SURROUND SPEAKERS - Bipole, Dipole, Quadpole, Omnipole... WHICH ONE? - Page 32 - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: There are many surround speakers out there now, but the ones below would have to get my highest reco
Mirage OMD5 (or any other Mirage Omnipole) 43 21.50%
JBL P520WS / Infinity ES-250 / Infinity Classia C255ES (Dual-monopole for 4 channels from 2 speakers, but also Bipole & Dipole switchable) 14 7.00%
Axiom QS8 or QS4 (Unique Quadpole design) 52 26.00%
Paradigm ADP (Many models available with this design, where the tweeters run Dipole, but the woofers are Bipole) 36 18.00%
Monitor Audio BXFX or RXFX (Single woofer, but the tweeters can switch to either Dipole or Bipole) 21 10.50%
Monitor Audio GXFX (6 drivers, including a ribbon. (Monopole / Dipole switchable) 21 10.50%
KEF 26/2DS (Dipole only, alas... but with two 6.5 inch side woofers and a front-firing 8 inch!!! ) 17 8.50%
Multiple Choice Poll. Voters: 200. You may not vote on this poll
 21Likes
post #931 of 934 Old 06-21-2016, 09:57 AM
foobrew's Avatar
Liked: 2
Originally Posted by JonasHansen View Post
My verdict
I personally think that the dipole solution in my new much smaller room, sounds better than monopoles in my previous room which was bigger. They provide exactly the big sound field I prefer with no hint of where the speakers are placed.
Thanks for sharing. That's pretty much what I'd expect based on the majority of this thread and also my own experience. I recently went from a smallish room using dipoles to a somewhat large one (20' x 20') using bipoles. The surrounds are selectable between bipole/dipole so I tried both modes that's just what sounded best for each room. The trick seems to be trying to remove localization without allowing the sound to get too muddled and chaotic.
Did you have a chance to try bipoles in either room?
foobrew is offline
post #932 of 934 Old 06-21-2016, 10:52 AM
JonasHansen's Avatar
Quoted: 27 Post(s)
No, never tried bipole. I have heard them in multiple demos and to me, they wound very much like monopoles.
JBL Synthesis | Crown | BSS Soundweb
JonasHansen is offline
post #933 of 934 Old 06-22-2016, 11:54 PM
Quoted: 70 Post(s)
Liked: 5
I have a question not about speakers but placement for the surrounds.
I'm going to take my side surround speakers down a bit to better match the ear level. Would I want them placed more to 90° in a 7.1-setup or a little more to the back when my sofa and rears are near the backwall, around 2.5 feet? Will it get better separation with those at around 90°? I'm also planing for Atmos in a while. Does that impact anything with the placement of the side surrounds?
Here are pics with my surrounds. Thanks!
westbergjoakim is offline
post #934 of 934 Old 06-23-2016, 09:07 AM
Dan Hitchman's Avatar
Quoted: 3135 Post(s)
Liked: 1594
Spoiler!
Spoiler!
In your situation, I would only do a 5.1.4 layout. You won't get any real benefit from rear surrounds as there isn't enough space (angle separation) between the sides and the rears. I would, however, have your sides at about 100 degrees, so closer to the wall corner.
I can't see the front of your room, but you could perhaps do 7.1.4 (only with upper end Denon and Marantz gear, mind you) with 5.1.4 plus Front Wides, which might be a better solution in your case. You would take the surrounds you're using behind you now and then placing them in Dolby's recommended FW positions towards the front of the room. They help fill in the sonic gap between the screen wall speakers and the side surrounds. Dolby Atmos uses them all the time as does Neural: X upmixing and native DTS: X.
Also, drop the side wall surrounds to just above head level while seated. They're high enough so somebody's head doesn't block the sound from any other viewer, but low enough to have separation between the lower and upper speaker layers.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
Reply Speakers
Infinity Es 250 Bipole Dipole Dual Monopole Surround Speaker
