Ceiling mount Mirage Nanosats - AVS Forum
post #1 of 1 Old 07-17-2007, 07:04 PM - Thread Starter
myunk's Avatar
I have a set of Mirage Nanosats. I need to ceiling mount them above my Plasma. The TV is corner mounted above a fireplace. This is the ONLY option for this room. I bought a set of Omnimount ceiling/wall mounts but they do not work.
I bought the nanosats and was told at the time that they have threaded holes on the back. Well, they don't. They have threaded holes on the bottom for the wall mount that is included with the speaker. But you can't use this mount for a ceiling install.
Anyone have any ideas?
myunk is offline
Reply Speakers
User Tag List
