Triad Owner's Thread - Page 262 - AVS Forum | Home Theater Discussions And Reviews
 321Likes
post #7831 of 7847 Old 02-04-2016, 07:15 PM
rabident's Avatar
Quoted: 215 Post(s)
Liked: 72
What triad speakers would be appropriate for my room? 1 row seating. MLP about 16 feet back on a 2 foot high riser in a slightly smaller than 20x30x12 room. I listen -10db below reference. I guess designing for reference is ok, since that allows 10db of headroom, so I am not running the system at its limits.
I would like 7 speakers, plus Atmos if possible. I am past the point where putting speakers in the ceiling is viable.
rabident is offline
post #7832 of 7847 Old 02-04-2016, 08:14 PM
batpig's Avatar
Quoted: 2879 Post(s)
Liked: 2759
I think in a room that size most will tell you Silver at a minimum, and Gold if you actually want clean reference level.
I have Bronze LCR in a much smaller room (16x17 with 11-12ft distance to front 3 speakers) and they can do -10 easily powered by my Denon 6200 internal amps. But you will need considerably more.
The good news is the room is so large that you can use direct firing speakers for surrounds which is ideal for immersive audio. So maybe Silver LCR for surrounds and LR-H in back for rear Atmos (just to be clear can you do ON ceiling or do you need reflective modules)?
batpig is offline
post #7833 of 7847 Old 02-05-2016, 04:44 AM
BrolicBeast's Avatar
Quoted: 861 Post(s)
Liked: 722
In a room that size, you'll need more than 7 speakers, I think. You need Platinums or Golds for your LCRs...Golds for surrounds, since Atmos is changing the way surround channels are mixed (no holding back). You can do Atmos...Will need to do a coffered ceiling and run speaker wires within the wood assembly.
BrolicBeast is online now
post #7834 of 7847 Old 02-05-2016, 10:23 AM
AVS Club Gold
Mike Garrett's Avatar
Quoted: 3294 Post(s)
Liked: 1964
I would look at Gold or higher.
mike@avscience.com
Sony, JVC, Epson, Denon, Marantz, Yamaha, Onkyo, Triad, Atlantic Tech, M&K, RBH, SVS, Polk, Stewart, Seymour, Falcon, DNP, SI, Screen Excellence, Carada & more.
Mike Garrett is offline
post #7835 of 7847 Old 02-05-2016, 11:48 AM
AVS Club Gold
craig john's Avatar
Quoted: 409 Post(s)
Liked: 603
Originally Posted by easycruise View Post
I'm trying to figure out how to get some speaker boxes for the KEF in-ceiling speakers like you have. KEF doesn't offer them. I don't have time to make them myself, so I am now leaning towards getting the Triad IC silver monitors because they are in an enclosure. Would this be an OK switch. considering?
My theater is single row seating, so Triad has said that 90x90 round speakers are OK for this application. Please share your thoughts. Thanks
Dave,
Triad's naming system can be confusing. The IC Silver Monitor 6 is not a round speaker:
http://www.triadspeakers.com/product...lver6-monitor/
Are you meaning the IC Silver Sealed Round:
http://www.triadspeakers.com/product...r-sealedround/
That speaker is not part of the "Silver Monitor" line as it uses different drivers altogether.
If you're referring to the Silver Sealed Round, then I would suggest you consider the IC Silver DT Sealed Round, which has dual tweeters and would have broader dispersion:
http://www.triadspeakers.com/product...t-sealedround/
My only concern would be their ability to keep up with the Platnums and Gold LCR surrounds in terms of output. If Triad says they can, then... I guess they can.
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #7836 of 7847 Old 02-05-2016, 01:36 PM
rabident's Avatar
Quoted: 215 Post(s)
Liked: 72
Still no timbre matched gold Atmos speakers, though, correct? Same for the Plats - they have LCR and subs but no surrounds. The Cinema reference use AMT in LCR, and while they have designated CR surrounds, they don't use AMT drivers.
It looks like silver is as high as the timbre matched systems go for Atmos, no?
Do the LCR or the monitors play louder? Can I mix them?
rabident is offline
post #7837 of 7847 Old 02-05-2016, 08:40 PM
doublewing11's Avatar
Quoted: 223 Post(s)
Liked: 731
Should work fine........................
I used the Kef's due to wanting dispersion for two rows of seven seats..................if you're talking only one row, should be fine and is a solid choice. Oops......Mike already answered.
doublewing11 is offline
post #7838 of 7847 Old 02-05-2016, 11:40 PM
Quoted: 223 Post(s)
Liked: 731
NO YOU'RE NOT!!!!
You have 12 ft ceiling for crying out loud! Perfect height for building something beautiful on the ceiling to hide Atmo ceiling speakers............and use it as a chase for wiring!!!!
joaquin and Mike Garrett like this.
post #7839 of 7847 Old Yesterday, 12:47 PM
easycruise's Avatar
Quoted: 72 Post(s)
Why would he need to do a coffered ceiling? I plan on doing a Atmos theater with a painted starfield ceiling with no coffer beams. Is there something I am missing?
easycruise is offline
post #7840 of 7847 Old Yesterday, 12:51 PM
easycruise's Avatar
Quoted: 72 Post(s)
Originally Posted by craig john View Post
Dave,
Craig
Hi Craig, those DT sealed rounds are 8 ohm speakers. Is that a problem mixing them with the Plats? And they are 87 sensitivity versus the 94 of the Plats.
I am still trying to figure out why Triad said to mount the inceiling silver monitor 6 speakers in the corners of the room. That placement makes no sense to me with Atmos. I would just like to know which ceiling speakers I should get with backing boxes and where to mount them.
post #7841 of 7847 Old Yesterday, 01:59 PM
Quoted: 861 Post(s)
Liked: 722
Greetings. He mentioned he was beyond the point of putting speakers in his ceilings. The coffered ceiling would give him raceways that he could run the cable through to surface mounted speakers.
post #7842 of 7847 Old Yesterday, 05:57 PM
rabident's Avatar
Quoted: 215 Post(s)
Liked: 72
Yeah, I could build down, but I can't put anything above the drywall. Too much women cave infrastructure running above. I thought on-wall vs in-wall might make a difference in recommendations. I wasn't able to view the compatibility chart from my iPad, but after pulling it up on a PC it answered a lot of questions.
Raised some, though, like why do the silver monitors match the plats and the golds don't? Also, I didn't see the new silver height modules listed, as far as what which models they work with.
Still thinking the silvers all the way around, with silver Atmos bounce speakers would be easiest if I could fit under their SPL limits. Does Triad provide max usable SPL stats for their speakers? By usable, I mean in a way a normal person would use them, before distortion or other undesirable artifacts from pushing the speakers to hard start to manifest.
rabident is offline
post #7843 of 7847 Old Yesterday, 07:43 PM
mmiles's Avatar
Quoted: 149 Post(s)
Liked: 57
The coffered ceiling or "box beams" will provide some diffraction of the sound and it looks great too. It's just another way to skin the cat.
Check out your PM inbox. Maybe we can still get together.
Mike Miles
ICR | Home based AV Business - mmiles442004@yahoo.com
Process Integration Inc. | System Integration - mmiles@processintegrationinc.com
Open Automation Software | SCADA and more mikemiles@opcsystems.com
mmiles is offline
post #7844 of 7847 Old Today, 04:20 AM
Liked: 0
Hi I am new member and I'd like to thx the guys here for there valuable info abou triad speakers and now i am planing to go with triad spekers for my home theater and i like to have ur comment my system will be as planing is triad silver 7.1.4 and my room is about 19"*14*W*12H .
The system will be :
- Triad IR SILVER LCR (3 inrom 4 in wall for the surround)
- Triad IR SILVER SUB (one at the moment and mybe i will go for 2)
-Triad IC SILVER/6 SATELLITE (4 for atmos)
My Q. Is is this system will be fine or should i go with the golds ?
Note: still not decide about the av receiver still wait to see a one had all the new format.
Plz id like to have ur sugest about my system
Best regards
Ahmed
A7mad78 is online now
post #7845 of 7847 Old Today, 04:39 AM
Dawn Gordon's Avatar
Quoted: 127 Post(s)
Liked: 83
Originally Posted by [COLOR=#000
rabident[/COLOR];41410233]Yeah, I could build down, but I can't put anything above the drywall. Too much women cave infrastructure running above. I thought on-wall vs in-wall might make a difference in recommendations. I wasn't able to view the compatibility chart from my iPad, but after pulling it up on a PC it answered a lot of questions.
Triad doesn't have SPL charts per se. But I did manage to get a room size guide/chart from them.
Authorized Sales: Triad Speakers, NHT, Marantz, Denon, JVC,
Panamorph, Sony, Stewart, SI Screens, Oppo and Control4.
Contact us for Home Theater pricing and assistance.
Sales@EgretElectronics.com
Dawn Gordon is online now
post #7846 of 7847 Old Today, 04:49 AM
Quoted: 127 Post(s)
Liked: 83
Best regards
Ahmed
As far as room size, you are definitely good to go with the Silver system. Everything looks good as far as speaker selection. I do recommend two subs, as this will smooth out your low end. Triad recommends putting the subs in diagonally opposing corners.
Optionally:
Since your room is narrow, you could alternatively go with InWall Bipole Silver Surrounds for the sides, and possibly the same for the rears. It depends on how close your seating is to the surround speakers.
Dawn
post #7847 of 7847 Old Today, 05:02 AM
Liked: 0
Optionally:
Dawn
Thx dawn.. the seating is 65cm for the back and 68.4cm for the side
Reply Speakers
Triad
