Polk now posted its new RTi line - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-15-2007, 04:38 PM - Thread Starter
tleavit's Avatar
Quoted: 43 Post(s)
Liked: 89
Polk literally just posted their new line of updated RTi speakers.
Called simply RTi 2008
For example, the Rti12 looks exactly like the Rti9 2008 model. I can't tell the difference. Maybe its being setup for a new model like a Rti11
It kinda sucks for me since I just literally bought rti12's and the CSi5.
"Any sufficiently advanced technology is indistinguishable from magic" -Arthur C. Clarke
tleavit is offline
post #2 of 4 Old 08-15-2007, 06:00 PM
gotchaforce's Avatar
then return them?
gotchaforce is offline
post #3 of 4 Old 08-15-2007, 06:12 PM
FyreFlux's Avatar
if you just bought them, you probably got a pretty good deal on them though. chances are the new ones are going to be full priced, even if there is no changes.
FyreFlux is offline
post #4 of 4 Old 08-15-2007, 06:18 PM
FyreFlux's Avatar
they actually look a little different. they appear to be all wood this time around instead of being plastic underneath the grille...looks a bit better i think.
FyreFlux is offline
Reply Speakers
