Triad Owner's Thread - Page 224 - AVS | Home Theater Discussions And Reviews
 82Likes
post #6691 of 6707 Old 01-13-2015, 12:45 PM
Dawn Gordon's Avatar
Quoted: 44 Post(s)
Liked: 39
Hi Jesse,
The first thing I would do is reset the Denon to factory default settings, and start over. Do not use the automated speaker setup. We'll do it manually for now.
0. Set All Speakers to Small.
1. Set the LCR's crossover to 80 or 90 and 90 for the surrounds.
2 Set the LFE Output to LFE and main.
3. Make sure that you have the LCRs and surround's distance to your seating position set correctly.
4. Make sure that the surround speakers are oriented properly. They are designed to go on specific sides of the room and are labelled left and right. Is it possible that you didn't see this when installing?
5. Make sure the sub is in a "node." Good spots for this are generally corners.
6. Check the speaker phasing. Even pro's can get this wrong from time to time.
7. Get some fabric in that room, area rugs, heavy curtains, fabric chairs and couches. Sounds to me like there's not enough absorptive surfaces in the room.
8. You can also raise the channel levels for the surrounds. A lot of folks complain that there's not enough sound coming out of the rears, and often it's the program material, and not the system. Get Spider-Man (2002) and watch Chapter 19 -- you'll see what I mean.
Let us know what happens!
Dawn
Authorized Dealer Sales: Triad Speakers, NHT, Marantz, Denon, JVC, Stewart Filmscreen, Screen innovations, Panamorph and Control4.
Dawn Gordon is offline
post #6692 of 6707 Old 01-13-2015, 12:53 PM
jes5e's Avatar
Thanks a lot Dawn, I'll give it a try and report back!
Originally Posted by Dawn Gordon View Post
Hi Jesse,
Dawn
jes5e is offline
post #6693 of 6707 Old 01-20-2015, 10:08 AM
audioguy's Avatar
Quoted: 555 Post(s)
Liked: 357
I will be joining the Triad community. I will be getting 3 Platinum LCR's for the front and 4 Silver Monitors for side and rear surrounds. Anxiously looking forward to getting this installed.
craig john, MIkeDuke and grtuck like this.
New Theater
Don't count the years. Make the years count. Lou Holtz
audioguy is online now
post #6694 of 6707 Old 01-20-2015, 11:47 AM
BrolicBeast's Avatar
Quoted: 316 Post(s)
Liked: 405
YESSSSSSSSSSSSSS!!!!!!!!!!!!!!!!!!!!! Welcome, good sir, to the club!
BrolicBeast is online now
post #6695 of 6707 Old 01-20-2015, 12:52 PM
audioguy's Avatar
Quoted: 555 Post(s)
Liked: 357
I went to CraigJohn's over the weekend, and except for 3 hours we sat on the Tollway due to an ice storm and some very serious auto accidents (including two deaths), it was a great time. I was sold ofter he put on the first multi-channel DVD (NOT Bluray) of some music. I can't compare to the sound in my room exactly with the Seaton speakers since our rooms are treated very differently. But I heard enough to write the check.
New Theater
post #6696 of 6707 Old 01-20-2015, 01:44 PM
nathan_h's Avatar
Quoted: 163 Post(s)
Liked: 105
(anyone looking for Silver Surrounds, on wall style, current version, please check out my post in the classifieds)
____________________
Build Thread & current gear list: "Nathan's Theater in Search of....".
though the Triad On Wall Silver Surrounds are listed for sale, and will be replaced by direct radiating speakers for object-oriented sound this year.
nathan_h is offline
post #6697 of 6707 Old 01-20-2015, 10:01 PM
DougF's Avatar
Help with all ceiling 5.1 HT and music system
In my 15 x 19 room I need to go all ceiling (although maybe subwoofer in wall if unobtrusive location). A 60" TV will be centered on one 19' wall with the seating area on the opposite 19' wall. I also want decent quality 2 channel music from the LR ceiling speakers. As a comparison, in my old house I used to run 5 Paradigm SA-35 inwalls and I thought they sounded good for both HT and music.
So, how about IC Silver Mini Monitor for LCR? Will they be markedly superior to the IC Bronze/8 LCR? For HT? For music?
And for surrounds, I've looked at Dawn's chart but no ceilings are listed as surrounds. If I have to use ceilings for surrounds, what do you recommend for the Silver LCR? For the bronze LCR?
Finally, the subwoofer -- if I went in the ceiling, where would it go best -- between the two surrounds so directly over the seating area? Or should I put it in the wall at floor level - my options would be to put it directly under the surround (on the right) or directly under the TV?
The basic setup of the 5 ceiling speakers, without the subwoofer, would like something like this:
L C R
S S
Thanks - sorry if I'm leaving important info out - just let me know. Your help is much appreciated.
DougF is online now
post #6698 of 6707 Old 01-20-2015, 10:18 PM
Dan Hitchman's Avatar
Quoted: 1295 Post(s)
Liked: 628
L C R
S S
Any particular reason you have to have all in-ceilings? Otherwise, there will be no Dolby Atmos, or DTS-X, or Auro3D in your future.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is online now
post #6699 of 6707 Old 01-20-2015, 10:23 PM
DougF's Avatar
In a nutshell -- windows and wife. So, ceilings it is.
DougF is online now
post #6700 of 6707 Old 01-21-2015, 07:26 AM
Quoted: 44 Post(s)
Liked: 39
Doug,
Yes, you can use in-ceilings for surrounds (I'm updating the chart next month), but as Dan pointed out, if you configure all your speakers as InCeilings you will lose the ability to use Atmos processing. Since that's not a problem for you, then you should be fine using IC Bronze or IC Silver LCRs for your surround channels. Triad doesn't normally make IC Silver LCRs, but they will custom build them for you for an additional charge. Keep in mind that the Silver LCR InCeiling model will be 19" wide, so your ceiling joists need to accommodate this width.
post #6701 of 6707 Old 01-25-2015, 09:58 AM
fred_ugly's Avatar
This question is for Paul, but anyone else is welcome to chime in...
Thanks for your advice re surrounds. I found a way to mount my klipsch surrounds that I am happy with. That means I can focus on upgrading main speakers now...
I could use some advice on Bronze or Silver LCR InWall speakers as fronts.
My situation is as follows:
- 15x20 living room, open to kitchen, so really it's one long room 15x40
- front speakers are very modest Klipsch Synergy B3 bookshelves (6.5" woofer) and C2 center (2 x 5.25")
- the bookshelves "theoretically" go down to ~60Hz (according to specs) but center doesn't go below 80Hz
- music and effects sound fine but my problem is that I can't hear the dialog unless it is turned way up
- this could be caused by Audyssey calibration or speaker setup, or even a bad center channel, but what I really think is that my small center and other mains are getting lost in this huge room
- this is the primary living area, so aesthetics are very important (high WAF), large towers are not an option
- decent bookshelf speakers or in-wall would be best
- TV is wall mounted above low entertainment console
My question is: would InWall Silvers be an order of magnitude better than what I have now? Or even Bronze?
Sorry if this is a dumb question...
Philip
fred_ugly is online now
post #6702 of 6707 Old 01-25-2015, 10:33 AM
Liked: 628
Philip
In-Wall Silver LCR's would be quite a big leap forward and should be considered for a larger room. But then you should also consider upgrading your surrounds to matching Triads as well at some point, so there is a closer timbre match around the room.
post #6703 of 6707 Old 01-25-2015, 12:09 PM
fred_ugly's Avatar
Thanks Dan! I assumed that would be the case, but thanks for confirming.
post #6704 of 6707 Old 01-25-2015, 12:14 PM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 1040 Post(s)
Liked: 628
Very nice.
Mike Garrett, AV Science Sales Call Me: 585-671-2968
Email Me: Mike@AVScience.com
Brands we sell: http://avscience.com/brands/
Call for B-stock projectors
Stewart, Seymour, SE, SI, Falcon, DNP & more.
RBH, Martin Logan, Triad, Atlantic Tech., MK Sound, BG Radia, SVS & Def Tech, Denon, Marantz & Yamaha .
AV Science Sales 5 is online now
post #6705 of 6707 Old 01-26-2015, 06:03 AM
Quoted: 44 Post(s)
Liked: 39
Philip
Like Dan says, Triads would a big improvement, especially Silver LCRs for that size room.
I'm not a huge fan of auto calibration. So, the first thing I would do is delete all the auto settings and start from scratch -- but go the manual route. You can also feel free to raise the center channel level if room acoustics and/or speaker placement are causing center dialog issues.
post #6706 of 6707 Old Yesterday, 07:49 AM
fred_ugly's Avatar
Thanks for the response Dawn. And thank you for creating the Triad Speaker Matching Chart. Very helpful!
I hope to be joining the Triad community soon...
post #6707 of 6707 Old Today, 05:08 PM
DougF's Avatar
Low Sensitivity vs Volume - Omni Silvers vs Mini/8 LCR
Due to some size constraints in my all-ceiling HT, I am looking at using either:
  • 5 InCeiling Silver/8 Omni SE with a sensitivy of 85db and impedance of 8 ohms; or
  • 5 InCeiling Mini/8 LCR with a sensitivy of 88db and impedance of 4 ohms
I'm told that the Silver's have better sound quality. But I'm concerned about volume levels. I have a Sherbourn 5/1500 amp which is 5 x 200 - essentially 5 monoblocks in a single chassis. I like to listen to HT and 2 channel music loudly. The Sherbourn was fine with my old in-walls (paradigm sa-35 with 92db sensitivity).
Will the Silvers be loud enough?
DougF is online now
Reply Speakers
Triad
