Triad Owner's Thread - Page 217 - AVS Forum
 68Likes
post #6481 of 6495 Old 09-29-2014, 06:43 AM
landshark1's Avatar
Liked: 58
Originally Posted by Dawn Gordon View Post
If you want to match your surrounds to your Gold LCR fronts, I recommend going with the IW Gold/4 Omni SE.
See my Triad Speaker matching chart via the link below:
Yeah, I've saved your chart for reference.
My only concern is the 2nd row being inches away from the rear surround speakers for any use of direct firing speakers back there.
And could I use the InWall Silver/4 Omni SE or even InWall Silver LCR (like doublewing) instead too for cost saving? Like many use the Gold line for LCR and Silver line for the surround duty?
What's the main difference between the LCR and the Omni SE line?
Thanks for all the effect guys! I'm new to the Triad speakers and surely looking forward to join the family.
~ Gary
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
landshark1 is offline
post #6482 of 6495 Old 09-29-2014, 08:53 AM
Dan Hitchman's Avatar
Quoted: 778 Post(s)
Liked: 441
Unfortunately, the back row of your theater is very close to the wall and any speaker is going to hotspot like crazy. It's the front row that has the prime seats. Design for those viewers. Design for Atmos and other immersive formats (you won't regret it)... no dipoles. Timbre match if you can. Dawn has you on the right path.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #6483 of 6495 Old 09-29-2014, 09:00 AM
landshark1's Avatar
Liked: 58
So you recommend me to forgettable the 2nd row viewer and focus on the primary user on the front row? Sounds reasonable option if I really can't accommodate both rows in my case.
Btw, I'm using Emotiva XPA-2 & XPA-5 amp, are they ok to power those Triads?
~ Gary
post #6484 of 6495 Old 09-29-2014, 09:20 AM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 372 Post(s)
Liked: 418
Yes.
Mike Garrett, AV Science Sales Call Me: 585-671-2968
Email Me:
Brands we sell:
Call for B-stock projectors
Stewart, Seymour, SE, SI, Falcon & many more.
RBH, Martin Logan, Triad, Atlantic Technology, MK Sound, BG Radia, SVS & Def Tech.
AV Science Sales 5 is offline
post #6485 of 6495 Old 09-29-2014, 09:30 AM
Quoted: 778 Post(s)
Liked: 441
It's all about compromises, unless you have a BIG room to work with for more optimal seating and speaker arrangements and so you can compromise less... and even then there is only one true sweet spot where the soundtrack's "audio bubble" is closest to the mixer's original intent.
post #6486 of 6495 Old 09-29-2014, 04:01 PM
doublewing11's Avatar
Quoted: 84 Post(s)
Liked: 307
I'm just plain confused and believe the algorithm for choosing Triad speakers is wrong for most/some applications.
I understand Gold Omni SE being recommended for surrounds with Gold LCR's due to having similar tweeter but the similarities stop there!
Sensitivity relating to dynamics should be considered.........sensitivity on Gold Omni SE is 6-7 db's less in sensitivity than Golds. IMHO, Silver LCR's have been a better match with Gold LCR's in my room than Gold Omni SE's due to fore mention issue. Triad speaker list is not match all for all applications..
Just saying.......
My Build Threads
doublewing11 is offline
post #6487 of 6495 Old 09-29-2014, 04:51 PM
landshark1's Avatar
Liked: 58
Hmmm.... I'm a bit confused too....
~ Gary
post #6488 of 6495 Old 09-29-2014, 06:19 PM
Quoted: 84 Post(s)
Liked: 307
Erskine Group spec-ed Gold LCR's for front and 6 Silver LCR's for surrounds. I suspect Gold Omni SE's were not part of equation due to huge sensitivity difference.
My Build Threads
post #6489 of 6495 Old Yesterday, 06:26 AM
Dawn Gordon's Avatar
Quoted: 30 Post(s)
Liked: 36
If cost is not an object, Triad always recommends using the same series speakers for both LCRs and surrounds. For example, Silver LCRs up front, and Silver LCRs for surrounds. Now those Silver LCRs can be OnWall, InWall, or even InCeiling. The best mix will always be room dependent.
The speaker matching guide is designed to show what speakers sound similar. Again, it's system and room dependent.
Authorized Dealer Sales: Triad Speakers, NHT, Marantz, Denon, JVC, Stewart Filmscreen, Screen innovations, Panamorph and Control4.
Dawn Gordon is offline
post #6490 of 6495 Old Yesterday, 07:35 AM
twells's Avatar
I think for a 'typical' HT, using speakers for side and back duty that are 6-7db less sensitive is probably ok since they're generally much closer to the listening position relative to the front LCRs. I seem to recall that when you double the distance, the SPL drops by about 6db. As everyone has said 'it's room dependent'. If you have a huge (wide) room you might need the additional sensitivity of Silver (or GOLD) LCRS but it's probably not the case for many.
It does seem that Triad set up their product lines around 5.1 systems (assuming diffuse surrounds) but never really adapted the lines (in a marketing sense) to larger 7.1+ systems and hence all the confusion.
Dan Hitchman and Dawn Gordon like this.
twells is offline
post #6491 of 6495 Old Today, 01:21 PM
jes5e's Avatar
Speaker placement help
I'm about to do an install of Triad InWall speakers in my new house. I'm looking for some advice on speaker placement. My biggest questions, other than just does this look like it makes sense, are:
1) Does this setup make sense?
2) Is my center speaker too low to the ground or will this be OK?
3) Are the left and right front speakers too close to the side walls in the room?
The speakers I'm using are Triad InWall Silver 6 LCRs for the three front, and Triad InWall Silver Surrounds for the side surrounds.
Any help is greatly appreciated!
Speaker placement diagram is in the attached image and shows two different views of the room - head on and top down.
Name:	Speaker Placement - 5.1.jpg
jes5e is offline
post #6492 of 6495 Old Today, 02:46 PM
Quoted: 778 Post(s)
Liked: 441
You know what the next question will be: are you going to consider immersive sound formats like Dolby Atmos and DTS-? (whatever they call their format)?
You will then want to switch out the Silver Surrounds for Silver LCR's and move them to where your prime listening spot is and just above ear level, so as no sounds get blocked by peoples' heads (same with the back surrounds). No dipoles allowed in 3D audio.
post #6493 of 6495 Old Today, 03:05 PM
jes5e's Avatar
I think that will end up being out of my budget. I've been going back and forth on if it's worth it.
jes5e is offline
post #6494 of 6495 Old Today, 03:10 PM
Quoted: 778 Post(s)
Liked: 441
It depends on the receiver or pre-amp you go with and which speakers you put in or on the ceiling (or at least wire for them). It's absolutely worth it! I heard just about every demo of home Atmos at CEDIA and it recreates the cinema version surprisingly well. It's like you're right in the middle of the action in an immersive environment (if you haven't heard a good Atmos mix at the theater). The minimum configuration recommended is 5.1.4. (5.1 + four overheads).
post #6495 of 6495 Old Today, 04:39 PM
Quoted: 84 Post(s)
Liked: 307
Watched Transformers 4 last night and OMG! Several scenes would be absolutely stellar if I was able to implement Atmos. The scene late in movie when objects were being sucked up in air was great.........can imagine Atmos would improve that scene BIGTIME!
BTW, having four large deep digging 18" subs at 1/4 space is the ticket!
Overall, movie wasn't a barn-burner, but certainly had moments.......sure tests LF ability of system.
My Build Threads
Reply Speakers
Triad
User Tag List
