundle that I will be buying, I have the option of also getting the imagine S surround.
then I will use one of my other speakers for the rest of the surround duty.
for the imagine S:
would it be better to use this as a surround back? or surrounds L-R?
and which mode?
for bipole it states to use the top 2 connectors.
If I place them in the back, I believe I connect the bottom connectors and the side surrounds, the top connectors.
this is the first time I will be using such a speaker, any feedback would be great.
skads_187 is offline
Old 02-12-2015, 08:43 PM
jh20001's Avatar
Quoted: 12 Post(s)
I have considered getting some dipole Paradigms to cover my sides with. I have 4 in the back, 4 in the front + center and sub. The sides are barron. I listened to a demo at a local retailer and they sounded like they would make a great addition to the setup.
jh20001 is online now
Old 02-13-2015, 07:11 AM
fatbottom's Avatar
Quoted: 720 Post(s)
Liked: 273
I think it's probably better to go bipole from now. I have owned dipole and bipoles.
Pivetta Opera
Bose Jewel speakers.
fatbottom is offline
Old 02-14-2015, 04:44 AM
Liked: 0
I'm about to setup a new home theater; do you currently have the ADPs in your system?
kkeary is offline
Old 02-14-2015, 08:16 AM
Dan Hitchman's Avatar
Quoted: 1409 Post(s)
Liked: 670
If you upgrade to Dolby Atmos and the upcoming DTS:X object formats I would highly recommend NOT going with dipole surrounds. Monopoles or maybe bipoles instead.
jh20001 likes this.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
Old 02-14-2015, 09:51 AM
jh20001's Avatar
Quoted: 12 Post(s)
Hmmm, I have never thought of that :/
Old 02-14-2015, 09:54 AM
jh20001's Avatar
Quoted: 12 Post(s)
No. My setup is a mixture between Monitors and Titans which created a great balance. My sides have a noticeable gap though due to the size of the room. That was why I was considering them on my sides. However, he made a good point about DTS:X. I could care less about Atmos at this point, but eventually I'll probably put "something" in my ceiling since DTS:X will support those speakers as well.
Back to the drawing board in my head.
Old 02-14-2015, 10:03 AM
Liked: 670
You should care about Atmos because some studios may not support DTS:X, where they will Atmos... and vice versa. DTS:X has more flexibility than Atmos at the moment. So, it will render to Atmos speaker positions. Set up for Atmos and you're ready for DTS:X as well.
jh20001 likes this.
Old 02-19-2015, 11:30 AM
LowTech1's Avatar
Quoted: 104 Post(s)
Liked: 78
He should also wait to get a receiver til summer/fall,when the new receivers have DTS:X on them also. I have dipoles on the sides,the only problem is my side walls are pretty close,like 3 ft from the listening position on either side. Which makes monopole speakers a little close. The speakers switch from dipole to bipole,so if I do decide to go Atmos/DTS:X I'd probably switch it to bipole and put 2 speakers in the rear too for 7.1.4.
LowTech1 is offline
Old 02-24-2015, 05:50 PM
budda109's Avatar
budda109 is offline
Old 02-24-2015, 09:22 PM
Liked: 670
I would highly suggest that you put your energy and money into first upgrading from the Bose speakers you have. There are a number of relatively reasonable speaker brands and models that would be of far greater sonic quality and give you a significantly bigger performance boost for the money.
Old 02-26-2015, 05:46 PM
budda109's Avatar
Well I am looking at speakers. I always look for a deal. Klipsch seems to be a speaker of many here at AVS. I am a service tech and travel a bit ran into a guy who won a 5.1 system. Yamaha AVR, subwoofer. center two front two rear speakers. Brand is Klipsch. He said how about 450.00. I asked him to take a few pics so I can check the model but after looking around seems like I should just take the deal. He told me everything is still in the box. I would think no matter what they are an upgrade from what I have now. Correct?
budda109 is offline
Old 02-26-2015, 10:59 PM
Liked: 670
Klipsch horn speakers can be an acquired taste. Some, like me, would say that their high frequency response is a bit on the hot side, leading to a more fatiguing sound. Their cheaper stuff can sound less appealing IMHO.
Sometimes it is best to buy a little at a time and build up to a really great sound system.
For instance, these have been considered a great bang vs. buck budget monitor for quite some time:
http://ascendacoustics.com/pages/pro...m/cmt340m.html
budda109 likes this.
Old Today, 01:36 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 77
What are people's thoughts on a planar magnetic tweeter on a surround speaker?
I'm building a Chane system with the A3rx-c and am wondering if the A1 bookshelves would work well as surrounds.
The tweeter has very wide horizontal dispersion, but very little vertical. This means you won't get as much ceiling reflection which could potentially give a less diffuse sound from the surrounds.
Thoughts? Will they be fine or should I stick with dome tweeters?
Soulburner is online now
Infinity Es 250 Bipole Dipole Dual Monopole Surround Speaker
