Triad Owner's Thread - Page 247 - AVS Forum | Home Theater Discussions And Reviews
 240Likes
post #7381 of 7384 Old 06-23-2015, 04:37 AM
Dawn Gordon's Avatar
Quoted: 91 Post(s)
Liked: 64
Originally Posted by lovingdvd View Post
Thanks Dawn. Does that mean I must use the Triad rack amp for this, or can I use an amp like the iNuke, which I presume would have similar features?
Also is there any information from Triad - an instruction manual or owners manual - for the amp you mentioned and in particular details the whole range of adjustments available? I looked all through their website and could not find anything like that.
Batpig and others are correct. You really want to use the Triad RackAmp. Everything from output, to crossovers is designed with these subs in mind.
Authorized Dealer Sales: Triad Speakers, NHT, Marantz, Denon, JVC, Stewart Filmscreen, Screen innovations, Panamorph, Oppo and Control4.
Dawn Gordon is offline
post #7382 of 7384 Old 06-23-2015, 09:17 AM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 1780 Post(s)
Liked: 942
Thanks guys! Is 350W really enough to fully drive this 10" woofer? I'd imagine so or they wouldn't match it with the 6" in-wall sub, but doesn't seem like that much power. It has only a 6 band PEQ?
If I wind up using 4 of these as balancing subs then I need 4 of the 350 rack amps? How much rack space do these take up? Miike any feel for how well this will all integrate with the much bigger Seaton Submersive F2+ dual 15" and Dirac Live?
Does anyone here have the 6" in-wall Triad sub? I've heard good things about them, but would like to hear from some owners.
You are using them for balancing subs to smooth response, so they will work well for what you need.
Mike Garrett, AV Science Sales Call Me: 585-671-2968
Email Me: Mike@AVScience.com
Brands we sell: http://avscience.com/brands/
Call for B-stock projectors
Sony, JVC, Stewart, Seymour, SE, SI, Falcon, DNP & more.
RBH, Martin Logan, Triad, Atlantic Tech., MK Sound, SVS & Def Tech, Denon, Marantz, Yamaha & MiniDSP.
AV Science Sales 5 is online now
post #7383 of 7384 Old 06-24-2015, 03:32 PM
Liked: 0
Anybody have experience with the Triad R Series? I use mostly Paradigm speakers normally, but the CI I'm working with recommended the R 26's just to save a bit on budget. Triad R26's are quite a bit less sensitive than the Paradigm 6.5" in-ceiling speakers I'm looking at (87 db vs. 91.5 db), but ceilings are only 9' high and I have plenty of power so it shouldn't be a major issue. Curious about the R Series, as Triad doesn't publish any literature on them and they appear to be the only speakers they sell (at least in the in-ceiling lines) that are imported. Specs surprise me a bit too. The Silver Open series speakers, that list for 2x the R26 are spec'd at 70 hz on the low end vs. 50 hz for the R26. Seems a bit backwards, if accurate, or possibly just stretched for the R26?
I don't have anything at all against Triad, just no experience with them and I don't think the CI has listened to this model either. Think he's just going off a recommendation from distributor and on price. I'm trying to get a handle on the musicality.
Thanks in advance for any feedback.
TJ
tennesseejed is offline
post #7384 of 7384 Old 06-25-2015, 05:24 AM
Quoted: 91 Post(s)
Liked: 64
I heard the R Series at a distributor showroom. Pretty impressive for the price point. All of Triad's round in-ceiling speakers are imported. Tell your installer that you want to try a pair. If you like them just buy more.
Reply Speakers
Triad
