Wiring Diagram for the Remote Control of Kef Motorized Speakers (Ci380QT & Ci200.2QT) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 08-04-2007, 11:34 AM - Thread Starter
AVSAR's Avatar
I have attached a wiring diagram for anyone interested in the IR remote control of the KEF Ci380QT or Ci200.2QT (and likely the CiFDT) motorized speakers. Finding the right hardware and wiring everything correctly took a tremendous amount of time and I wanted to provide this information to save anyone else the hours upon hours it finally took to get what I needed and wire it correctly.
Typically, the KEF motorized speakers are triggered by a 12V output on the receiver OR with the detection of audio output. The auto position is for auto music sense (not recommended for home theater installations due to prolonged silence in most movies) and the manual position is for using a 12V trigger. I wanted to control the motor function by IR remote control. While this is not an inexpensive project, it is possible and the final result is very cool.
PARTS LIST:
KEF MOTORIZED SPEAKERS
[1] Ci380QT
or
[2] Ci200.3QT
or
[3] CiFDT (since discontinued by Kef). I did not specifically research the CiFDT motorized speakers but the wiring diagram would almost certainly work for these speakers as well.
XANTECH PARTS:
[1] 78944 Connecting Block without power plug.
Xantech used to sell the 789-44PS (which included the power plug) but this model number is no longer on their website. If you cannot find the 789-44PS, you can order the 78944 and the 781RG power plug separately.
[2] CC-12 Remote Relay Module
POWER:
I originally used a Radio Shack power supply.  However after a few years, a hum developed in the speakers that I isolated to the power supply.  I even tried placing the power supply on another AC circuit.  I replaced it with a Pyramid PS8KX6 6 amp power supply and that resolved the issue.  The Pyramid is available from Amazon.com.  The higher the rated amps, the more reliable the power supply.  Pyramid does offer a 3 amp power supply but it is nearly the same price as the 6 amp.
WIRE:
A run of Cat5 ethernet for each speaker (and traditional speaker wire).
REMOTE CONTROL:
Many learning remotes would likely work well. However, I used a Logitech Harmony Remote and downloaded the IR profile for the Xantech CC-12 from the Logitech database.
Logitech Harmony Remote Controllers
For my home theater, I used the KEF motorized Ci380QT speakers in the ceiling. To wire everything except the speaker cable, I used (3 out of 4-color coded twisted pairs in) CAT5 ethernet wire for each speaker for the 12V DC, Control and 0V in the wiring diagram. If anyone has any questions about this setup, I may be able to help.
The typical disclaimer applies to all information in this post. While this setup worked well for me, I take no responsibility for anyone's equipment or safety and this post is for informational purposes only.
AVSAR
AVSAR KEF Motorized Speaker Remote-Control Wiring Diagram.pdf 142k .pdf file
AVSAR-KEF-Motorized-Speaker-Remote-Control-Wiring-Diagram.jpg 253k .jpg file
File Type: pdf AVSAR KEF Motorized Speaker Remote-Control Wiring Diagram.pdf (141.9 KB, 639 views)
AVSAR is offline
post #2 of 21 Old 02-29-2008, 11:25 PM - Thread Starter
AVSAR's Avatar
Originally Posted by HDCowboy View Post
That is exactly the speaker setup I am putting in for a guy and I was wrestling for a few hours now with how to drop "on demand" because during times of just audio I want to leave the speakers "up"...
ANY more info you can give would be appreciated...
What isn't clear is where you are using the UTPairs to-from
Also - can I use this for one other device that needs to go up and down with a seperate IR code?
How is it working for YOU??? This is great!!!! I love the internet and smart people at AVS forums!!!
I'm glad you can make use of my wiring diagram. If you only knew how long it took me to find the right components to make this work...wow, what a process it was. The end result is simply awesome! Everyone that comes and watches a movie at my house is totally blown away. Not to mention, it is much less wear and tear on motorized speakers because I usually leave them down.
I'll try to answer your questions as best I can. I used 3 ethernet twisted pair wires from the connecting block to the CC12 (you see the picture on the left with the ethernet wires on the CC12). You don't use the Status terminal on the connecting block or the CL terminal on the CC12.
I used 3 ethernet twisted pair wires from the CC12 to go to the Control lead from the Left, Right & Center speakers. I also used ethernet wire from the CC12 to the power supply and then 3 wires (again, for the Left, Right & Center speakers) out from the power supply on each of the the + and - leads of the power supply to the remaining leads on the KEFs.
I cannot remember if the CC12 has more than one distinct IR code on the harmony database. If it does, all you would need is 2 CC12s to control 2 sets of devices indepedently. Otherwise, you could use the same CC12 for all other speakers or a film screen but they would all be triggered by the same IR Signal.
AVSAR is offline
post #3 of 21 Old 03-21-2008, 11:17 AM
HDCowboy's Avatar
Just to try to clarify the ethernet pairs use
I've got three of the Kef in a line in the same joist space with 16/2 back to the stack for audio.
A supplier/installer said that I'd only need to run ONE cat5e for control of the system - he suggested using a Bosch relay with the amp trigger out to control drop down of the speakers.
My amp has no trigger out so we discussed using the "audio sense" and trigger it that way. My buddy said this was a bad idea due to the seperation of some tracks and occaisionally "dead spots" in movies that can cause the Kef's to ascend.
This is where I found your solution - Again "this is GREEEAAAATTTT"
is ONE ethernet run going to be enough here????
ie) one twisted pair for Shared Power +
-one pair for shared Common -
-and another shared pair for trigger?
I could splice the shared pairs and pigtail to each speaker.
Have I interpreted correctly?
Please say yes as the customer has now finished his "Flat" ceiling and there is no way I can run more without "trouble"
Thanx a million
Doc
HighDefCowboy...
HDCowboy is offline
post #4 of 21 Old 03-21-2008, 01:40 PM - Thread Starter
AVSAR's Avatar
Thanx a million
Doc
HighDefCowboy...
You will be fine with pig-tailing and a single run of Cat5! I ran 3 runs of Cat5 (one for each speaker) not because this is a better way to do it but because I had total access to the ceiling and Cat5 is cheap. If you are only triggering 3 speakers as I did in the diagram, using short runs and pig-tailing them to the "main line" back to the CC12 and Power Supply for the Control wire, 0 Volt wire and the 12 Volt DC wire will be fine.
I was told by a low voltage installer that one, single strand of Cat5 Ethernet would be sufficient. That is to say that you could simply use the blue strand as opposed to twisting both the blue strand and the blue/white strand together. However, a single Cat5 strand is not exactly the most rugged wire so I decided to use 2 strands (a pair) for redundancy.
Let me know how things work out.
AVSAR is offline
post #5 of 21 Old 05-06-2008, 12:00 PM
vico's Avatar
Hi,
I bought the KEF ci3-80QT and my amplifier has a trigger 12v out. Do you know how to connect speakers to the amplifier?
Thank you
vico is offline
post #6 of 21 Old 05-06-2008, 06:10 PM - Thread Starter
AVSAR's Avatar
I attached a wiring diagram for a 12v trigger. Hope this helps!
AVSAR
Trigger_Set_Up[1].doc 50k .doc file
Ci380_Trigger_Set_Up[1].doc 48k .doc file
AVSAR is offline
post #7 of 21 Old 05-06-2008, 08:52 PM
realred2's Avatar
I set these up about 2 years ago, Ran the 3 amp radio shack unit and had a remote outlet (for lights) with a small DC output plug from radio shack too. I used a single run of 4 cunductor speaker wire to run the whole thing, and then a 2 cunductor speaker line for sound. My customer can play music with the speakers mounted in the ceiling and looking like inceiling speakers, and can press a button and have them all drop down to specific heights for a "optimal" theater set up. 6 of the Ci380QT's and a Ci200.2QT for a center...Has been running great since. only had one sprocket break on a 380 (and the speaker fell down and wouldn't go back up)
My "Route 66 Basement Theater" Build Thread
realred2 is offline
post #8 of 21 Old 08-23-2010, 05:43 AM - Thread Starter
AVSAR's Avatar
The remote KEF speakers are still running flawlessly after 3 years. I went back and updated the links to the products.
AVSAR is offline
post #9 of 21 Old 08-24-2010, 05:18 PM
sampl's Avatar
Hi AVSAR
I am relatively new to this and not very technical so please bear with me.
I am renovating my house and have the opportunity to drill walls/floors/ceilings as appropriate. I currently have an onkyo sr608 receiver and, after reading your thread, checked and discovered it did not have a 12V trigger.
I have a KEF ci200.3QR which I want to use as the centre speaker and plan to buy ci200.3QT speakers as my Front L and R speakers.
1- Since my receiver does not have the trigger, am I stuck with just the audio on option and if not, what are my options?
2- Is it wise to have an inwall as a center and in-ceilings as the Front Left and Right? If so what is the best way to place the 3?
Thanks in advance for you (eagerly anticipated) answers.
sampl is offline
post #10 of 21 Old 08-25-2010, 09:57 PM - Thread Starter
AVSAR's Avatar
Originally Posted by sampl View Post
Hi AVSAR
I am not an expert on acoustics. It certainly would have more aesthetics and geek-cool factor to have your right, left and center come down from your ceiling as I did in my application. However, for my application I mounted a large 57" LCD above a fireplace and I had no room for a center channel above or below the display on the wall. This was the main reason I went with a ceiling solution. If you have space and you have full access to your wall, it will be far less expensive and far easier to wire-up 3 non-motorized speakers facing forward.
If you decide to go with motorized speakers, your options are as follows:
Run standard runs of speaker wire (one for each speaker) and runs of standard Cat 5 or Cat 6 ethernet (one for each speaker) in the ceiling and
1. Buy the Xantech connecting block, remote relay, a 12 volt power supply and a harmony remote and follow my wiring diagram and instructions to have full and independent remote control over the motor of your speakers or
2. Buy a receiver with a 12v trigger output so the speakers come down when the receiver switches on and go up when the receiver is off. You will need to at least step up to the TX-SR707 for this or
3. Buy a 12 volt power supply to power the speaker motors once in manual mode to drop them down and then turn off the power supply and simply leave them in that position or
4. Buy a 12 volt power supply to power the speaker motors and use the auto position to drop them down when audio is detected. The problem with auto mode is it is intended for music and not home theater. If there is a part of a movie with limited audio, the speakers may decide to go back up.
AVSAR is offline
post #11 of 21 Old 12-01-2011, 09:25 PM
hevnbnd's Avatar
To bring back an old VERY useful thread. Can anyone tell me the difference from the Ci200QT - Ci200.2QT - Ci200.3QT Any reason not to buy the QT one if I can still find it for cheap?
hevnbnd is offline
post #12 of 21 Old 03-16-2012, 08:25 PM
mpick92's Avatar
I am having trouble with my harmony 880 remote and the CC-12 relay module. The connecting block flashes yellow that it is receiving the signal, but the CC12 does not want to trigger the speakers. I did email logitech service as well, waiting for response. Any ideas?
-Otherwise I have been able to trigger the speakers manually by connecting CI and +12VDC on the CC-12. I really want to get this setup working before I cut into the ceiling.
mpick92 is offline
post #13 of 21 Old 03-21-2012, 09:22 AM
KEFAmerica's Avatar
Hi,
There is a different between all 3 SKUs. They have different motor assemblies. The .2 and .3 may not work together and create complications which may damage the speaker. Please make sure which every one you choose they are with the same series.
Sincerely,
KEF America
KEFAmerica is offline
post #14 of 21 Old 01-27-2013, 06:48 PM
rshmokinrt10's Avatar
Thank you very much for putting the wiring diagram together. I'm sure it was a time consuming project. Can you tell me if I can utilize the Xantech WL95 Single Gang wall box IR Receiver in this configuration?
rshmokinrt10 is offline
post #15 of 21 Old 01-28-2013, 05:32 PM - Thread Starter
AVSAR's Avatar
The Xantech WL95 looks like a great option and it will take the place of the 78944 Connecting Block and the 781RG power plug. It was not available when I assembled my system. You will still need to power it with a 12v power supply.
This setup is still going strong after several years. I have updated the remote to the Harmony 900 with RF and put everything in an AV closet. The Radioshack power supply developed a hum in the speakers (even on a separate AC circuit). I am not sure if it was because I added a new component or the PS just got old. In any case, I upgraded to the Pyramid PS8KX 6 Amp Power Supply and that did away with the speaker hum. I updated the first post with part info.
AVSAR is offline
post #16 of 21 Old 01-30-2013, 08:09 PM
That's great. I'm doing the rough buildout right now, but will let you know how it works out.
Thanks again for your help.
post #17 of 21 Old 06-19-2013, 10:32 AM
jackmondy's Avatar
Sir is there any fuse inside of this KEF..?
jackmondy is offline
post #18 of 21 Old 06-19-2013, 11:43 AM - Thread Starter
AVSAR's Avatar
There are no internal fuses in the Ci3-80QT's. This brings up an important point: You need to be careful to attach the correct wires from the power supply to the motorized speakers as you can damage the components if the wrong wires are connected. Be sure to follow the wiring diagram completely and you will have no issues.
AVSAR is offline
post #19 of 21 Old 07-30-2013, 07:25 AM
mustangwally's Avatar
having issues with downloading the PDF file, any chance you could send it me in a PM?
mustangwally is offline
post #20 of 21 Old 07-31-2013, 03:49 AM - Thread Starter
AVSAR's Avatar
I had the same problem with the original attachments not downloading from any of my posts. I re-uploaded the files to my posts in this thread, added a JPG version and mirrored the wiring diagram here:
http://alkaspace.com/is.php?i=157845&img=AVSAR-KEF-Motor.jpg
AVSAR is offline
post #21 of 21 Old 11-08-2014, 06:22 PM
Liked: 0
i just wanted to tell you how much i appreciate you posting your wiring diagram on kef speaker control. i used it with great success today.
you provided a perfect solution that i was struggling to overcome and i appreciate your hard work and research on it.
Rob
robroy1 is offline
Reply Speakers
