Triad Owner's Thread - Page 210 - AVS Forum | Home Theater Discussions And Reviews
 467Likes
post #6271 of 8412 Old 07-14-2014, 06:51 PM
mmcxiiad's Avatar
Originally Posted by Dan Hitchman View Post
If you don't have to use in-ceilings for any reason but for overhead effects (such as those in Dolby Atmos and DTS-UHD object formats, the former just announced for home use) then you shouldn't. You want to lock the sound with the picture as much as possible.
In-ceilings are usually a last resort kind of speaker due to less than ideal room situations or if you're just doing ambient mood music in a non-critical application.
A fair amount of my decision is based on he conversation I had last time. I went back and reread some of it and basically the consensus was due to the height of the tv and where the speakers would have to be... And he'd instance we sit from he tv, ceiling speakers would be a better fit
As far as locking the sound with the picture, since these speakers are angled, I thought that this corrected that issue? Or is here some other factor that I am not taking into account?
I am not trying to be argumentative, just trying to understand and make the best decision possible as opposed to wasting money.
mmcxiiad is offline
post #6272 of 8412 Old 07-14-2014, 06:52 PM
mmcxiiad's Avatar
Accidental double post
mmcxiiad is offline
post #6273 of 8412 Old 07-14-2014, 09:01 PM
Dan Hitchman's Avatar
Quoted: 3414 Post(s)
Liked: 1767
Only a little bit. And if you did want to move up to Atmos at some point... well, it would be really, really hard with front speakers in the ceiling as well as in-ceiling speakers that are supposed to be above you. It would totally throw off the sound stage. In-ceilings still to much of an extent become like VOG speakers whether you want them to or not.
Do you have pictures of your room?
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #6274 of 8412 Old 07-14-2014, 09:26 PM
mmcxiiad's Avatar
Yep. here is the post where I posted a few pics and description. It is our master Bedroom. I will never do atmos in this room. Putting in a 5.1 setup was the limits of what my wife and I agreed on (I wanted 7.1... she was apprehensive about even putting the 55 inch tv in.
After much negotiation and concessions... 5.1 is the limit.
Initially i didn't want in ceiling speakers. I had asked about in wall ones. My concern was that the center would have to fit between the studs. Also, on the other side of the wall is the laundry room. so I am limited about building a box to mount a speaker sideways.
After a little back and forth in ceilings were mentioned as the best way to go. I am not stuck on them if I can find a better solution.
The one advantage I have with in ceiling is there is nothing but blown in insulation above the room.
mmcxiiad is offline
post #6275 of 8412 Old 07-14-2014, 11:16 PM
Liked: 1767
Ah, now I see. Go with the angled in-ceilings as others have mentioned. It's not a mission-critical room anyway and they'll be fine for your bedroom (I'm just not used to having surround systems in a bedroom setting). If this had been for a main theater I wouldn't have gone with the in-ceilings except for use as Atmos overheads.
post #6276 of 8412 Old 07-15-2014, 08:02 AM
mmcxiiad's Avatar
We'll, now to go back my original question - which would I be better off with gold omniSE or silver minimonitor?
mmcxiiad is offline
post #6277 of 8412 Old 07-15-2014, 08:06 AM
Liked: 1767
My vote's for the Silver MiniMonitor. It seems to have better drivers.
You will need a subwoofer with either.
post #6278 of 8412 Old 07-15-2014, 07:04 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 942
BTW, where's Paul?
Dan, are you the Guy taking over for Paul?
Colorado.......Listen Up? Isn't Listen Up an Audio Video retailer?
Just curious since you post here. A LOT!
doublewing11 is offline
post #6279 of 8412 Old 07-15-2014, 10:30 PM
Liked: 1767
Originally Posted by doublewing11 View Post
BTW, where's Paul?
Just a forum member like you with a love of home theater and movies.
Paul is probably on vacation. He either retired from Triad or moved on to other things, so I'm sure he has other stuff to do than talk to us all the time (like having a life).
post #6280 of 8412 Old 07-19-2014, 10:27 AM
queendvd2's Avatar
Just make sure it's the Marantz that's faulty and not the B&K. If it is the Marantz that has gone bad, then all you need is another pre-amp for now (which doesn't care what ohms a speaker is rated at... that's the amplifier), not necessarily a receiver unless you don't want to spend a lot right now. What kind of budget is right for you?
Dan, thanks for all the input. After finally finding some time to troubleshoot, it was simply a connectivity issue with the amp. Everything is all good and I've got audio again. Appreciate all the suggestions and am happy no $$ needing to be spent!
queendvd2 is offline
post #6281 of 8412 Old 07-19-2014, 10:29 AM
Liked: 1767
Fantastic news! If you get a chance to demo Dolby Atmos... more $$ may indeed be spent.
post #6282 of 8412 Old 07-22-2014, 08:31 PM
RapalloAV's Avatar
Quoted: 1310 Post(s)
Liked: 292
Lightbulb 4ohms mixed with 8ohm speakers?
If I was to replace my Klipsch inwall THX fronts KL-7800 THX speakers which are 8ohms, with Triad Silver/4LCR inwall speakers which are 4ohms, how would they mix with the rest of my Klipsch ceiling speakers which are also 8ohms? I have an 11.2 setup.
My AVR is the Integra 70.4 which I also use with a separate Integra amp DTA 70.1
My Integra AVR 70.4 only has two settings 4 or 6 ohms. Currently its set to 6ohms for all the Klipsch speakers.
I am only powering the two rear channels from the AVR, the rest are powered from the separate amp. I do see on the rear of the amp there is also a switch to set it to 4 ohms or 6ohms.
So the question is, can I mix your three Silver/4LCR 4ohm speakers up front safely with the rest of my Klipsch 8ohm surround speakers?
If so how do I setup the AVR and the separate power amp?
Do they both get set to 4ohms?
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is offline
post #6283 of 8412 Old 07-22-2014, 11:01 PM
Liked: 1767
I'd probably run the Triads via the DTA-70.1 and set it to the 4 ohm setting. The Klipsch's are far, far easier to drive (8 ohm and very sensitive) and would probably do just fine powered by the receiver.
post #6284 of 8412 Old 07-23-2014, 12:01 AM
Spizz's Avatar
Quoted: 170 Post(s)
Liked: 76
Oh I did not know that Paul was no longer with Triad. If correct he will be missed as he was an excellent champion for the brand.
Spizz is offline
post #6285 of 8412 Old 07-23-2014, 12:34 AM
RapalloAV's Avatar
Liked: 292
Wow brilliant idea I had never thought of that, thank you!
Could you describe the difference I might hear, feel with using the three triads up front over the Klipsch KL7800s?
I have never heard or seen Triad speakers here in NZ, Im only going from what I read.....
I find the Klipsch kind of bright, not warm enough with the four SVS PB13 Ultras I have. I really want a better match. Something better for the fronts...
Anyone please pitch in if you can add anything here...
Murray Thompson
X Owner RapalloAV
post #6286 of 8412 Old 07-23-2014, 08:30 AM
Liked: 1767
When I listened to Triad Silver speakers I found them to have a very wide, dynamic sound stage and the high frequencies were non fatiguing, laid back, and smooth. The best way I could describe them would be: "natural" and "uncolored." Great for listening to music for extended periods. Dialog was clear and easy to understand. I find most consumer grade Klipsch speakers to be harsh and grating and irritating to listen to after a few minutes... like nails on a chalkboard. The sound is quite colored and it only gets worse as you raise the volume to "movie listening" levels.
With the debut of object based surround like Dolby Atmos, my advice would be to upgrade your surrounds to matching Silver monopole in-walls as well, so you have proper timbre matching. Triad should be showing new Atmos friendly speaker models at the CEDIA Expo in September, so it might be worth waiting for these announcements.
I believe you would be quite happy with a switch to the Triad brand... and no, I didn't get paid to state this.
grtuck likes this.
post #6287 of 8412 Old 07-23-2014, 08:21 PM
Quoted: 229 Post(s)
Liked: 942
Speaking of Atmos, one step closer with base for ceiling cloud done........
More sanding, staining, filling knot holes in Knotty Alder.......home for six new Triads.....
ID:	177378   Click image for larger version
65Goat, Mike Garrett and grtuck like this.
post #6288 of 8412 Old 07-23-2014, 10:16 PM
Liked: 1767
Wait.
Triad is coming out with new Atmos speakers and not just the kind that Pioneer and Onkyo are offering. More info should be forthcoming at CEDIA.
post #6289 of 8412 Old 07-23-2014, 10:37 PM
Quoted: 229 Post(s)
Liked: 942
Wait.
Not necessarily going to work in my room............have had direct contact with Triad who have been in communique with Dolby. Looks like I may be looking at custom Silver LCR's in my room to match my 6 Silver LCR's and 3 Gold LCR's. Big question is will ther be enough depth in ceiling cloud to accommodate the minimum depth required to do so. We shall see.....
Atmos is still a mystery.......but info is leaking out ever sooooo slowly.
post #6290 of 8412 Old 07-23-2014, 11:01 PM
Liked: 1767
Well, since they pretty much build to order... it sounds like they already have Dolby approved schematics for Atmos friendly speakers, so definitely see what they can do to meet your needs. Just so long as they're timbre matched to what you have currently.
post #6291 of 8412 Old 07-24-2014, 07:50 AM
04rex's Avatar
Quoted: 117 Post(s)
Liked: 26
Hey guys, how much do the on wall Mini LCR speakers go for typically?
And when you do want to order custom sizes, how much does it typically cost for each speaker? Do they charge by 1/4 inch?
I have been trying to get pricing and emailed a few people that carry them but have not got any responses back.
04rex is offline
post #6292 of 8412 Old 07-24-2014, 08:43 AM
nathan_h's Avatar
Quoted: 1020 Post(s)
Liked: 612
There was a complete price list in this thread a few months ago. These are the new 2014 prices.
Custom sizes were not specified but you can at least get a sense of the base price for all models.
____________________
Current theater & gear: "Nathan's Theater in Search of....".
nathan_h is offline
post #6293 of 8412 Old 07-24-2014, 08:44 AM
nathan_h's Avatar
Liked: 612
Very cool that you have been able to get info directly from Triad and Dolby to help with your planning.
nathan_h is offline
post #6294 of 8412 Old 07-24-2014, 08:47 AM
04rex's Avatar
Quoted: 117 Post(s)
Liked: 26
Yeah, that is essentially what i want. Just an idea of the pricing. Do you know what page it is on?
04rex is offline
post #6295 of 8412 Old 07-24-2014, 08:49 AM
nathan_h's Avatar
Liked: 612
Those switches for impedance selection simply limit the power output. They put them in as a caveat and stopgap.
To keep operating temps low, they work. To unleash the full power of your gear, they get in the way. Ymmv.
And, frankly, while I like Klipsch, they have such different tonal, dispersion, and sensitivity characteristics from Triad's that I would do all or nothing, if it were me.
nathan_h is offline
post #6296 of 8412 Old 07-24-2014, 08:50 AM
nathan_h's Avatar
Liked: 612
He retired several years ago, but until recently was still so involved with the community it was hard to tell!
Although I miss his input, I am sort of happy to think he might be really enjoying the great outdoors, biking, and a well earned retirement.
nathan_h is offline
post #6297 of 8412 Old 07-24-2014, 09:38 AM
Mike Garrett's Avatar
Quoted: 5615 Post(s)
Liked: 3599
Custom size change for the speaker it's self costs a little more. Custom grills are expensive.
mjgarrett100@gmail.com
Mike Garrett is offline
post #6298 of 8412 Old 07-24-2014, 10:15 AM
04rex's Avatar
Quoted: 117 Post(s)
Liked: 26
Ok, how much do the Mini LCRs go for without custom sizing? I just want to know if they are in my price range or not.
04rex is offline
post #6299 of 8412 Old 07-24-2014, 03:58 PM
jjcook's Avatar
Quoted: 336 Post(s)
Liked: 141
The retail price (from the PDF sheet posted here earlier this year) is $500/ea for the InRoom/InWall4/InCeiling8/OnWall LCR.
Info: 8.5' viewing distance AT screen fabrics comparison
Builds: Variable-aspect screen with motorized masking (have parts) HT 2.0 renovation with acoustic coffered ceiling (in progress, 5% completed)
jjcook is online now
post #6300 of 8412 Old 07-25-2014, 05:51 AM
Dawn Gordon's Avatar
Quoted: 159 Post(s)
Liked: 113
MSRP for the OnWall Mini:
1.0 $500
2.0 $1000
3.0 $1500
Dawn Gordon is offline
Reply Speakers
Triad
