Triad Owner's Thread - Page 216 - AVS Forum
 60Likes
post #6451 of 6459 Old Yesterday, 02:51 PM
Dan Hitchman's Avatar
Quoted: 693 Post(s)
Liked: 415
Originally Posted by BrolicBeast View Post
Honestly, I thought Atmos would be done precisely as you describe. But the more info Dolby released, the more the dream died...
Even the most expensive Atmos processors on the market don't seem to have anything, but the simplest Atmos rendering communications (just what speakers are plugged in to your system)... you still need to place the speakers within the angle recommendations set by Dolby.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #6452 of 6459 Old Yesterday, 03:01 PM
Scott MS's Avatar
Exactly what I am thinking. Rather than analyzing speaker locations to configure the system, they are requiring you to stick speakers in one of 34 very specifically defined locations. That is not a formula achieving wide adoption.
Scott MS is offline
post #6453 of 6459 Old Yesterday, 03:11 PM
Scott MS's Avatar
I also agree with Dan's comments before that separation is key. I happen to have a room where I don't have a lot of space between the seating location and the back wall. I have Rear Surrounds high on the rear wall.
I am not really in a position to add height speakers both behind and front of the seating location simply due to space and the distance between the existing speakers (it would be about 3 feet of space if I did -- and if I lowered my rear surrounds to listener level you would enjoy a speaker 2 feet behind your head). My preference would be to utilize the Rear Surrounds speakers, a pair of "Middle Overhead Speakers", and a pair of "Front Overhead Speakers" to achieve the height channel, assuming the processor would be smart enough to blend the Rear Overhead between the Middle Overhead and Rear Surround.
These are the types of questions that Dolby needs to address.
Scott MS is offline
post #6454 of 6459 Old Yesterday, 04:28 PM
doublewing11's Avatar
Quoted: 78 Post(s)
Liked: 303
Well, all 9 of my current speaker locations have been designed/built into columns and really can't be moved....:...
Fortunately, my ceilings are 10-1/2 ft high with ceiling cloud to hide possible ceiling speakers. My front row side surrounds are 2-1/2 ft above ear level with second row surrounds 18 inches above ear level. Both rows of side surround tweeters are 3 ft from ceiling........thus somewhat doable separation from all other surrounds. My problem is......current available products from Triad can't address dispersion issues for my room which is quite large compared to most dedicated rooms at 25-1/2 ft by 17 ft by 10-1/2 ft in ceiling height. I'm definitely going to wait until dust settles on this one..........
nathan_h likes this.
My Build Threads
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
doublewing11 is offline
post #6455 of 6459 Old Yesterday, 06:57 PM
jimim's Avatar
Guys quick question. I'm trying to rework my room with direct vs bi poles now due to atmos. I was originally using silver surrounds for my rears and sides. My front speakers were gold lcr's.
If I go with direct speakers is the omni silvers a good choice to replace the silver surrounds. I thought about silver lcr' but I thought it might be overkill.
My room is 12 wide by 22 long by 8 high.
Also if I can't go in my cieling for the *.4 speakers would the omnis be a good choice for rear heights and front heights set at the atmos recommended angles and placement?
Thanks a lot,
Jim
Ps I'm also throwing around the idea of going down to silver lcr' to match up all speakers if the omni are an appropriate choice for surround rears and heights if I can't get in my cieling with the bronze in cieling surrounds.
jimim is offline
post #6456 of 6459 Old Yesterday, 07:13 PM
nathan_h's Avatar
Quoted: 80 Post(s)
Liked: 88
If you can safely reach reference level, based on the distance from the speaker location to the seating location (money seats/MLP) & the speaker sensitivity & their max power handling & your amplification, that is a minimal threshold for whether you could use (for example) the omni in place of the LCR, imo.
____________________
Build Thread:
nathan_h is online now
post #6457 of 6459 Old Yesterday, 07:16 PM
nathan_h's Avatar
Quoted: 80 Post(s)
Liked: 88
When DTS first started mapping out their plans for object based sound, they had this more flexible "we'll figure out what speakers you have and map the objects correctly for your setup" technology in their plan.
I agree it may be a few years until we see it available in regular gear (ie, $1,500 processors and not $30,000 ones) and I wouldn't be surprised if you have to upload measurements to a cloud service for crunching and they send back a config file for your system.
In those terms, what the Dolby system is, at this point, is a single, generic config file for some specific speaker positions. Still a big step forward, but not quite what most of us are hoping for.
At this point, I'd rather spend the money on a software solution that works correctly with where my speakers are, than spend money on moving my speakers.....
Build Thread:
post #6458 of 6459 Old Yesterday, 07:35 PM
Quoted: 693 Post(s)
Liked: 415
There's only so much you can do with speakers that were meant to be overhead not high up on the wall and maintain the proper 3D effect Atmos sound engineers were trying to create. Re-mapping isn't a panacea. Even the professional Dolby Lake calibration system only can do so much with the Atmos renderer. Theater owners still need to install speakers to within a certain parameter to get the most seamless sound.
post #6459 of 6459 Old Yesterday, 07:53 PM
nathan_h's Avatar
Quoted: 80 Post(s)
Liked: 88
Absolutely.
My point is not that mapping is a panacea. Rather to say: There's still a significant amount that dynamic mapping could achieve beyond what is available right now.
Dan Hitchman likes this.
Reply Speakers
Triad
User Tag List
