Triad Owner's Thread - Page 220 - AVS Forum
 70Likes
post #6571 of 6584 Old 11-19-2014, 07:05 AM
jimim's Avatar
Quoted: 12 Post(s)
Originally Posted by hendry98 View Post
i have a small dilemma and i thought maybe you could help me out here.
My wife found that the Sub-woofer will be Inroom (2 x 15" Gold Sub-woofer), so she asked me gently to find alternative solution to hide them.
to my knowledge, Triad do sell Inwall Silver 12" and Bronze 10" Slim Sub, so i came up with the below mixes and hoping to hear your opinions
1- 2x Inwall Silver behind the AT screen (each between Center and Left/Right speakers) + 2x Bronze Slim Sub in the back wall. Or i can place them in each corner.
2- 4x Bronze Slim Sub, and each will be in the middle of each wall. (front, back and side walls)
3- 1x Silver Sub behind AT screen, and 3x Bronze Slim Subs go in the other walls.
3- any other suggestion? (Room size, 26'D x 16'W x 11'H), two rows with the first seat 15' from the screen and the back seat is 5' from the back wall)
Note: Inwall Silver Sub can only placed in the front wall due to the size limitation in the other walls.
You have a AT screen. So I'm just going on what Triad recommended cause at first i had one sub per middle of wall. Both Bryan Pape and Traid said the same thing to me. 2 up front 2 in the rear as close to corners as you can make it happen. So I would go with 2 gold inrooms behind screen and then as Triad if 2 bronze slims in the rear is enough for this size room. If you have columns can you go deep enough with them to get silver inwalls in the columns if the separation is far enough of the 2 columns? If you sare following the recommended angles for your rear surrounds then the columns should already be close enough to the side walls in the rear to make it work. But I do know Triad will say 2 up front and 2 in the rear. But I don't know if the 2 slim bronzes will be enough fill along with the 2 golds.
Or you can bypass t he whole triad sub thing and just throw some Seaton subs behind the screen if you got the room. That will prob do the trick. A lot of guys have em here.
Jim
jimim is offline
post #6572 of 6584 Old 11-19-2014, 07:11 AM
Dawn Gordon's Avatar
Quoted: 35 Post(s)
Liked: 36
Due to the size of your room, option 1 makes the most sense. Definitely position the IW Bronze Slim Subs in the rear corners, and if possible put the InWall Silver Subs as close to the front corners as you can.
Authorized Dealer Sales: Triad Speakers, NHT, Marantz, Denon, JVC, Stewart Filmscreen, Screen innovations, Panamorph and Control4.
Dawn Gordon is offline
post #6573 of 6584 Old 11-19-2014, 01:57 PM
robo1234's Avatar
Originally Posted by doublewing11 View Post
Currently have a Marantz 8801 which is an exceptional pre-pro. IMHO, there won't be a huge difference in other pre-pros. I recommend a pre-pro that is Atmos capable.
As far as where the 400 watts came from......I run my Gold LCR's off a Parasound A31 amp which is capable of 400 watts at 4 ohms which really makes the Golds sing. Just commenting due to receivers having a difficult time driving Golds to dynamic levels.
Well thanks for the input but para is a bit more than i can spend at this time but the 7702 is for sure any amps to look at before i pull the trigger.......MM8077 Thanks
robo1234 is offline
post #6574 of 6584 Old 11-19-2014, 02:49 PM
twells's Avatar
I ran my Gold LCRs off an Ada ptm-6150. These are great high current amps that are built like tanks. You can usually pick up a used one for $5-600. Only downside is that they are fan cooled so not the best if your equipment is in your home theater (mine isn't).
twells is offline
post #6575 of 6584 Old 11-21-2014, 08:53 PM
jimim's Avatar
Quoted: 12 Post(s)
If I wanted to put I wall speakers in a column am I still using the brackets? I mean I know I neecthe brackets to pull and hold the speaker forward so it doesn't fall backwards but what if I want to use an in wall piece in a column but use speaker grill material? Can I just attach the speaker to the wall or on a shelf and make the column opening to accept speaker grill material? I know I shouldn't be confused with this but I am. I want to keep the depth of the column as low profile as possible that why.
Jim
jimim is offline
post #6576 of 6584 Old 11-21-2014, 10:28 PM
doublewing11's Avatar
Quoted: 92 Post(s)
Liked: 319
Jim
My columns are 3/4" Knotty Alder plywood with dimensions 16" wide by 6" deep. Triad issues a cutout template I used for columns. Speaker has toggles top and bottom that require a screwdriver which squeezes the speaker to the plywood flush.........when done, attach grill. Very slick, easy system.
doublewing11 is offline
post #6577 of 6584 Old 11-22-2014, 07:24 AM
Quoted: 35 Post(s)
Liked: 36
Jim
Yes you could do that as long as 1) You make sure to tighten the 4 grill screws all the way down and 2) Use some acoustic batting or foam behind the speaker to push it forward.
post #6578 of 6584 Old 11-22-2014, 10:39 AM
jimim's Avatar
Quoted: 12 Post(s)
Ok that's right. That was what I was looking for. You have to pad em a bit in the back. I haven't installed my mini's yet for the kids game area. I'm using brackets for those but I remember now that I didn't need to if I padded them. So lesson learned is when I build my columns try to get em not much deeper than the silver lcr's being used.
Thanks guys.
jimim is offline
post #6579 of 6584 Old Yesterday, 08:14 AM
avguru99's Avatar
Hi guys,
I'm looking for opinions for a two channel system. Specifically I would like to know your opinion on the following:
Inroom Omni Gold Se
Inroom Silver Mini Monitor
Inroom Gold Mini Monitor
Reviews seem scarce especially for the Omnis so I'm hoping that some of you have real world experience with these speakers.
I'm thinking of using a Marantz PM6005 or PM7005 to drive them.
It will be for my home office set up, not a very large room about 13 ft by 10 ft.
I'm also looking at RBH SX-61/R as another speaker option.
Thank you in advance for your help.
avguru99 is online now
post #6580 of 6584 Old Yesterday, 08:49 AM
avguru99's Avatar
Forgot to ask - in terms of triad paint finish what is included? Is it a matte finish, satin, or glossy. Has anyone painted them Ferrari red? Were you happy with the results.
post #6581 of 6584 Old Yesterday, 04:16 PM
Quoted: 92 Post(s)
Liked: 319
Originally Posted by avguru99 View Post
Hi guys,
Inroom Omni Gold Se
For music only........you really should be looking at Gold Monitors......my favorite Triad Product.
As far as answering your question on painting grill, Triad will match any color you want.
post #6582 of 6584 Old Yesterday, 05:02 PM
avguru99's Avatar
The gold monitors look and probably sound pretty sweet. Unfortunately, they are outside of the present budget.
With regards to the painting, is it the grill or is it the entire speaker including the grill that is custom painted?
post #6583 of 6584 Old Today, 07:03 AM
Quoted: 35 Post(s)
Liked: 36
Regarding the Triad speakers you are considering, the InRoom Silver MiniMonitors will work best with the Marantz amp you are considering.
Triad will paint the speaker box in any matte or semi-gloss finish you wish. The MiniMonitors (both Gold and Silver) come with a fabric grille (black or white). The Omni Gold SE comes with a metal grill which Triad will also paint with your chosen color. I've seen the high gloss finishes and they are beautiful, however there is an upcharge for them.
post #6584 of 6584 Old Today, 11:08 AM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 623 Post(s)
Liked: 520
Robo1234
"Hi guys big? I have a Triad Gold LCR system driven by a Pioneer VSX-94 I am thinking of upgrading to a Marantz AV7702 with a marantz mm8077 the room is small 13 x 14 x 8 will we see a change is it worth the money sonically not for my ego . Or can you suggest another change that maybe better many thanks.
Regards
Robert"
Go with the 7702. That is what I am doing. Like Doublewing said, the 8801 is a nice AVR, but I would go with a prepro with Atmos.
Mike Garrett, AV Science Sales Call Me: 585-671-2968
Email Me: Mike@AVScience.com
Brands we sell: http://avscience.com/brands/
Call for B-stock projectors
Stewart, Seymour, SE, SI, Falcon, DNP & more.
RBH, Martin Logan, Triad, Atlantic Tech., MK Sound, BG Radia, SVS & Def Tech, Denon, Marantz & Yamaha .
AV Science Sales 5 is online now
Reply Speakers
Triad
