Speakercraft AIM 3 Vs 5 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-27-2007, 03:56 PM - Thread Starter
baronzemo78's Avatar
Is there a big difference in sound quality between the Speakercraft AIM Three series and Five series? I'm probably going to go with the AIM LCR 5's or AIM Cinema 5's due to a good deal I'll be able to get on Speakercraft.
baronzemo78 is offline
post #2 of 4 Old 07-27-2007, 06:05 PM
mazersteven's Avatar
Big difference is in the ear of the listener. But I say yes. Better clarity, smoother highs, fuller midrange. JMO
mazersteven is offline
post #3 of 4 Old 07-28-2007, 10:21 AM - Thread Starter
Mazer, I love your theater and thanks for the advice. I will need to go in ceiling for my side surrounds and can do on wall for the rear surrounds. Would you recommend cinema dipoles for the rear surrounds and maybe an AIMwide for the side surrounds?
post #4 of 4 Old 07-28-2007, 05:42 PM
I have not auditioned the Wide series yet. They are supposed to give a diffused sound field like a di-pole speaker. If you can mount the Cinema in-walls not higher then 24" above ear level, that sounds like the way to go.
Reply Speakers
