Triad Owner's Thread - Page 237 - AVS | Home Theater Discussions And Reviews
 181Likes
post #7081 of 7104 Old Yesterday, 09:35 AM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 1355 Post(s)
Liked: 743
Originally Posted by doublewing11 View Post
Oh my gosh Mike! Hope your pocket book is heavily laddened!
Dumb me. I was the one having to push my wife into it.
Mike Garrett, AV Science Sales Call Me: 585-671-2968
Email Me: Mike@AVScience.com
Brands we sell: http://avscience.com/brands/
Call for B-stock projectors
Sony, JVC, Stewart, Seymour, SE, SI, Falcon, DNP & more.
RBH, Martin Logan, Triad, Atlantic Tech., MK Sound, SVS & Def Tech, Denon, Pioneer, Marantz & Yamaha .
AV Science Sales 5 is online now
post #7082 of 7104 Old Yesterday, 09:39 AM
AVS Club Gold
Liked: 743
Originally Posted by lovingdvd View Post
I'm looking at using the Triad Gold Monitors or LCRs for behind an AT screen, primarily for movies but on some occasions for music listening as well. I think these are rated to 50 hz but are (large) bookshelf-like speakers as opposed to towers. In this case would these speakers typically be set to Large or Small in a preprocessor like the Marantz 8802 when used in conjunction with multiple subs in a dedicated home theater? Normally I would think the recommendation would be to run them as Small to leave the power for the mid and upper frequencies and let the group of subs do the heavy lifting. But I was reading an article by Paul Spencer to suggested that in some cases you can let your mains also play down to the lower frequencies if it helps smooth out any voids, perhaps in the 50-80 hz region? Thanks!
Pretty much any speaker sold, should be set to small for HT, if using subs. My mains have 18's and they are set to small. It would have been much better if AVR manufacturers had used the term full range and non-full range, rather than large and small.
nathan_h likes this.
post #7083 of 7104 Old Yesterday, 09:39 AM
lovingdvd's Avatar
Quoted: 609 Post(s)
Liked: 128
Not dumb. More like, strategic. Greasing the wheels for your next theater upgrades.
lovingdvd is offline
post #7084 of 7104 Old Yesterday, 09:41 AM
AVS Club Gold
Liked: 743
Thanks. Do the also recommend the same for the Gold LCRs?
Yes. Pretty much all speakers used for HT used with subs, should be set to small.
post #7085 of 7104 Old Yesterday, 09:45 AM
AVS Club Gold
Liked: 743
Originally Posted by BllDo View Post
Anybody know if Triad is running with Mundorf or Beyma AMTs?
I believe it is a custom Beyma.
BllDo likes this.
post #7086 of 7104 Old Yesterday, 09:51 AM
AVS Club Gold
Liked: 743
Just to clarify, you mean 6.5 ft away from directly overhead in your front row (not a compromised spot half way between front and back row right)?
I understand now what you are saying. You want to know about swiveling the speaker - turning it horizontally - since otherwise the tweeter aim is to the left and right of you instead of directly at you. That's actually a great question. I am guessing that yes it should be aimed that way. However please check with a professional as I am just making an educated guess here.
If you have two rows and you want good sound in all seats, you might want to measure from the spot between the two rows and use the 30 degree and 150 degree angle shown here: http://www.dolby.com/us/en/guide/dol...-4-setups.html Then rotate all ceiling speakers to point at this spot. That would give the most even coverage. Or you could just base it off of the main seat, since you will most likely be the person that cares about this the most.
hendry98 likes this.
post #7087 of 7104 Old Yesterday, 09:55 AM
AVS Club Gold
Liked: 743
Have to build my fund back up. Had 8K in it and donated it to the kitchen. Right now, only two items that I am in need of for my HT are not available yet. One is a 4K BD player and the second is a method for doing vertical stretch of 4K movies. I have several months before I actually need these items.
post #7088 of 7104 Old Yesterday, 11:03 AM
hendry98's Avatar
Quoted: 87 Post(s)
Liked: 3
Thanks for your reply, so you are supporting what i am doing actually right? to aim the speaker towards my MLP.
i think it makes sense, otherwise, my MLP would be out of the speaker dispersion!
before tilting the speaker, the angle was 38 degree, where i should be within 30degree (60 dispersion = 30degree on each side).
hendry98 is online now
post #7089 of 7104 Old Yesterday, 11:13 AM
AVS Club Gold
Dennis Erskine's Avatar
Quoted: 25 Post(s)
Liked: 55
With multiple seats, multiple rows, and ceiling heights less than 10', you are well advised to not mount speakers on the ceiling for ATMOS. Ceiling treatments and reflective height speakers don't play together well. That is not to say it cannot be done, it is to say there are real challenges. Reading all the printed material and speculation from those who haven't been there, may start you in the right direction but it won't give you a solution for any given room. Perhaps a year from now there will be more people out there with hands on experience with these 3D formats; but, right now real world experience in small rooms is hard to come by.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
www.CinemaForte.net
Dennis Erskine is offline
post #7090 of 7104 Old Yesterday, 11:16 AM
hendry98's Avatar
Quoted: 87 Post(s)
Liked: 3
Exactly!, and this is what i am doing right now!
by the way, regarding my main LCR which are InWall Triad Gold. since it is not an easy job to do DIY baffle wall without professional help, i am going to do a false wall instead (normal wood framing covered by GoM.), and this means i am building speaker boxes to host my LCR since they cannot sit on normal shelves, and then build normal screen frames for my Seymour screen.
would that be ok? or what do you suggest in this case?
however i can do baffle wall, but for future maintenance, it will be pain in the ***, since i went with 2x InRoom Gold Subs, and if they sit inside the baffle wall, it will be pretty hard to reach without removing the complete screen framing!, not to mention my Subs if placed below the screen, the screen frames will block about 5" of the subs from the top.
post #7091 of 7104 Old Yesterday, 11:22 AM
hendry98's Avatar
Quoted: 87 Post(s)
Liked: 3
Originally Posted by Dennis Erskine View Post
With multiple seats, multiple rows, and ceiling heights less than 10', you well advised to not mount speakers on the ceiling for ATMOS. Ceiling treatments and reflective height speakers don't play together well.
I have one row for movies viewing, with 3 seats. and my ceiling height is 10.2'.
the height speakers is approx. 8.2' (diagonally from my ears) from my MLP.
and no ceiling treatments in my HT.
post #7092 of 7104 Old Yesterday, 05:25 PM
Dan Hitchman's Avatar
Quoted: 1560 Post(s)
Liked: 742
Thanks. Do they also recommend the same for the Gold LCRs?
Yes. They're not full range speakers. Very few are. Maybe Wilson Watt Puppies or some other huge monstrosity.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is online now
post #7093 of 7104 Old Yesterday, 06:04 PM
doublewing11's Avatar
Quoted: 137 Post(s)
Liked: 429
Smooth bass is such a difficult proposition.....................never understood why someone would want full range speakers anyway.
doublewing11 is offline
post #7094 of 7104 Old Yesterday, 06:06 PM
Liked: 742
Usually since the best place in the room for great bass reproduction is not where the actual speaker is located.
doublewing11 likes this.
post #7095 of 7104 Old Yesterday, 06:19 PM
Quoted: 137 Post(s)
Liked: 429
TRUE!!!!
What the heck? Two grown men winking at each other!
post #7096 of 7104 Old Yesterday, 06:26 PM
Liked: 742
TRUE!!!!
I'm definitely not going anywhere to pick out curtains.
Not that there's anything wrong with that.
post #7097 of 7104 Old Yesterday, 07:03 PM
AVS Club Gold
Liked: 743
Even with those speakers, if you have subs the quality of the speakers, you would still want to run the speakers as small. Since the subs would be able to perform better down low.
post #7098 of 7104 Old Yesterday, 08:27 PM
lovingdvd's Avatar
Quoted: 609 Post(s)
Liked: 128
Interesting you mention that because that's my situation - 7.75' ceilings and multiple rows/seats. However I only care really about the sound from the front row and in particular the front center speaker. I am considering doing the Atmos front heights at 30 degrees. That would put them well in front of the first point of reflection. So that would enable me to have absorption on the ceiling that would not interfere with where the speakers need to be mounted. I could see how one has to be careful to make sure their speakers don't wind up where the first point of reflections are since that would make it hard to have absorption there plus interfere with the sound.
Below is one model that shows this proposed 9.1.6 layout. Thoughts from all welcome. Thanks!
post #7099 of 7104 Old Today, 02:47 AM
Gary Lightfoot's Avatar
Quoted: 117 Post(s)
Liked: 78
You might want the LCRs a little higher so the sound can get to the back row easier and over the heads of the front row.
Side surrounds could maybe be a little higher, or a little behind each row so that the heads of people in the outer seats don't interfere with the sound getting to the people sat further in.
Gary
Originally Posted by elmalloc
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is offline
post #7100 of 7104 Old Today, 06:37 AM
Dawn Gordon's Avatar
Quoted: 68 Post(s)
Liked: 54
I spoke to one of Triad's engineers yesterday, and he actually prefers to run the Gold LCRs full range with subs. He said not to count full-range out with these speakers. Might be worth a try just for kicks if nothing else.
Although I've always set pre-pro's to small, I'm going to play with this the next time I install Gold LCRs for a client.
Authorized Dealer Sales: Triad Speakers, NHT, Marantz, Denon, JVC, Stewart Filmscreen, Screen innovations, Panamorph, Oppo and Control4.
Dawn Gordon is offline
post #7101 of 7104 Old Today, 07:28 AM
Quoted: 137 Post(s)
Liked: 429
Be very careful with this idea!!! I set crossover at +/- 3 db location for Golds and drivers bottomed out using REW with 75 db signal.
Needless to say, I keep crossovers at 80 Hz or above!
post #7102 of 7104 Old Today, 08:08 AM
Livin's Avatar
Quoted: 36 Post(s)
Question
Dennis,
Are you saying if your ceiling is 10' high then you would mount in-ceiling speakers? I'm starting to design my room and I want to build it so I won't have to tear up drywall/etc and cn lready have the wires ran - even if I don't install speakers yet. What would you do in this case?
thx for the input!
________
Ltek
my setup: XBMC, Windows Media Center, Z-Wave/Insteon automation, Paradigm-Parasound-Onkyo-Velodyne Home Theater, 110" DIY Screen & BenQ W1070
Livin is online now
post #7103 of 7104 Old Today, 08:35 AM
Liked: 742
Originally Posted by Livin View Post
Dennis,
thx for the input!
Other people around here have installed in-ceiling and on-ceiling speakers with less than 10 foot ceilings and have had sonic success with Atmos.
post #7104 of 7104 Old Today, 08:40 AM
AVS Club Gold
Liked: 743
I guess if you only listened at -15db below reference and no louder then you would be safe, but running them full range is asking for trouble if you ask me. I agree with you, Cory.
Reply Speakers
Triad
