Recommend a <$300 center channel for Paradigm Studio 60s? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-24-2007, 08:16 PM - Thread Starter
jambon's Avatar
So I've finally moved into a new house that will allow me to place my Studio 60s properly for listening to music. It's been great. In addition, the house was already decked out with in-wall rear speakers for a home theater setup. So now I'm only a decent sub and a center channel from a respectable 5.1 HT capability.
My first instinct was to go to my local paradigm dealer and see what they had available that might match the fronts. When I saw what they were asking for a Studio series center channel or even a Monitor CC-290, I began to question how important HT listening was to me. I'm really a music guy first so I'm starting to wonder if it would be a good idea for me to buy an unmatched, ie non-Paradigm, center if there were any good ones out there for ~$300.
So I guess I'm pondering 2 questions. Are there any high-quality centers out there for around my preferred price? And if so, would it do a reasonable job of providing HT sound in combination with my Studio 60s? I'd appreciate any advice from anyone who's attempted something similar.
jambon is offline
post #2 of 5 Old 08-25-2007, 07:03 AM
Kal Rubinson's Avatar
Quoted: 761 Post(s)
Liked: 526
Find a used Studio/20.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #3 of 5 Old 08-25-2007, 07:53 AM
swgiust's Avatar
Quoted: 26 Post(s)
I would stay in the Studio line. Check out e-bay or audiogon for used one's.
The Studio 60's are truly a very, very good speaker, so please don't cut corners on you center. You will reget it.
swgiust is offline
post #4 of 5 Old 08-25-2007, 07:54 AM
Sirquack's Avatar
I second Kal's response. You want to stick with the same brand, and series if possible. Keep an eye on ebay, audiogon, etc. and look for a used one if a new one is out of the budget. You really don't want to mix match brands.
___________
"Don't worry about the future, it is already tomorrow in Australia..."
My Website
Sirquack is offline
post #5 of 5 Old 08-25-2007, 08:14 AM
tokerblue's Avatar
Quoted: 191 Post(s)
Liked: 164
I third the response. The Studio line sounds much better than the monitor line. Save up a little more rather than going the cheaper route. The center channel is VERY important for HT since virtually all of the dialog comes from the center.
tokerblue is online now
Reply Speakers
